Cylinder head washers stuck - any ideas to remove? | Page 3 | FerrariChat
Discussion in 'Mondial' started by freelapl, Aug 5, 2013.
  1. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    I was just thinking that now you have broken the seal, how about placing the engine inverted on just that head in a container of kerosene oil mix. This would get in behind the studs and soak from the outside in.
    I'm just thinking that although it has released it may bind up again and now the heads are further down the studs care must be taken with uneven loads on them. Although I'm sure your bloke knows what he is doing to get this far.
    I hope if I ever have to do mine they are not frozen on like this.
    All the best, Bell.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
    Thanks for the update.
  3. freelapl
    freelapl Karting
    May 8, 2006
    88
    Los Angeles, CA, USA
    Pete Freeland
    Yes I will be back over there at the end of the week and will take pics of the whole setup. I will also suggest the soaking in kerosene to see if that helps.
    He is definately being very cautious as far as applying even pressure as the head continues to travel up the threads. The goal is not to apply any lateral stress or pressure, and keep it even and equal as it goes up the threads. One positive aspect of this is that although we still have not attempted anything yet on the other head, at least at this point we have the tooling and the process identified to get it off and moving....my guess is that the other one will only take 4-5 weeks at the most to be removed.
  4. enzo360
    enzo360 F1 Veteran
    Aug 1, 2004
    5,439
    Belgium
    Jurgen Durand
    Pete,
    any more pictures on the plate? I'm in the same position with my engine and would like some more input on this.
    Best
    Jurgen
  5. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Not dissimilar to the issue with the Jaguar XK engine where the studs and head corrode together to create a difficult to breach unity. On those engines two techniques are used, one to remove the studs and the other to use brute force, either with hydraulic jacks between head and block, or lifting part of the car just by pulling on the cylinder head. All seem to work nicely.
  6. desparateaudio
    Sep 27, 2014
    3
    Hey Freelapl,
    Hope all went well with the final part of your head removal. I am about to undertake the same issue so I was wondering if you might provide a few pics of the head plate and some dimensions if at all possible?
    Thank you so much!
    Anthony
  7. desparateaudio
    Sep 27, 2014
    3
    Any updates on the plate with some pics? I'm about to do the same thing so any pics you can provide and maybe some dimensions would greatly be appreciated. Thx!
  8. desparateaudio
    Sep 27, 2014
    3
    Sorry all for double posting. Thought first one was missed.
