CS front tires | FerrariChat
CS front tires
Discussion in '360/430' started by sezme, Aug 20, 2007.
  1. sezme
    sezme Formula Junior
    Oct 23, 2006
    558
    NJ
    sezme
    I found 4 front Pirelli Corsa (225/35-19.) They are expensive at $450 per tire. Anyone interested in my spares IF I do the deal?
    Stu
  2. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    The 235 Corsa's work fine and the tires you found are probably dated 2004. You might check the date code ie. 3404 34th week of 2004. These tires are now getting fairly old and will not stick as well as newer tires. The 235's on Tire Rack are in stock now. Pirelli might not make the 225's again. The Scuderia is using 235's in the front but probably on 8.0 wide rims. The Stradale only has 7.5" rims. I wonder if we can get 8.0" from BBS. Maybe a group buy would be of interest to them.
  3. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    you xghould check the date these tires were manufactured. i bet they weare made way back in 2003. rubber loses some of its charm. pirelli is making the corsa rear tires so you can get them manufactured in 2007. but i am almost certain that they have not made the sizes for the front in years. but pirelli corsas are available in a slightly wider size for the front (235/35-19 instead of the original 225/35-19) but at least two stradale owners have tried these slighter wider tires and they have been VERY happy.
