Cylinder not firing | FerrariChat
Cylinder not firing
Discussion in '308/328' started by tobygaff, May 29, 2022.
  1. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    #1 tobygaff, May 29, 2022
    Hey guys. While I was out running the car yesterday I had a cylinder drop out. The car started idling bad and dying at stops. When I got it home, I put a thermal camera on it, and it was very obvious that cylinder 4 was not firing. I put a spark tester on it, and I have no spark at all. Even going to the block. As a troubleshooting measure, I replaced the spark plug wire. Still, no spark.
    I could see it maybe being a distributor cap, but I don’t want to just start throwing money at it until I have properly diagnosed. Any other ideas of things to try? What could cause no spark on a single cylinder?
    It is an 84 Euro GTS QV with the dual distributor setup.
    Appreciate any feedback
  2. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    Sorry…. 1984 GTS Euro QV. I guess that would help.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,807
    Cerritos, CA.
    Did you check the spark plug extender?
    robertcope likes this.
  4. Steve Magnusson
    26,776
    If you confirm that it isn't a wire, extender, spark plug problem (and the other three plugs in that bank are firing), another possibility is that the spark for that cylinder is wrongly jumping from the contact where the carbon button rides, thru the rotor plastic, and to the end of the distributor shaft. I think there was an FSB to address this. You can always just try swapping the dist rotors to see if there's any change (and give them a visual inspection while doing that).
    Post #1 in this thread has some good photos showing how a rotor was arcing from the metal contact on the top (where the carbon button rides) thru the plastic and onto the metal spring clip that contacts the flat on the distributor shaft:
    https://www.ferrarichat.com/forum/threads/have-you-lost-power-in-one-bank-of-cylinders.525461/#post-144754234
    And this thread:
    https://www.ferrarichat.com/forum/threads/ignition-problem-on-308-qv.642903/#post-147929536
    has additional photos and information.
    Saabguy, JuLiTrO and Dane like this.
  5. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    Thank you. I think that it may be a voltage/current problem. There is no spark at idle, but as I rev the engine it comes in. I am going to swap the extender to another cylinder to see. Is the spark normally weak at idle? I have also heard people talk about cleaning up the engine ground points. I am going to look for those tomorrow and do that as well.
    I appreciate your help.
  6. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    I did some more testing, and I definitely have a feeling it’s a voltage issue. It only has 12.5 volts at idle, however it may be because it is now idling at 700-800 rpm’s. It used to idle at 1200. This changed all of a sudden while I was driving it. What would cause my idle to go from 1200 down to 800? Vacuum leak? I have looked all over and I can’t find any. Air control valve? Is there a common place where vacuum leaks happen on these cars?
    Could it possibly be just an alternator?
  7. miketuason
    Feb 24, 2006
    15,807
    Cerritos, CA.
    Vacuum leak will actually raise the idle, have you tried switching the dist. cap and see if the problem switch over to the other bank?
    mike996 likes this.
  8. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    I have not tried that. The back one is pretty hard to get to. Didn’t want to introduce new problems
  9. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    California SF bay area
    Paul
    I think that would just be the result of the loss of spark on the #4 cylinder. You know it could be the spark plug, have you tried swapping it out?
  10. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    I swapped the plug and it didn’t make any difference. Things actually seem to be getting worse. It will not idle right now. I am going to try to figure out how to check the fuel pressure. I want to see what that looks like. I am really getting frustrated.
  11. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Yes. A buddy had the same issue and his regulator was weak. After chasing a whole lot of parts on his QV, he replaced the regulator and all was fine.
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    With your symptoms and the fact that you checked the plug and the plug wire/extender, a carbon-tracked distributer cap is where I'd be looking first. If there is good spark on other cylinders in the same bank, it is not likely to be a coil or engine ground issue. Also, if there is good spark on other cylinders it is not likely to be a low voltage or alternator/regulator issue. It is most likely a secondary ignition issue affecting the particular cylinder.
    Check the resistance of the faulty cylinder's plug wire + extender with a multimeter. There can be dramatic differences in resistance depending on the type of cable but standard ignition cables - NOT solid copper wires - will show considerable resistance. Around 5000 Ohms per foot of cable is quite common though it may be much lower, again, depending on the type of cable. Check several cables to see if any are dramatically different, again, remembering that unless they are solid copper, the resistance will change based on cable length.
    Do the old shade tree ignition test... After dark, open the hood, start the engine and observe for any visible sparking. If none, using a spray bottle with some tap water in it, spritz some water on the secondary ignition components - coils, dist caps, wires and again look for sparks. Sometimes it is quite a light show! With these engines you can't get a "complete" spark test because you can't see the portion of wire/extender/spark plug. But this test is surprisingly effective at finding secondary sparks "leaking" from the system.
