Tried a 13 mm wrench .. too small ... tried a 14 mm wrench .. too big. I now assume the nuts holding on the half shaft to the gear box end are special .... any advice? Regards, Pete
Brian You're right they are torx bolts............... Image Unavailable, Please Login Image Unavailable, Please Login
A regular 12 pointed metric socket from a regular (non-impact) socket set will fit these bolts, but off the top of my head I can't remeber the size, I think it was 13mm or 14mm. You don't need anything "special". RF
