Cylinder numbering 550 | FerrariChat
Discussion in '456/550/575' started by rmfurzeland, Sep 27, 2007.
  1. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Can anyone confirm the cylinder numbering for the 550, is it
    right front =1, right rear=6
    left rear =7, left front=12 ?
    where "right" is the passenger side on a US car.
    Regards,
    Ron
  2. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    front left shoud be #7. and rear left # 12.
  3. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Are you sure? You can see a label numbering on the coil bank that seems to imply what I said first, but even this is ambiguous.
    Regards,
    Ron
  4. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I will check mine this afternoon and let you know.
    sark
  5. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I checked mine it is all covered and it is hard to say which wire goes where. I called ferrari delear, they do not want to answer the question, how about that. I checked parts manuel and service manuel, neither one numbered the cylenders. Possiblly you are right, # 7 is at the back. I have to find out too.
  6. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    This is what I found for you. Page B18 in workshop manuel it says. Note: The cylenders are numbered in a U shape begening from the right- hand cylender bank.
    good luck
  7. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Thanks for all your research amd effort so are we agreed my original numbering is correct, it is in a U shape beginning with right front.
    You would think such a simple thing would be well documented and easy to find, eh?
    Thanks again,
    Ron
  8. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Yes you were right. # 7 is in the back and # 12 in the front. By the way what you were plan to do. You ever done belt chang on your 550. I am planing to change the timing belts in few months. If you are done, could you kindly email me step by step. Thanks. Sark.
  9. rmfurzeland
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Dear Sark,
    Sorry I wish I had a step by step instruction but I am not due to try this for another 20,000 miles.
    I do remember an old Fchat thread which had a good step by step sequence.
    Found it , it was by Jack Russell racing on 02-26-2006, 04:08 PM...I see you were in on the dialog....
    "With tremendous hesitation, I post the attached document from the 575M service guide. This is NOT from a 550, and I defer to Phil/Brian/Tom to explain any differences between the 550 and 575. (There were, if I recall, some substantial updates to the tensioner system on the 550)
    (Nervously) -Daniel "
    see attachments with this thread.
    You will need the Staeger tensiometer or the modern Seem digital tensiometer
    Hope this helps a bit,
    Ron
