Cylinder sleeve/ liner replacement | FerrariChat
Discussion in '348/355' started by RCKSTR, Dec 6, 2018.
  1. RCKSTR
    RCKSTR Karting
    Good evening gents,
    Theres a chance I may need to replace a liner on cyl 7, I will be dropping the motor myself and pulling the head for proper inspection. If the liner does need to be changed, do I need to strip it to the bare block and off to the machinist or is there an alternative? I did find a used color matched piston rod and sleeve.
    Cheers
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
    You need to make a tool that fits at the bottom of the liner and then use a slide hammer to pull it out the top. Needless to say, the piston has to come out first. Do replace the rings and the rod bolts.
  3. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    Don't forget to heat the block if you can and shrink the sleeve ( in the freezer) when assembling.
    100% use new rod bolts !!! Normally no need to remove the crank.
  4. RCKSTR
    RCKSTR Karting
    New rings and bolts, no prob!
    Great, thanks guys!
  5. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    757
    Vermont
    john truskowski
    Why is it that you feel you may need to replace the liner?
  6. RCKSTR
    RCKSTR Karting
    Zero compression on the cyl. I'm sure I'm going to find a bent valve or two. Piston edge looks damaged using endoscope
  7. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    good on the scope as initial diagnostic. Hope it turns out amazing.
    Just curious though, Any idea how it happened?
  8. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    Argeed, I would want to know if there was a issue that caused this, such as a clogged injector that caused a lean condition in that cylinder etc
  9. RCKSTR
    RCKSTR Karting
    Will update as soon as the motor is out and I have the head off
  10. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,724
    Why are you assuming only one liner has bitten the dust?
  11. RCKSTR
    RCKSTR Karting
    210 compression and no leak down on other 7
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    ernie likes this.
  13. RCKSTR
    RCKSTR Karting
    I do have a slide hammer, once I get the piston out I will build an attachment to remove the sleeve
  14. RCKSTR
    RCKSTR Karting
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,222
    CT
    John Kreskovsky
    You should do a leak down on the block.
  16. RCKSTR
    RCKSTR Karting
    That's a great idea, guess I'm building a plate next ;)
  17. yelcab
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
    Burnt exhaust valve. Seen it before. Good luck.
  18. yelcab
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
  19. yelcab
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
  20. yelcab
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
  21. yelcab
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
  22. yelcab
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
  23. RCKSTR
    RCKSTR Karting
    Caused by bad injector? There is no indication of any piece coming in contact with the piston
  24. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Has anyone seen a burnt exhaust valve before?
  25. yelcab
    Nov 29, 2001
    13,555
    San Carlos, CA
    Mitchell Le
    This is what happens: Your cylinder was running rich for a variety of reasons (grandma drives it, bad header, bad tunes, bad injector) and there is excessive carbon build up on the valve face. It never comes into contact with the valve seat 100% and therefore cannot dissipate all of its heat into the block. Eventually it burns up, melts away, and you have zero compression. In the process, the liner is worn out, the rings are gone and you maybe lucky if you can save the piston.
