Cut Off Switch for 355 | FerrariChat
Discussion in '348/355' started by Dr. Wynter, Jul 26, 2013.
  1. Dr. Wynter
    Dr. Wynter Karting
    Apr 10, 2013
    136
    Michigan (and NYC)
    Kevin
    I have to leave my car unattended for a few weeks and I know there is a cut off switch for the battery some where under the hood where my battery tender is connected. Anyone have a photo of where the switch is exactly?
  2. Christian Sasfai
    Dec 31, 2012
    140
    Heath, Texas
    Christian Sasfai
    No photo, but mine is under the removable cover/panel (with the two large thumb screws) on the right side of the front trunk. It's a round knob marked "on" and "off" with an arrow (or arrows). You can't miss it once you pull the cover.
  3. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    #3 308 GTB, Jul 26, 2013
  4. Dr. Wynter
    Dr. Wynter Karting
    Apr 10, 2013
    136
    Michigan (and NYC)
    Kevin
    Thanks gents, I suspected that knob, but wasn't sure. Happy motoring!
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Don't forget then when you reconnect the battery you have to start the car and let it idle for 10 minutes or so to allow the ECU to relearn everything.
  6. 355azul
    355azul Rookie
    May 26, 2010
    49
    Austria
    Is that really necessary?
    I admit: I didn't do it. Didn't notice any problems.
  7. f355spider
    f355spider F1 World Champ
    18,055
    If you don't it may cause idling issues as it will need to re-establish the idle parameters...at least that is what the owner's manual states. Good ideal to read the manual, there is a lot of useful information in there. ;)
  8. Dr. Wynter
    Dr. Wynter Karting
    Apr 10, 2013
    136
    Michigan (and NYC)
    Kevin
    Thanks! Will do!
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    It is actually worse that this. After you reconnect the battery, you key the ignition on, and then wait at least 30 seconds for all of the electronics to find themselves again. If you don't you can mess up the servo motors that control the A/C-heater.
    Then start the car and let it idle until the radiator fans have cycled (off-on-off) at least 3 times.
  10. Shorn355
    Shorn355 F1 Veteran
    6,862
    Colorado
    Scott
    Pefectly stated process ^^^^ - Unfortunately no power where I store my cars so use the battery switches just about every time I put them away. Been following this process on the 355 for 2+ years and never an issue. Doing the exact same thing on the TR. FWIW I also always hit the AC compressor STOP button after the cars are shut off and before putting them away and then turn it back on after the car has idled and warmed. Maybe overkill but seems to work.
    Cheers!
  11. 355azul
    355azul Rookie
    May 26, 2010
    49
    Austria
