CV joint and drive seal replacement | FerrariChat
Discussion in '308/328' started by dino_bob, May 22, 2013.
  1. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    I am planning on servicing the CV joints and changing the drive seals. Although there are a lot of good information out there, I will probably have some more questions when I start working on it. But for the moment I wondered if anyone knows if I have to empty the gear oil when changing the drive seals?
  2. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    I recently did mine on my 77GTB and did not have to. Check Birdman's site for a great tutorial. Ferrari 308 Mondial parts and service
    Fastradio (here on FChat) has a great kit available for seals and boots. And he is a great counselor when you need a little reassurance...;)
    CC
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,208
    Austin, TX USA
    Greg
    I did my 77 GTB as well, a few years ago, and as I recall, no need to drain gearbox.
    Greg
  4. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    Great, thank you CC and Greg.
    I have already bought the boots and seals from ferrariparts.co.uk. But I need some CV grease, any recommendations?
    The Birdman tutorial has been studied, it has been much helpful.
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,208
    Austin, TX USA
    Greg
    Hmmm. my kit came with several tubes of CV grease. i would imagine an auto parts store would have something similar
    Greg
    Sent from my SGH-T989 using Tapatalk 2
  6. andy j
    andy j Rookie
    Apr 2, 2012
    20
    Doylestown, PA
  7. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    David's (Fastradio) kit was all inclusive so I didn't have to worry about sourcing it. Unfortunately I did not record what brand/specification it was.
    It is an easy repair - once you break all the bolts loose. Enjoy the bonding time.
  8. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
  9. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    Thanks. I have already got the Curil T and Permatex, been thinking about this job for a while.
    Andy: Feel free to post in this thread about your fix if you have questions or want to share anything else regarding the job.
    Since there is no special recommended CV grease, I will look around an see what I can find in the local shops.
    There is a special tool for the drive shaft seals:
    http://www.superformance.co.uk/parts/ST-03.jpg
    Have anyone used it? Whats the use for the bolt?
  10. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    #10 andyww, May 24, 2013
    This was my method of holding the output shafts while removing/replacing the bolt.
    Piece of ally with 2 holes drilled and bolt to the output shaft.
    I am not sure exactly how that seal tool would be used, presumably you insert the original bolt through it and tighten to press the seal in. Maybe the side bolt is to prevent it rotating in some way.
  11. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    Good idea Andy, I will have to measure the bolt distance and make a similar tool. Fixed the front brakes today, and took it for a drive. Smiled all the way, so I might put the CV joint fix on hold untill it starts raining again:)
  12. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,310
    Redlline CV2 is a good call for the CV grease if you havn't done it yet.
    The WS manual states 140g of grease per joint & its widely acknowledged to be wrong - it should be 100g (so you can get away with one tub of grease, which, for reasons known only unto Redline contains 397 g !!). You might well wonder how you get 100g in each joint when you start to put the stuff in, let alone 140!
    There was a good video about somewhere recently that exlained exactly how to re-assemble the CV joints & make sure you get everything the right way around. A lot of 1/2" drive extensions & a universal joint are what you need to get to the bolts . Make sure you have a good quality hex head bit & clean each bolt head out before you try & undo it to make sure the bit seats properly. If you round one o fthose things off it would be a PITA extraordinaire!
    For the clamps, the Oeticker ones work well & when put them on be sure to make sure you line up the crimped bit away from the bolt holes! invest in the proper tool to crimp them as well. Don't forget the washers on the inboard left side bolts.
    Its messy but not too difficult.
    Change any bolts that have suspect hex heads as well. Bolt length is critical so of you are replacing any make sure you get the right ones.
  13. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    My theory about the 140 grams is that unlike on many cars, there is no end cap over the outside ends of the CV joints. They are open and maybe the extra is in case grease migrates out into the void in the output shaft or hub. Could be just a wild guess though and probably is.
  14. Tifosi2011
    Tifosi2011 Formula Junior
    Apr 3, 2011
    307
    Burnaby, BC Canada
    Here is part one of two videos i made about our cv joints.
