Custom chip tuning at Competizione for the 3.4 liter engine: results. | FerrariChat
Discussion in '348/355' started by WilyB, Feb 9, 2008.
  1. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    #1 WilyB, Feb 9, 2008
    Richard and Fernando at Competizione in Gaithersburg found a sorcerer in Italy that knows in-depth how to program the MOTRONIC’s EPROMs.
    My goal was to get rid of the big dip at mid rpm (4000 to 6000) that the K&N, test pipes and Stebro exhaust had created on my otherwise stock Mondial T.
    http://www.ferrarichat.com/forum/showthread.php?t=180285
    Well, the new chip offered exactly what I wanted (I wonder if I should have asked like 500hp? :D).
    Torque at the hub is up from 212.4 to 219.0, but, much more important, the max torque rpm is down from 5800 to 4200!
    The Mondial’s drivability is now the same as before the intake/exhaust modifications, just with about +5 to 6% power/torque across the whole rpm range. If one admits a 15% power loss through the transmission, the car now makes about 315hp and 252 lb/ft at the crank, which is about how the car feels. I may be a bit spoiled, as my daily driver has 460 lb/ft… ;) I also noticed the car revs much higher than before: I lifted the pedal at 8000… I have to ask Fernando about the new limit?
    In short: a great improvement, custom tuned to my car. I am very happy and I would recommend you to call Competizione about their custom tuning.
    PS1: The AFR is taken at the exhaust. In real life, it converts to 0.5 lower numbers.
    PS2: Three lowest graphs were the baseline runs with the K&N and Stebro, but not tuned. The two mid graphs were made last night, in a high CO2 content atmosphere. The light blue graph was this morning.
  2. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    this is awesome! I can't wait to get mine done. Can you PM me the price? I need to start saving....
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  4. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    That is fantastic :)!!!!!!!
  5. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    I took the Mondial out tonight. Wow. It's really like the old one "plus".
    I wonder what it will do on the 1/4 mile? Low 14 or high13s? The engine really wakes up past 4000 and scream all the way to 8000.
    My daily driver, a 335 with a piggy back, does the 1/4 mile in the low 13s/107mph, but I get no traction from 0 to 30 due to the lack of LSD.
  6. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,763
    US of A
    Michael
    I have seen the best of a 13.8 in my Mondi T coupe. I would bet you could rival that.
    http://www.youtube.com/watch?v=1maYzWhJ0k0
    Great post by the way. Nice work.
  7. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
  8. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    #8 WilyB, Feb 10, 2008
    Out of curiosity, I did measure the MAF resistance (PIN 1 & 6) and I got 384 Ω on the right one but 1050 Ω on the left one!!! Anyone ever seen that before?
    Other question: how to you remove the round black and aluminum cap to access the tuning screw? I tried to use some kind force (fingers) and prefer to ask before using some more brutal force, given the replacement cost!
  9. Ben348
    Ben348 Formula Junior
    Jan 1, 2008
    304
    NH the Netherlands
    Ben
    Wily,
    I too had a different reading on the left/right maf.
    I got the alu pluggs out by drilling a little hole in it and screwwing a left hand tap in it, but any screw wil do.
    Screw it in till it jams, and than pull it out. This requers a bit of force.
    Happy wrencing!
    Ben
    Holland
  10. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    Thanks! (and thanks to ND for his PM). But is not "1050 Ω" way out of whack?
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yes, 1050 ohms is far too lean to do any good at all, especially when it is such a different setting from the other side of your engine.
    Might have something to do with dirty pins. Think about cleaning the MAF cable pins.
  12. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    With compressed air or some electronic (computer) cleaning solutions?
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Liquids. Electrical contact cleaner spray and Stabilant 22a are your friends!
  14. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 Good advice!!! Especially when the ECU is depending on those voltages for A/F calculations.... :eek:
  15. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Is this a 2.5 or a 2.7? Is chip tuning available for the 2.5?
  16. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    Based on the advice from the brotherhood here, I got really physical with them and drilled them out. Was a pain in the a$$ but worked. You really can't hurt anything.
  17. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    Mine is a 2.5, but the very first Ferrari Competizione tried the new chips on was a 360. On the 360, the top end did not change much but the mid-range torque did improve noticeably. They saw several 2.5, 2.7 and later awaiting shipment.
    Best is to give them a call.
  18. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Cool, mine's a 2.5. Hoping Richard will come down to VIR for the VSCCA school in May. I can pick his brain then.
  19. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    I still measure 1050 Ω between pin 1 & 6 after a thorough cleaning with Electrical contact cleaning solution.
    Ferrari "offers" a new MAF for $1050. After I gave them the BOSCH remanufactured part # 0 986 280 110 Fernando had given me, they came up with a quote of $500 (no core needed).
    I ordered one from N_D’s link (thank you Sir) for $249.75 (minus the $66 core). I also ordered on eBay an almost identical SAAB 900’s MAF for $60 to play with.
  20. Ben348
    Jan 1, 2008
    304
    NH the Netherlands
    Ben
    why get a new one, just screw it back to 383Ohm`s....
    regards, Ben
  21. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    +1 ^What he said.^
    That's the reason for removing the cap, so that you have access to the screw.
  22. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    True, but if I screw up the Mondial would be out of commission until the new part arrives. As Fernando confirms the unit was properly set up at 383 Ohms when they did the major service a few months ago, it is possible that the unit went bad anyway.
    If the unit is good, that will give me an opportunity to try FerrariAds! :)
  23. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    I'm confused, how can you screw up? You just turn a screw. Have fernando turn the screw for you if you are paranoid :) I'd try that first before springing for another MAF.
  24. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Dude, dude, if you do not turn the screw how do u know the MAF is really broken?! Look, if u take the position that it is already screwed up, how can mess it up further?
    Case in point: after the intake plenum replacements, my left MAF went to 1020 Ohms while the right one was just fine at the 383 where I it last month. I started down the "My MAF is screwed" road and sought a replacement. 1989 Volvo 240 is the part I found BTW. BUT, I then figured screw it just adjust the resistence screw. Hey, guess what - it took a few turns but it is fine now. Who cares what when wrong? Those things get out of whack by a number of variables. Maybe something went thru the MAF to alter the resistence of the wires. Maybe you grounded it somehow. Maybe the wires just age and the resistence changes with the metal aging.
    Who cares?! It's fine and running now. After I ran the car for a bit, I checked and rechecked the MAF resistences and they are exactly where they are supposed to be.
    So, dude, go ahead and adjust them since they are already screwed anyway. :p :D :) ;)
  25. WilyB
    WilyB F1 Rookie
    4,283
    AZ
    So I can just drill the cap out of existence without fear of damaging something behind it?