  13. tuttebenne
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Good suggestions overall. I would agree that a single bad cylinder would not be indicative of an alternator issue but under 14v output is. It is very easy to confuse a dead cylinder with a poor overall spark that is bad at this cylinder and then bad at another next time you try to diagnose. This feature comes with Dinoplex at no additional charge.
  14. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    Thanks guys. The spark is very weak on all cylinders AT IDLE. As I slightly rev the engine, it is slow to respond, but when it does the spark comes on hot. For some reason that single cylinder does not like the weak spark, but as it revs it starts firing and the cylinder comes to life. At idle I can barely see the spark tester flicker. This is why I thought maybe it is a voltage or current issue.
    I think if I could get a full spark at idle I would be all set
    How about a throttle position sensor? Do these cars have a TPS that could be faulty and affecting things?
  15. Steve Magnusson
    26,776
    No (not on a euro QV), but one easy thing to do is swap the connectors on the two Digiplex ignition ECUs to see if the "problem" stays on the same bank, or not. Same idea with swapping the coils. Have you had a look inside the distributor cap of the bank with the trouble to see if there is something obviously wacky inside?
  16. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    I did. It looked ok, but I ordered a new one just to be sure.
  17. tuttebenne
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Change your voltage regulator.
  18. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    Here is a video of what I am seeing. Spark is weak until I rev it, then it comes in. Trying to decide if that is the cause of the problem or a symptom of it.
    https://drive.google.com/file/d/15Jl0WVGwAR5dijygIcyQc6X4R_eUIQf4
    I ordered a few parts to troubleshoot too.
    Dist Cap
    Rotor
    Extenders
    Voltage regulator - does the alternator have to come out for this or can this be swapped in the car?
  19. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    I understood initially that there was poor spark at ONE cylinder at idle. If there is poor spark on ALL cylinders at idle then I agree that it could be a low voltage issue as opposed to a secondary ignition issue. Low voltage at the coils could be a result of some poor/corroded connections as opposed to faulty components.
    If you have sufficient power to spin the starter, there is plenty of power to run the engine. Once started, most cars can run for quite a long time on battery power only (no charging output from alternator) as long as other electrical items - lights, etc are off/not drawing power. In any case, check the voltage at the battery with a multimeter with the engine running and the RPM around 1000 (normal idle speed at operating temp). I would expect to see at least 13 VDC.
    REMEMBER that these cars may not engage the charging system on startup until the RPM has hit around 1800-2000RPM. So it may be necessary to blip the throttle after startup to "activate" the charging system.
    ragtop1 likes this.
  20. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    I see this weak spark on all cylinders, however it seems to affect cylinder 4 the worst. Cylinder 4 has the same weak spark but does not fire at idle (seen from thermal imaging) but it does fire once you rev a little.
    It is difficult to diagnose because the engine won’t run smoothly because of that misfire. It causes very rough idle. After about 30 seconds the car then dies and is difficult to restart. I believe the air control valve could be suspect but not sure how to test it.
    The battery voltage is 12.5-12.7. I don’t think I have ever seen over 13.
  21. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    "The battery voltage is 12.5-12.7. I don’t think I have ever seen over 13."
    Is that with the engine running or engine off? If running, and after the throttle is blipped to activate the charging circuit/turn off the red battery light on the dash, you should see more than 13V at normal idle and up to 15 volts as the RPM rises. If you don't, there is a charging problem either a regulator, alternator, or connection issue. With ignition off, a fully charged battery will stabilize at around 12.6V so 12.5-12.7 is fine.
  22. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    What is there on the car that kicks in after 20-30 seconds of starting? The car idles rough at startup but runs. After running for 20-30 seconds, something kicks in and it dies. Is this the air control valve closing?
  23. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    If it's happening around 20-30 seconds, my guess would be the warm-up enrichment is deactivating. There is also cold-start enrichment but that typically lasts less than 5-10 seconds. Idle stabilization (through the aux-air valve) typically lasts 30-60 seconds. Both warm-up enrichment and idle stabilization times depend on ambient temperature so these numbers are general. What was the ambient temp when you noticed this? Cold engine I assume?
  24. tobygaff
    tobygaff Karting
    Dec 5, 2010
    198
    Fort Wayne, IN
    “Cold” engine but probably 72 degrees ambient temp.
  25. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    According to the Bosch CIS guide, the warmup-enrichment cycle would run about 90 seconds at that ambient temp based on electric heating of the WUR, or cut off sooner if the engine heating was greater. I don't have a feel for the actual timing or whether the idle speed / aux-air would kick off sooner, but maybe @Steve Magnusson would know. Either way, the mixture will be rich during that warmup period and then lean out to a "normal" level, so it cold be indicative of a problem with the default mixture level if the engine dies after warmup-enrichment ends.
