Cylinder Liners | Page 2 | FerrariChat
Cylinder Liners
Discussion in '308/328' started by MNExotics, May 22, 2012.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,339
    Edwardo
    Hey Joe,
    1985 QV liners installation procedure.
    1- clean liner o ring seat inside block.
    2- Lube o ring seat inside block with a thin film of engine oil.
    3- Carefully install new o ring onto liner. Note; don’t lube the o ring or the liner.
    4- push liner into block, don’t twist.
    5- Flip block upside- down. Note: On the head studs, use washers and pipe spacers to hold liners in place.
    6- Pour a glass of Enzo approved Diego-Red Wine. Good luck.
  2. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    581
    NYC
    Joe
    Thank you - Perfect level of detail. One other question...I had my liners re-plated and they were marked for each cylinder and marked top and bottom so they could be re-installed in the same bore with the same orientation...Needless to say, even though i asked for Millennium to preserve the markings, they were sent back without them - So I will install them wherever and I can't tell if there is a top or bottom (they look symmetrical) - Is this a problem? Am I missing anything? Again, thanks for your help on this - it appears from the threads I've read that you may have done this several times - Joe
    350HPMondial and miketuason like this.
  3. 350HPMondial
    5,339
    Edwardo
    Hey Joe ,?
    I would use my bore gauge to place the liners in order of loosest to tightest. then, I would use my calipers on each piston to do the same.
    Essentially,, matching all specifications for piston/liner clearance.
    good luck.
    Edwardo
    ferrariowner likes this.
  4. 85QVEuro
    Jan 15, 2021
    581
    NYC
    Joe
    Edwardo - thanks for the follow up on this
    350HPMondial likes this.
  5. 350HPMondial
    5,339
    Edwardo
    Joe,
    No problem on the free advice. ( your doing the hard part.)
    I appreciate your efforts to do a good job.
    ( smile)
  6. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Question for the group.
    If you purchased new cylinder liners, what would you use? Steel or try and resurface the old liners?
    Would you re-bored the liners with a torque plate to insure proper fit? I worry that worn liners may 'egg' shape even if replated.
    Thoughts?
  7. 85QVEuro
    Jan 15, 2021
    581
    NYC
    Joe
    Not sure if this helps (and I wouldn't pretend to know the situation for every used liner) but mine were checked for concentricity and lack of taper by the company that did the re-plating - all checked out perfect. In addition, when you have them re-plated, they can build the plating up to create a perfect piston to wall clearance
