CTEK Battery Tender | FerrariChat
CTEK Battery Tender
Discussion in 'California(Portofino)/Roma(Amalfi)' started by JasTex, Nov 20, 2016.
  1. JasTex
    JasTex Karting
    Feb 21, 2016
    104
    DFW Area
    Jason
    Does anyone know where I can order a new CTEK tender for my CaliT with the round magnetic adapter? Need quick delivery....am in the U.S.
    Thanks a mil....
  2. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Have you tried Boardwalk? When I needed a tender for my Porsche, got it at the dealer. Likely not the cheapest option, but I had it in my hands within hours as they had them in stock. BF is open all week except Thanksgiving...T
  3. Alden
    Alden F1 Rookie
    3,604
    Central Florida
    If it is like the other CTEK/Ferrari chargers, the connector is proprietary, only available from Ferrari, or maybe from the original connector manufacturer if you can find out who that is.
    Search a bit here for more info, but I think I remember some folks being displeased with the magnetic connector, don't remember the reason(s.)
    If you want a Ferrari/CTEK that will connect direct to your battery with quick disconnect fittings, shoot me a PM, I can make whatever you need. I have done a lot of these for owners. I have OEM Ferrari chargers in stock for immediate modification and delivery.
    Alden
  4. ahmadof
    ahmadof Rookie
    Mar 27, 2011
    18
    I would go with what Alden is suggesting. I got an adapter for cteck to cali plug in the trunk. That way you can use any cteck charger (avail even at Home Depot) and it uses the oem socket , so you have warning on dash not to drive off, etc.
  5. JasTex
    JasTex Karting
    Feb 21, 2016
    104
    DFW Area
    Jason
    Thanks a lot guys. I. Will give Boardwalk a call in the morning. Failing that I'll PM you Alden. Thanks again.
  6. good2go
    good2go Formula Junior
    Feb 9, 2016
    939
    I tried to buy one. No luck. I found an adapter in UK.
    You might need to order original Ferrari charger.
  7. good2go
    Feb 9, 2016
    939
    I connect my battery tender every time I park. Its fast and easy with this magnetic external connector. If you have a cali that takes the external connector, buy one.
  8. good2go
    Feb 9, 2016
    939
    Is this he round magnetic connect that connects under the trunk lip? Do you have adpters for CTEK or the Original Ferrari battery tender?
  9. Alden
    Alden F1 Rookie
    3,604
    Central Florida
    IIRC, some folks said the magnetic connector was easy to knock off, especially when using a car cover. Thread out there somewhere about the magnetic connector.
    Sent from my VS986 using Tapatalk
  10. Mojosan
    Mojosan Formula 3
    Jan 31, 2008
    1,005
    NJ
    Not terribly relevant...but a Bentley CTEK charger works on Ferrari and vice versa.
  11. Alden
    Alden F1 Rookie
    3,604
    Central Florida
    I pretty much make whatever you need. I have original Ferrari chargers in stock and also CTEK chargers, adapters and other stuff.
    I do not have the round magnetic connectors, but if you have one, I can adapt it to a new CTEK or an original Ferrari charger.
    Shoot me a PM and we can talk. I have made some pretty esoteric stuff for owners, it is only limited by your imagination and (sometimes) parts availability.
    Alden
  12. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,832
    Dallas Texas
    If you know you know
    When you call in , be sure to mention you are a Ferrari Chat / Ferrari Club member to get your discounted pricing!
    PM me if you need me,
    Steve
  13. James cln
    James cln Formula Junior
    Dec 20, 2015
    289
    San Antonio
    James cline
    Go to eBay -
  14. JasTex
    JasTex Karting
    Feb 21, 2016
    104
    DFW Area
    Jason
    Boardwalk came through for me. They had one....
    So my baby's back on life support with her umbilical cord attached providing her all the juice she needs.
    Thanks guys, appreciate the inputs.
  15. tomc
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Nothing worse than a Cali low on juice!
    T
  16. Alden
    Alden F1 Rookie
    3,604
    Central Florida
    Can you tell me where you found the Cali adapter in the UK?
    Alden
  17. good2go
    Feb 9, 2016
    939
    It was on ebay but only UK listed.
