CS Reliability
Discussion in '360/430' started by CogitoErgoZoom, Apr 20, 2012.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. CogitoErgoZoom
    CogitoErgoZoom Formula Junior
    Apr 20, 2012
    520
    Caves of Altamira
    Marc
    Gents,
    After going through DiscoInferno's slightly frightening thread about his ongoing experience using his F430 as a daily driver, and the various electrical gremlins and problems he has had getting the vehicle serviced properly, it set me wondering about how the CS has generally been in terms of reliability.
    Can current and pas CS owners comment on what their experiences have been like in terms of reliability?
    I will be living and operating the car in the central Texas area and don't want to be facing the same issues he's gone through. While it would be a stretch to say I'll be using the car as a daily driver, I do expect a certain reasonable amount of quality / reliability out of a modern car. And while I have the means to acquire the car, I also don't want to be spending an additional 15-20% on repairs out of the gate.
    Your perspectives would be much appreciated.
  2. jason1st
    jason1st F1 Veteran
    Mar 25, 2004
    5,637
    ATL/CHS/MIA
    Jason
    I've had mine for just over 1.5 years and drive it regularly. I've had zero problems.
  3. Scuderia Scappaticci
    Scuderia Scappaticci Formula Junior
    Sep 21, 2006
    357
    Michigan
    NS
    Had mine 3years no issues. Just tires and regular maintenance and did I mention tires.
  4. Licht
    Licht Karting
    Aug 2, 2009
    67
    Dallas TX
    Driven mine in Texas for 2 years, 5000+ miles, no issues at all
  5. Mike Law
    Mike Law Formula 3
    2,013
    Netherlands
    Maikel
    I don't drive much in my CS, 6000 km's in 1.5 years. I've had a few problems sofar.
    1) power steering oil hose broke, oil on the belt so had to replace the belt (1 year old)
    2) cable in the drivers door had to be replaced, the door wouldn't open anymore
    3) exhaust mount broke off twice, easy fix
  6. Michael B
    Michael B F1 Rookie
    Silver Subscribed Owner
    Apr 28, 2004
    3,379
    US of A
    Michael
    #6 Michael B, Apr 20, 2012
    I just rolled over 1000 miles in the last two weeks... Driving it daily.
    Why the heck not? Its not made of glass. Buy-Drive-Enjoy.
  7. Tired of seeing this ad? Upgrade now
  8. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,258
    Site of US F1 Race!
    frenchie
    #7 Jagbuff, Apr 20, 2012
    ..almost too reliable, have runout of things to fix! I use it whenever I can, even when it's hot... BTW, it's got close to 42K miles and still runs very strong!
  9. Financialman
    Financialman Formula 3
    Sep 8, 2005
    1,834
    San Jose CA
    Dan Carpenter
    114, that is hot! I drive my ferrari alot as well, have almost 9k miles on my Scud now.
    It was 90 here in Silicon valley today, ac works great!
  10. 575Mike
    575Mike Formula 3
    Mar 11, 2004
    1,698
    Midwest
    Michael
    CS is a lemon.
  11. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,207
    25k miles or so, no issues, just the normal tires & belts. It does tend to scrape if you're not careful
  12. watt
    watt Formula 3
    Jun 17, 2004
    1,307
    Way Back In, NZ
    Giuseppe T Hemingway
    i put 24,000 miles on 9 strads, the most on one was 9600. no issues except if you get stuck in bad creep and go traffic in hot weather the over heating alarm for the gear box starts to sound off.
    a very reliable rig
  13. CogitoErgoZoom
    Apr 20, 2012
    520
    Caves of Altamira
    Marc
    Hear, hear. That's exactly what I'm planning to do!
  14. Tired of seeing this ad? Upgrade now
  15. maxer
    maxer Rookie
    Oct 19, 2010
    21
    Owned mine for a year and a half , 4000 miles of pure technology and emotion added to 7000 mi original
    CAN YOU SAY PERFECT !
    previous owner said "too nice to drive"
    My view " too nice not to drive"
    If you get a CS you will see yourself as lucky
  16. CogitoErgoZoom
    Apr 20, 2012
    520
    Caves of Altamira
    Marc
    Thanks guys for all the info. Sounds like the CS came out of the factory pretty well sorted then, which is reassuring. I think the key thing will be to find one that hasn't been sitting up for too long and likely facing a lot of issues after being put back on the road.
    I've started the search process already. Just need to find the right one.
  17. arizonaitalian
    arizonaitalian F1 Veteran
    Oct 29, 2010
    6,499
    Good luck with your search. If you haven't already, do a search of this forum for some invaluable threads on CSs...
    I've only had mine a little over 1 year and 2100 miles and its worked great. Only non-routine maint/service was a new battery and tender installation (I knew the battery was ready to be replaced from my PPI, so even that wasn't a surprise).
    Be sure to get a PPI and try to find the car's history when you find one.
  18. CogitoErgoZoom
    Apr 20, 2012
    520
    Caves of Altamira
    Marc
    Good advice, thanks. I've been mining the CS threads for info for several days already. I'm also looking at a few F430s, but I think I'm leaning significantly towards the CS at this point.
    I'll just have to be patient to find the right one and the PPI is a must.
