CV Boot Replacement Show & Tell? | Page 3 | FerrariChat
Discussion in '348/355' started by WATSON, Feb 21, 2016.
  1. WATSON
    24,081
    WI
    I have about 6 hammers as well in different materials. I try not to use them as slips and dents and damage seem to follow for me :) But using the steel claw hammer made me cringe...and had no other option that made sense. It worked.
    From earlier in the thread:
    '79 Porsche 930 Boot on left, Aero boot on the right.
    Aero boot can be ordered from Pegasus - P/N 1474-108
    If you scroll up you can see pics i posted of the P-boot next to the Ferrari one. It is different at the mounting and the ID for the axle shaft is smaller.
  2. WATSON
    24,081
    WI
    233 miles this weekend. Just took a peek underneath. Bolts are tight and have not moved. Boots look great and no issues.
    Thanks to F-Chat, we had a great drive today. Awesome :)
  3. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,027
    PA
    Kevin
    I recall the axle nut torque spec to be closer to 203 lb-ft. I would be concerned if you cranked it to 300.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #54 Dave rocks, Apr 18, 2016
  5. ace51
    ace51 Karting
    Jun 30, 2008
    84
    NC
    #55 ace51, Apr 18, 2016
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Wait for it...............
  7. WATSON
    24,081
    WI
    I didn't have the balls to inspect my balls.
    I left my balls alone and simply washed & greased my balls up.
    hahaha
    So that's what that assembly looks like all torn down.
  8. WATSON
    24,081
    WI
    Hummm I read somewhere the torque was 250 ft/lbs. Regardless I am at that number now, not 300.
  9. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Really like the looks of the aero boot ... if the aero boots handle 5° of axle pivot, they should work ok .... as was mentioned the further away from the radiant heat source the better ... :)
    The SS Goth shields are shaped to physically block 'line of site' radiant heat from the un-shielded cats and nearby exhaust from getting to the CV boot .... the Goth shields are made from stainless, which has a low heat transmission rate, which is an additional reason they reduce heat exposure to the CV boot ... and ...... thermal tests were conducted which verified significant 'radiant heat' reduction to the CV boot .... :)
  10. phrogs
    phrogs F1 Veteran
    7,375
    Kzoo Michigan
    I just did this today, FYI my rear lower A-arm bolt and nut are 22 mm not 24 mm.
