360 - Cutting Holes In My 360 Spider! | FerrariChat
360 Cutting Holes In My 360 Spider!
Discussion in '360/430' started by Aeron Fout, Sep 29, 2020.
  1. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    I have a early 2001 360 Spider without the fuel pump access panels in the convertible tub. I did not want to go through the hassle of removing the entire top system to access the pumps. After studying some pictures of 360’s with the tub removed and eyeballing the location of the access panels from google images, I got out my cutting tool and went at it. The entire process of cutting and replacing the pumps took about 45 minutes per side.
    My plan is to use the original cut out piece as the replacement cover. I’m making some small aluminum tabs to hold it in place, then using a bead of black sealant to fill the cutting gap.
    Hopefully this can help someone out. If anyone is interested, I’d be happy to provide the dimensions of where I cut my holes. Use this information at your own risk! Please don’t try this if you don’t have some mechanical skills and a steady hand. It’s a very close tolerance when cutting near the fuel line and wiring harness. Cutting holes in a Ferrari is not for the faint of heart!! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    CEDPEAR, Mimmo Blue, Gumart1 and 4 others like this.
  2. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,324
    Maryland
    Mark
    I've always been a DIY guy as much as possible (owed to dad, central iowa farm-boy/vietnam vet) and this makes me smile.
    Todd Laing and Aeron Fout like this.
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    so later models have a removable cover?
  4. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    Yes, I believe towards the end of 2001 is when they started building them with the access panels.
    Mimmo Blue likes this.
  5. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Great work !
    marknkidz and Aeron Fout like this.
  6. derekmines
    derekmines Formula Junior
    Dec 12, 2013
    284
    Melksham, UK
    Derek
    Yep, mine's an October 2001 and I have the access panels
    Aeron Fout likes this.
  7. hessank
    hessank Formula 3
    1,928
    Canada, Florida
    Fred
    BTW Aeron, you're not done with the 'maintenance ports'.
    If you've done that much you need should have included the Roll-over valve next to the pump and the other one a bid further down.
    They will also need changing at a later date so why not complete the mod.
    FCHAT picture
  8. Aeron Fout
    Aeron Fout Karting
    Nov 21, 2019
    88
    Cocoa Beach, FL
    flyadf
    I thought about drilling some extra holes and doing the rollover valves now, but they were on back order and I did not want to wait any longer. At least now I can look inside my fuel pump access holes and get exact measurements for the rollover valves when they arrive.