  19. arizonaitalian
    Oct 29, 2010
    6,499
    Have you gotten the opportunity to drive both (430 and CS)?
  20. tubeguy
    tubeguy Formula 3
    May 21, 2003
    1,028
    Upland California
    Kevin Deal
    I had both and had no problems with my CS w/ 8k miles. Coming up 18k miles on my 430 and have to say I would trust it more than my CS. Main reason is the 430 clutch which I think will last longer.
    The other thing to consider is the front end on the CS is lower and with that it is not as relaxing to drive around town. The 430 gives more clearance and with that you get more "mistakes" before you have to pay.
  21. arizonaitalian
    Oct 29, 2010
    6,499
    So true! I remember when I first got the CS I was afraid to take it places I hadn't been before because I had visions of somehow getting trapped in parking lots with speed bumps blocking the way out! A friend flew into the airport and wanted me to pick her up in it...so of course I "test drove" the route the day before in my maser just to be sure I knew what bumps were there...I've gotten over my initial jitters thankfully...
  22. CogitoErgoZoom
    Apr 20, 2012
    520
    Caves of Altamira
    Marc
    Unfortunately not yet. Hope to remedy that soon though. From what I've read it does seem they have quite different personalities though, as similar as they are.
    thanks that's good insight on the front end height. why would the F430s clutch last longer though? Aren't the transmissions in the two cars basically the same? I would think the full auto mode available in the F430 would lead to more clutch wear.
    that would have been awkward! do you really think the front end height hinders the everyday usability of the car? mine's not exactly going to be a daily driver, but i do plan on using it regularly.
  23. arizonaitalian
    Oct 29, 2010
    6,499
    Yes, they are very different, that's why I asked. For me and for the "role" I want the car to fill in my garage, the CS or Scud were the only Ferrari's to fit the bill. The 430 is fantastic no doubt, but the CS is so very raw and loud and racy...you really do (of course) have to drive both to know what you want...
    Actually, the ride height is not the biggest thing that keeps the CS from being a daily driver (to me daily driver doesn't mean you drive it each day - rather it means you only drive "it" every day and you take it everywhere you go). So, "yes" the CS can be driven every day if you like. But, "no" I don't enjoy taking it for long freeway runs (too loud) or to run errands (a bunch of reasons, mostly parking related). I use the CS for "fun" drives and the occasional track day. I also take it out 2x per week just to go to lunch or whatever.
  24. CogitoErgoZoom
    Apr 20, 2012
    520
    Caves of Altamira
    Marc
    My usage would be pretty similar as to what you've described. When I say "daily driver" I basically mean a car you can use for all purposes with little punishment in the way of excessive noise, harsh ride, gas mileage, etc. In my mind, something like a current Porsche 911 Turbo can easily be used as your one-and-only primary vehicle if you really wanted to without too much worry about reliability and comfort issues. Could you say the same about a "standard" F430? I don't know, I don't have enough experience. Even if that is the case, I still don't see any Ferrari being my one and only vehicle.
    If I go the CS route what I'm basically looking for is the equivalent of a 4-wheeled version of my Ducati (please don't flame for that bit of sacrilege!), which is what a car like the CS seems like to me, but of course way more awesome. If that's the case I'll probably get a nice comfortable truck, SUV, or sedan to go along with it. While I won't use the CS as everyday transportation, I do want to use it like I use my bike: fun runs, day trips out to good B roads, the odd track day, etc.
    What I don't want is so something so fragile that I'm too worried to use it on a regular basis for fear of not being able to clear parking lot humps. :) It doesn't sound like I have much to worry about with the CS from the way you guys have described it though.
  25. Spdrcrj
    Spdrcrj Formula 3
    1,093
    Jim
    I think if you get a PPI and well sorted CS, you'll have piece of mind. I never got either with my Gallardo (I know, idiot) and always wondered about the condition of the car. Turns out, the clutch lasted 1k miles and was gone. My CS however, received a fresh major (that I got to watch the end of being performed), the tech ran through the entire SD3 system with me on the car and showed me a few past errors and that the car was running perfectly now, have the full service history on the car, and I bought from a dealer/had the car serviced by guys with fantastic reputations. Point is, I drive my car whenever it's sunny and dont have any of the trepidation I had with the gallardo.
  26. Jompen
    Jompen Formula Junior
    May 27, 2006
    709
    Had mine for four years. This year they noticed some small oil drops at the gearbox. A known problem on 360/CS. No oil on undertray but need to take apart the gearbox from 3rd to 6th. Alot of hours...
    Also front wisbones needs to be replaced due to they "rattle". Not common but heard of 430´s, 360´s with the same problem.
    Car has 10.000 miles on it and a few trackdays a year.
    Also brake discs needs to be replaced every second time you change pads. Pads lasts for years in normal use though.
    An amazing machine the CS
  27. arizonaitalian
    Oct 29, 2010
    6,499
    I think your "4 wheel ducati" analogy is the right one and the use you describe is right on. The CS fits that bill perfectly (for me anyways). I pair it with a Jeep for SUV type duty and parking at airports etc and with a GT/Spider for crusing with the GF on weekends or running to work, errands.
