D. Helms 550 Electrical connector upgrade to Gold - anyone seen elec problems? | FerrariChat
Discussion in '456/550/575' started by synchro, Sep 3, 2009.
  1. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    There is a discussion in the Tech area and it surrounds 348, 355, etc electrical connectors and David Helms is putting together kits with gold upgrade as a solution. Not sure many have seen the 550 as having the same issues as other cars, but he says the style of connectors is the same so it seems reasonable that the same issues might crop up:
    Perhaps, just be informed of what DH is doing, looks innovative
    See here:
    http://www.ferrarichat.com/forum/showthread.php?t=236795&page=2
  2. Mr Mezzanotte
    Mr Mezzanotte Formula Junior
    Aug 22, 2006
    653
    try stabilant-22 - that's what a lot of the porsche and vintage lamborghini guys use.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  4. fatbillybob
    Aug 10, 2002
    29,374
    socal
    While I have not seen 550 electrical problems like the mondial or 348 I am 100% convinced that they still exist in our cars (550). I have posted before in other areas of FC about the progression of my 348 from a very pristine streetcar to a full on dzus fastnered racecar and the gradual evolution of increased reliability as the OEM electronics were either eliminated or modified. Guys in the 348/355 section have noted the same things I noticed that with modification of electronics these cars not only run more reliably but with more power. So I will be DaveH's testor or at least user of his gold connector kit. I "know" that there will be improvement. I'm not sure what I am missing yet but hope to feel a difference. Ferrari specs out their connectors for a rediculously low number of cycles and for those of us who will hold on to our cars for years the gold connectors will be value added and keep us running reliably for longer periods of time. For some reason the 550 is more reliable than other ferraris but in reality the build quality is just more of the mediocre same. Anyone would conclude I'm right if they take apart a door panel, have a shrinking dash, or pull any engine connector to find dirt clearly visible in the connector body.
  5. tazandjan
    39,367
    FBB- One thing for sure. If Dave does it, it is solid gold, whether connectors, hoses or maintenance.
    Taz
    Terry Phillips
  6. tritone
    tritone F1 Veteran
    7,232
    On the Rock
    James
    .....that would be a Ferrari, all right......;-)
    Tritone
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,391
    Frederick, Maryland
    Brian Brown
    Good luck, they just made Stabiliant 22 illegal in California. Time to move out of this fu-king state.
  8. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    #8 rustybits, Nov 4, 2009
    I've come across issues on the fusebox, usually the high-draw plugs like the thick rubberised plug that carries the supply feeds into the box,and also the contacts that supply power from the board to the cooling fans. In the U.K i used to see quite a few suffering from corrosion at the ABS unit plug, (due in no small way to the crummy English climate!) so I'm positive that Dave's high quality connectors would help.
  9. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    While Stabilant 22 provides some initial benefit, it tends to build up a varnish-like layer on the connectors with repeated use.
    Probably because the 550 isn't as old yet, and/or had as many disconnect/connect cycles for maintenance.
