CS: Metal Crunching Noise | FerrariChat
Discussion in '360/430' started by mrmckay, Jun 21, 2007.
  1. mrmckay
    mrmckay Formula Junior
    Jul 14, 2003
    488
    MD, USA
    Chris
    Has any heard a noise originating from somewhere behind the driver's seat when first driving off after starting the car? The noise sounds like a tin can "crunching" or "popping" and it goes away after about 30 - 45 seconds. It doesn't happen all the time but I've reported it to the dealer and they have been unable to reproduce. I was wondering if it could be something related to the F1 pump?
    Regards,
    Chris
  2. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    Have owned three Stradales and have never experienced anything like you're describing. The only consistent issue was the ball joint noise up front which was repaired under warranty in every case. Other than that ... no popping or crunching noises.
  3. fuse
    fuse Formula Junior
    Aug 11, 2004
    340
    Same here, has had experiences with quite a few CS and never heard of that noise before. Hopefully they can find it for ya.
  4. mrmckay
    Jul 14, 2003
    488
    MD, USA
    Chris
    Jeffrey,
    Thanks for the info.This is my second and I didn't experience anything like this on my first CS. Hopefully it's nothing to be concerned about.
    Regards,
    Chris
  5. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    Have owned three Stradales and have never experienced anything like you're describing. The only consistent issue was the ball joint noise up front which was repaired under warranty in every case. Other than that ... no popping or crunching noises.[/QUOTE]
    Just to help other Stradale owners. What was the ball joint noise like??
