CS fender liners need replacement | FerrariChat
Discussion in '360/430' started by ylshih, May 23, 2006.
  1. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,578
    Northern CA
    Yin
    I did the Ferrari Challenge Driving Clinic at Infineon last week and I turned the car in yesterday to get it serviced and put on new tires. The dealer just called up and said they recommended replacement of all four fender liners because all the louvers were cracked or broken due to large chunks of rubber getting thrown into them.
    Is this a common issue after being on a track? I asked about that and the service tech said that since the driving clinic was being let out in between the Challenge race cars there was a lot more rubber debris on the track than when a sports group has the track all day.
    Anyway I was expecting tires and possibly brake pads as wear items, but not the fender liners.
  2. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    This seems common. The louvers are fairly brittle.
    Some people have taken the louver-less fender liners off, attached stainless or aluminum mesh to the back of them, then reinstalled them. Replacing with new liners will only lead to the need to replace them again and again.
  3. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Sheesh. I've never seen that personally. What's the tab on those bad boys?
    Gary
  4. ylshih
    Honorary Owner
    Mar 21, 2004
    20,578
    Northern CA
    Yin
    $1200 + labor (1-2 hours).
    I told them to hang on to the old liners, thinking along the lines of the suggestion to cut open the louver areas and replace with mesh or something and then have them to exchange back for the new liners based on activity.
  5. Valence
    Valence Formula Junior
    Jan 20, 2004
    883
    Charlottesville, VA
    Chris& Brian Coffing
    Do you want to send them to us to be fabricated in carbon/Kevlar? They'd be a lot tougher then. We love making "non-cosmetic" parts.
  6. ChalStrad
    ChalStrad Formula 3
    Jan 22, 2004
    2,249
    Lausanne Switzerland
    Peter Mann
    Don't worry about them, leave them as they are. If you replace them they'll be broken within miles....but $1200???? boy am I pleased that I don't have to go to a N.American Ferrari dealer!!!!
    THAT is insane!
  7. MufflerMan
    MufflerMan Formula 3
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    Chicken sh*t. Ferrari should replace them free of charge. If you build a car for a race track, build it to withstand normal racetrack wear. If you stuff it in a wall, sure thats your responsibility, consumable parts (brakes, tires, etc) absolutley your resposiblity, but fender liners? I usually have the manufacturers back, but that is BS. I plan on buying a CS soon and I am disapointed to hear about this.
