Curious about certain costs... | Page 5 | FerrariChat
Discussion in '348/355' started by Shootfighter65, Jan 28, 2015.
  1. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Not every owner has disposable income
  2. DavidLMcAfee
    DavidLMcAfee Formula Junior
    Nov 22, 2015
    355
    East TN
    David McAfee
    Estimate I recieved from a local independent shop was "under" $3,500. That was for the timing belt only. Water pump, bearings, etc. would add to that.
  3. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,652
    Southlake, TX
    Rob Lay
    I don't understand that math parts plus removing engine. that's how much it USE to cost for 328 major and no engine removal required.
  4. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    super price for an engine out service....even adding hills bearings, oem tensioners & water pump (if needed) still makes for a very reasonable basic service.
  5. mwhitesell
    mwhitesell Formula 3
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    I just paid close to 9k for my 355's 4th major. This included all the fluids, belts, tensioners, water pump, full 30k kit, and about 800 in random sensors bolts and electrical connectors. 6 of this was labor and the rest parts.
  6. rob lay
    Dec 1, 2000
    64,652
    Southlake, TX
    Rob Lay
    sounds dead on with major I just completed with Norwoods.
  7. GerryD
    GerryD Formula 3
    May 5, 2010
    2,448
    North of TO
    Guido
    Thats 27 hours and I have seen it done many times. You should drop by Daytona sometime Mike. Actually try to come by for the grand opening of their new place or should I say palace later in the year. You will be amazed, believe me.
  8. rob lay
    Dec 1, 2000
    64,652
    Southlake, TX
    Rob Lay
    is there book hours with Ferrari and authorized dealers or can they vary?
  9. GerryD
    GerryD Formula 3
    May 5, 2010
    2,448
    North of TO
    Guido
    There are book hours. Ive seen the book and it has the hours for every single job you could imagine. Cant remember the hours for a 355 engine out service. Just watched a 355 challenge engine done in no time...no corners cut.
  10. vinny84
    vinny84 Formula Junior
    Nov 20, 2008
    379
    PA
    Vince
    Agree 100%. These are very special cars which require special attention.
    This is also true, as I do not have a large amount for disposable income. However, I just have an understanding with myself that anything that needs done with my 348 just needs to be done, no exceptions and certainly no shortcuts.
  11. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    I've been to Daytona. Alex is terrific.
    When is the grand opening of the new place and where?
  12. GerryD
    GerryD Formula 3
    May 5, 2010
    2,448
    North of TO
    Guido
    Probably late next spring or summer. Depends on the weather right now. It won't be too far from FoO.
  13. GTO Joe
    GTO Joe Formula 3
    1,003
    Charlotte, NC
    Joseph Troutwine
    I think the $3,500 figure was a base labor number without parts. When I had mine done two really good Indys quoted me round numbers of $4,000 for labor and $2,000 for parts plus any "while you are in there" costs. Total out the door for me was $7,100 after a few minor "additional" items.
  14. rob lay
    Dec 1, 2000
    64,652
    Southlake, TX
    Rob Lay
    $7,000 to me sounds reasonable for some independent shops. Norwoods Auto Italia has unbelievable reputation 2 of the best independent Ferrari techs in world and they have a waiting list, so the demand is there for them to get $130 an hour.
  15. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    B.S. Show me the book hours for swapping headers on a 355 engine while the engine is out. I imagine there isn't one. At $200 an hour (I'm using a high hourly rate it most likely was less) they changed him for 3 1/2 hours for a 1 1/2 hour job at max. I understand dealer billing. If it shows a job is billed for 10 hours the idea is to bill for 10 and get it done in 8. But making up a 3 1/2 hour bill for a 1 1/2 hour job is different
  16. rob lay
    Dec 1, 2000
    64,652
    Southlake, TX
    Rob Lay
    I'm not saying it is right or that's what everyone does, but it is a reality with automotive service. Ferraris at dealers or independents are less likely to always work off book, but they do for many things and other makes do it almost 100% of the time. Many good techs I've known got paid for 50-60 hours a week book when working 40 hours.
