CV Joint Nut | FerrariChat
CV Joint Nut
Discussion in '308/328' started by skipgt4, Dec 27, 2022.
  1. skipgt4
    skipgt4 Formula Junior
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    This is more of a curiosity question. Having replaced the CV joints and boots I was wondering why the 308 uses “flex top” nuts on the CV joint bolts? Why not just use a good quality Nylon insert lock nut?
  2. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    My guess and it's only a guess is that the axles can get really hot and the nylon can soften and not hold.
    I have often wondered the same thing.
  3. skipgt4
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    that could be but a good quality Nyloc nut is good to 250 F. does it get hotter than that at the CV joint?
  4. BrockBenson
    BrockBenson Formula Junior
    Oct 18, 2018
    277
    Australia
    I don't believe CV joints get that hot. Maybe Nyloc's didn't exist in the early 80s? In fact, I can't ever remember seeing Nyloc nuts fitted to cars by any OEMs?
  5. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    741
    Omaha, NE area, US
    Steve
    Lotus was using nylon locknuts in the '60s.
  6. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    #6 moysiuan, Dec 27, 2022
    There are many nyloc nuts on the car, many in much hotter places than the CV nuts, I always wondered how they can withstand the heat. I can only presume the CV bolt torque is so high that it needed a stronger mechanical lock, I think they are very vibration resistant, the suspension movement must create alot of vibration.
  7. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    159
    My 1961 Lotus Elite uses an all mtal "Flex top" nut on its inner u-joint -- because there is an inboard brake disk sandwiched between. It uses nuts with lock washers most everywhere else.
    Mike Flanagan
  8. Steve Magnusson
    26,806
    Heat (both convective and radiant) from the (glowing ;)) exhaust manifold near the inboard CV joints probably played a role in their selecting an all metal locknut (rather then a Nylon insert locknut).