    Cv joint rebuild from a 1985 Ferrari 308 QV - YouTube
    Here is part wo
    [ame=http://www.youtube.com/watch?v=sjV9tH1MYao&feature=player_detailpage]PART 2 Cv joint rebuild from a 1985 Ferrari 308 QV - YouTube[/ame]
  15. thecarreaper
    thecarreaper F1 World Champ
    18,012
    Savannah
    308s use the same axles as the Porsche 911. Local axle shops here charge less than $450.00 to rebuild both with a 1 day turn time.
  16. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    Thanks for all the tips. I have now finally started on the job. Got the bolts of without any problems. Could not find PB Blaster here in Norway, so I used CRC Rost Flash spray.
    One of the joints is stuck on the axle, so I will probably try to press if off using a hydraulic press, but everything else is going as planned. I do have two questions though:
    Washers: There are no washers under any of the bolts (Birdmans tutorial mentions them on one of the sides), but the normal "half moon" is there. Is this normal for a 75 308 GT4?
    The axle where mounted with the ridges on the outer side (wheel side), not on the transaxle side as in Birdmans tutorial. Is this normal for a 75 308 Gt4 or should I flip it when I install it?
    Here the image from Birdmans tutorial:
    http://www.birdmanferrari.com/service/cv_joints/CV-service16.jpg
  17. DSTP
    DSTP Karting
    Apr 7, 2012
    134
    MD
    Dave
    Rebuilt mine over the winter: Inside Ribs and Washers, The washers are mostly there to take up length in the bolts (inside flange area, potential interference) be careful of the bearing cage & bearing installation there's a right way and a wrong way! Also make sure you replace the original circlips. Birdman's tutorial is helpful! Also was cool to see the Ferrari 308 GT4 stamp on the bearing hubs! And while you are there... if you haven't done these, go ahead a rebuild your shocks. I had a riser ring installed on the shocks - must have been one of those 70's thing, go figure.... who would raise the rear end on a Ferrari? Anyway have fun and godspeed!
  18. Steve Magnusson
    26,659
    #19 Steve Magnusson, Jul 8, 2013
    I'd guess that it is "normal" for a 1975 308 to have been originally assembled without them (since the 1976 308GT4 SPC shows no washers, while the 1979 308GT4 SPC does show the washers) -- i.e., it was a change that they added later in production when they realized just how crazy close the ends of the bolts were getting to the ends of the studs on some cars. Length tolerances for large bolts and studs, and the variation in the installed height of a stud are HUGE -- so it probably all looks good on the nominal design drawing, but some might be OK without the washer, while some might not (depending on how the tolerances stack-up together). Additionally, there was a significant design change to the 308 differential starting with gearbox SN 693 -- could be that the clearance was less of an issue with the early diff design, but somehow the nominal clearance got reduced in the redesign -- but just another guess.
    If the existing clearance on your 308 seems insane = add the washers.
    If the existing clearance is OK = your choice to add the washers or not (although another factor is to ensure that the bolt end extends some minimum distance past the nut).
  19. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,293
    Ventura, California
    Robert Garven
    Bob,
    I have #10766 no washers and one rib wheel side two ridges engine side. There is lots of good info in the post I added.
    Post some pics!
    Rob
  20. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    Thanks Robert. I am thinking about swapping them left/ right and put the ridges on the trans-axle side. After reading a lot of older post, I have found no specific reason that this should be problematic. Will try to take some photos.
  21. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    #22 dino_bob, Jul 12, 2013
    So I have now serviced the CV joints, and removed the old shaft seals. They were rock hard! Interesting how rubber can turn in to brittle plastic.
    The only problem now is that the DSC (differential seal carrier) wont come off. I will give it one more try.
    I do not have many pictures of the work (it is so messy so that I have avoided bringing the camera down to the garage), but here is one of the painted axles and one of the car it self.
  22. Steve Magnusson
    26,659
    Stimorolgum likes this.
  23. dino_bob
    dino_bob Karting
    Sep 27, 2012
    133
    Norway
    Robert
    Yes. I realized that I can leave it, but in Birdmans tutorial he does remove it so I thought I should give it a try. Good to know that others have skipped this, as it looks like it is stuck. I do not want to heat it up or use a lot of force.
  24. robertgarven
    Feb 24, 2002
    5,293
    Ventura, California
    Robert Garven
    I did not remove it. I think there are pictures at the CV joint thread I posted
