CT: 348 fails emissions for gas cap? | FerrariChat
Discussion in 'New England' started by jlclt348, Aug 12, 2016.
  1. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    I took my 348 in for emissions testing prior to getting my CT registration. Car passed the smog, but failed gas cap because they didn't have a testing device of the correct size? Has anyone heard of this before? Thanks.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
    Out of interest why are they interested in testing the fuel tank cap and what sort of test are they doing ?As far as i know it is not done in uk
  3. itsablurr
    itsablurr Formula 3
    1,016
    Carlisle, MA
    Matt
    #3 itsablurr, Aug 12, 2016
    I'm not sure how an absence of proper equipment on their part should mandate a fail on your part. If i understand correctly, the intention of whatever test they're running is to verify that the cap seals adequately, in order to allow venting through the evaporative emissions equipment on the car (pressure/rollover valve, charcoal canister system). I'd say that the rush of air that follows unscrewing the cap after a short drive should be evidence enough of proper cap function and, barring the presence of their 'test equipment', give me the damn sticker. As far as the evap system goes, I don't think I've ever heard of an actual test routine, rather just a visual presence check if anything at all.
  4. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    #4 fastradio, Aug 12, 2016
    Yes, of course. Here's the requirement.
    Gas Cap Pressure Leak Test « CT Emissions
    So..either the car has a non-standard cap or the station does not have the correct adapter. My advice would be to go to another station that is more "Ferrari-friendly"
  5. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,782
    Weston, MA
    Paul
    So is Miller the shop that failed you?
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    I have the same problem with my 355. No adapter. But they pass it anyway.
  7. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    No, this was a local shop in New Milford CT, next to Auto Tourismo. I'll try again at another shop. Taking a car to Miller is a major time commitment for me - always the last resort.
  8. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    OK, so there is an adapter - that's good to know. The tech was young and I don't think he 100% knew what he was doing. I think I can still register the car with the fail on it.
  9. jlclt348
    jlclt348 Karting
    Jul 7, 2013
    209
    Ridgefield, CT
    Justin
    Fyi... I was able to get a permanent plate even with the failed gas cap.
