Current exhaust manifold and exhaust box wisdom | FerrariChat
Discussion in '206/246' started by Mark Shannon, Nov 14, 2017.
  1. Mark Shannon
    Mark Shannon Formula 3
    1,237
    Surrey, UK
    I have to replace both the manifolds on my UK E Series and maybe the box as well.
    Please recount your experiences of the various different suppliers, problems with fitting, noise etc.
    Mark
  2. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,331
    Iain
    Mark,
    Carrs in Exeter had a local exhaust fabricator make up a complete new stainless system front to back for me using my original Ansa system for a pattern. It looks very close in terms of appearance and sounds almost identical. It cost significantly less and bolts straight on with no issues I believe. I've had this system fitted to all my Dinos. Give Mark Ware a call there for pricing as it around 3 years since I had my last one fitted. A couple of fellow Dino owners who use Carrs also had this system fitted and are more than pleased with it. All you need to finish it off is a set of Ansa stickers from Parker Hall in the US and some red tape.
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    I recently fitted stainless steel headers from Superformance on a late 246GT. The quality of the headers was just ok. All of the bends on the header pipes were done on a old time non-mandrel type tubing bender, so instead of having a nice curve with a round profile, the tubing necks down to an oval profile where it was bent. Also on the outlet of the headers there is no inner pipe stub as original to locate the crush/sealing ring, so you have to use a solid steel ring between the headers and muffler. The quality of the welding was very good on the header, and the cylinder head flanges were machined after welding, so they were nice and flat. The header fit well and mated up nicely to an Ansa muffler. The mounts for the head shields also did not match the originals. I don't know what the cost of the system from Carrs is, so it might make sense to compare the two.
  4. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,331
    Iain
    The system from Carrs was a good saving over the Superformance version from memory.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    Well, from the photos the Carrs headers appear to be much closer to the originals. Nice smooth bends, nice stand-offs for the heat shields and the correct little stub on the outlet to support the crush seal ring. If they fit well and are cheaper than the Superformance, then that is the system that I would purchase.
