cv joint boot replacement | FerrariChat
Discussion in 'Technical Q&A' started by James lafevers, Apr 6, 2019.
  1. James lafevers
    Apr 6, 2019
    11
    Pitviper
    I need tutorial on how to remove cv joints and install new boots. Also, is it necessary to remove them or are the split boots that can be installed without removing half shaft ok to use. Thanks for help, pitviper
  2. absostone
    absostone F1 World Champ
    10,033
    Shafts must be removed
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    what car? Toyota camry?
  4. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
  5. ago car nut
    ago car nut F1 Veteran
    5,500
    Madison Ohio
    David A.
    You don't want to use split boot on any car that has value!
  6. James lafevers
    Apr 6, 2019
    11
    Pitviper
    Thank you for the reply and excellent tutorial.