  17. plugzit
    plugzit F1 Veteran
    7,816
    Redondo Beach, CA
    Bruce Bogart
    1 1/2 hours may be realistic if you assume the engine is out. And all 20 bolts and nuts are in new condition, and none of the studs come out with the nut. And the motor is sitting on the stand in such a way that you can access all the nuts from underneath with just a universal jointed socket. And you use power tools to take off and install each of the 20 nuts and bolts (that ok with you?). And you have all the tools sitting out. And the parts being installed, including the 8 exhaust gaskets and 2 donuts are sitting out. And all parts, including the area around and near the exhaust flange are clean. And when you reinstall the cats, they are perfectly clocked to accept the muffler when you reinstall that.
    Lessee, you've got 90 minutes from start to finish. 20 nuts off. Old headers off. 8 gaskets off. 8 new ones on. 2 new donuts on. New headers on. 20 nuts on. 60 functions. 90 seconds for each, including the time to make up tools. Yeah, that's realistic.
  18. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    What planet are you from. I've done my headers in the car I've also looked at engines out of the car. I could do it in a hour and a half without everything laid out the way you describe. Headers still in the box. Who connects the cats to the headers with the engine out? The bottom nuts are easy and the top wouldn't be bad at all with the engine out. Don't forget how hard those doughnut gaskets are. (Rolling eyes ) Sounds like you have never done it. If you have your not good at it and if you haven't you shouldn't be telling people that have how it goes. Awe never mind when your talking to the guy that's always the smartest person in the room facts and reason never applies
  19. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    Back off. You are talking to a guy that has 4 Ferraris, does 10 major engine outs a year all on his back, breathes Ferrari knowledge out of his nostrils, and good enough to lend a hand with his free advice. So, if Bruce tells you it takes 1 1/2 hours, then it takes 1 1/2 hours.
    Bruce is our resident Stooge number 1. It does not come more prestigious than that.
  20. yelcab
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    Here is my real life experience. I just finished some work on a car that had a major service right before the sale by a shop, and a PPI done by another independent mechanic. The new owner asked me to change the muffler. I put it on the lift and it snowballed into a lot more. Here is what I found:
    Death rattle caused by Kluber grease has totally leaked out of the flywheel assembly.
    Two dead engine mounts.
    One cat converter totally rodded out.
    One leaking oil hose at the oil tank.
    Two heater hoses missing, not connected, not there. One pipe is missing. Probably broke during removal and bypassed instead of replaced.
    Leaking valve cover gasket oozing with black silicon, and still leaking.
    One loud thunk from rear suspension because the bushing is totally pulled out.
    One cracked and leaking radiator
    AC compressor replaced but bolts and nuts are loose.
    And sub frame at the left upper A-arm totally cracked through.
    The steering rack boot leaks, and is broken.
    On the good side, the valve covers were repainted wrinkled red.
    The service bill clearly states the Water pump S hose was replaced. But, it is not there.
    I don't know how much that service cost, but whatever it was, it was not worth it. Many corners were cut to lower the price, perhaps?
    I am also incredulous that the PPI mechanic did not spot any of those issues.
    You are only as good as your mechanic. Good ones cost more than bad ones. It is the reason I do all my own work.
  21. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Learn to read. I said it takes an hour and a half. He was the one justifying 3 hours or more. Who are you his nanny? You think he can't answer himself so your off to rescue your princess? Motor out sitting on a stand it doesn't take 3 -5 hours to swap headers. Not even for a one armed blind monkey. Incumbent by ingents I press on with my life
  22. yelcab
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    It would if you have to enlarge one of the holes to make it fit. And muscle the bad fitting after market headers to fit the geometry. Please press on with your life.
  23. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    What does that have to do with charging someone 3-5 hours to swap headers with the engine out of the car? Some shops have charged 6 hours with the engine in. WTF? Like I said your posts are all over. If you have a 355 engine on a stand and can't swap headers in 1-2 hours You have other issues.
  24. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    Yes make up some circumstances to justify your post. Your right and if aliens interrupted the mechanic then that adds to the process .....now your making stuff up. Don't go away mad. Just go away.
  25. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
