360 - Current Major Pricing | FerrariChat
360 Current Major Pricing
Discussion in '360/430' started by rotaryrocket7, Jul 18, 2025 at 8:18 AM.
  1. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    626
    Eden Prairie, MN
    Matt
    In Midwest, having a major done at the Ferrari dealership. Quoted $18.5k for the major service - 55 hours
    First time having to pay for the major (I've done belts myself in the past) - leaking camshaft seal and I didn't want to mess with the motor.
    From history around here I always thought a major was around $8k. I'm sure I'm missing something, but what are the going rates that others are seeing?
  2. CoreyNJ
    CoreyNJ Formula 3
    2,440
    New Jersey Shore
    Dealer rate vs Independent????
  3. mvaldezf60
    mvaldezf60 Karting
    Feb 16, 2009
    210
    California
    Just had a major done this week, but am in CA. Pricing came out to just under $11K. Included, belts, tensioners, new water pump, engine mounts, all fluids changed, spark plugs but they also had to service transmission. Ill post more specifics later if you want.
  4. NelloWafer
    NelloWafer Rookie
    Feb 17, 2025
    1
    Tom Riddle
    NYC area - dealer pricing for a major on my 360 this spring:
    replace the 360’s engine oil, filter, coolant antifreeze, brake fluid, gear oil, steering oil, engine air filter, cabin pollen filter, timing belt, accessory belts, pulleys, tensioners, cam seals, & spark plugs.
    $18,995
  5. Scottrx7tt
    Scottrx7tt Karting
    Oct 5, 2023
    230
    Lenoir City, TN
    Scott Williams
    That’s just nuts. 55 hours? That is full engine rebuild pricing. 90% of the time it’s a leaky valve cover and not cam seals. I’d use an independent shop. I’d just do it myself if it were me. These care are extremely easy to work on.
  6. Flyingbrick242
    Flyingbrick242 Formula Junior
    675
    Northern AZ.
    If I were you I would get a second opinion, this does NOT sound right..that quote is outrageous.!
  7. priericky128
    priericky128 Formula Junior
    677
    St. Louis MO
    Rick
    If you have it, the detail would help a lot. I’m sure you could spend 55 hours doing work on a 25 year old car, but what are they doing in that 55 hours and is it what you want them to do?
    I saw a quote once for an engine out belt service on a 360, and it was not a poorly maintained car.
