cs heater | FerrariChat
cs heater
Discussion in '360/430' started by coledoggy, Oct 13, 2007.
  1. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    took the stradale out tonight, turned on the heat, and just kept getting cold air. lord have mercy, is this something i'm going to have to put with, or pay 3k to get fixed?
  2. Donie
    Donie Formula Junior
    Jan 14, 2006
    346
    Spain/Ireland
    Are you sure that the STOP button is out, because otherwise you will get no heat on the Ferrari, apart from when you set DEFROST, which overrides the settings.
    I find this very peculiar on the Ferrari 360, since on Porsches and others, you can get heat without having the A/C running.
  3. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    I had this exact problem, AC would work fine, but no heat. It was the AC/Heating ECU which needed to be replaced, mine was fixed under warranty, but I wouldn't be surpised if the ECU was expensive...
  4. nerd
    nerd F1 Rookie
    Oct 12, 2003
    2,539
    Coronado, CA
    RSK
    I live in Phoenix, AZ....what's a heater? I'm grateful that my CS has excellent air conditioning!
