430 - Curiosity question - clutch & Quickjack | FerrariChat
430 Curiosity question - clutch & Quickjack
Discussion in '360/430' started by Marcoboxer, May 18, 2021.
  1. Marcoboxer
    Marcoboxer Formula Junior
    293
    Alpharetta, GA
    Mark Roberts
    Has anyone ever attempted a F430 clutch on a quickjack? I’m feeling adventurous....or is it stupid?
    Any thoughts on this?
    Whatever you are driving, I hope everyone has their top down and is enjoying summer.
    M
  2. akagan
    akagan Rookie
    Aug 13, 2014
    16
    Oakland, CA
    Avi Kagan
    Marcoboxer likes this.
  3. Marcoboxer
    293
    Alpharetta, GA
    Mark Roberts
    You are my new hero, doing a Scud clutch job on axle stands. Anything I should consider, or am I best just getting in there? It doesn’t seem to be an overly difficult job, notwithstanding any F1 related/hydraulic issues.
  4. Rifledriver
    36,952
    Removing the gearbox to do the clutch?
    Thats a new one.
  5. akagan
    akagan Rookie
    Aug 13, 2014
    16
    Oakland, CA
    Avi Kagan
    Nothing too complicated really. Getting the bolt behind the oil tank was painful, so I also removed the oil tank. I'm sure you don't have to, but I took the chance to clean it up while I was in there. A couple of the bolts holding the upper engine brace thing were difficult to get to with the air injection system on the Scud, but maybe not so bad with a normal 430.
    Gearbox wasn't removed per say, as much as it was dropped and turned to gain access to everything. Not sure how else you would get to the clutch...
  6. Rifledriver
    36,952
    Most of it doesn't need to be disconnected. Unbolt from the engine and the half shafts. Slide it back about 4 inches and remove clutch and flywheel and replace throw out bearing. I do not disconnect oil hoses, oil tank or F1 system.
    You work too hard.
    brogenville and Marcoboxer like this.
  7. akagan
    akagan Rookie
    Aug 13, 2014
    16
    Oakland, CA
    Avi Kagan
    Yeah, maybe! I did want to take the chance to detail and clean a bunch of stuff, and like I said with the oil tank, don't need to take it out, but access isn't great with it on.
  8. Rifledriver
    36,952
    I have done this job 100 times. Oil tank is not in the way.
