Daily SF90 (2 month impression so far) just switched from CUP2 tires to PS4S | FerrariChat
Discussion in 'SF90 Stradale' started by lamborarijason, Mar 22, 2025.
  1. lamborarijason
    lamborarijason Karting
    Sep 18, 2017
    158
    Jason
    I switched from CUP 2 tires to PS4S tires at around 2200 miles, front has a ton tread left, rear was at near wear bar. I was having issues spinning tires even in 3rd gear. Thanks to recommendation of another Fchat member, I replaced all 4 tires with PS4S. After taking it easy for first 10~20 miles or so, I gradually test out the grip with caution. Absolute nuts, even in race mode floor it in 1st it is brutally quick and sticks with zero delay.
    This car is definitely capable of 2.5 sec or less 0~60 "without" use of launch control. Where my 992 Turbo S while insanely quick with launch control, the delta between with and without using launch control is 1.2~1.5sec difference due to delay/pause off the line if just floor it.
    I am two months into SF90, I have gotten quite familiar with the car now. A few key points:
    -I have not used launch control even once, this car absolutely doesn't need it, it is instant. It is possible to make 992 Trubo S faster with mods, but even if it has 1500hp or more, it will never have the instant feel of SF90 no matter how extensive the mod list is.
    -Rolling acceleration is shocking, I thought F8 was adequately fast for me already (faster than 992turbo S with stage 1 tune), the SF90 is whole new level, defintiely a high 4s to 5 sec 60mph to 130mph car. Any brief acceleration it is at 100mph+ on the street, needs to be on brake immediately.
    -Car can start in hybrid mode and pull away quietly without engine starting. However, ev mode on the mode selector will not be available until car is warm (5 to 10 minute or so) then it will show "EV ready" on dash.
    -Car feels incredibly light and nimble, kinda reminds me of 570S I had back in 2016. I also had Aventador SV, it is a big car and felt big, SF90 is similar in size, but doesn't feel big or heavy when driving it.
    -Appears to be very well built, zero issues, zero squeaks. On my previous F8 and 992 Turbo S, car had squeaks in several areas, I end up fixing all squeaks on my own through trial and error (roof, dash, door, bulkhead trims, seat belt, etc).
    -I previous daily drove 488, 3 Hybrid NSXes (Including Type S), Taycan Trubo S, F8, and 992 Turbo S. They were almost all fantastic cars (Taycan TTS I didn't enjoy it), F8 was best of bunch while 992 TTS was easiest to drive fast while keeping underwear dry, being a non hybrid and trubo, F8 was really resonsive.
    -The hybrid system is best one I have experienced so far, the ones on NSXes were good. The one on SF90 just felt a lot more usable, responsive, smoother + true ev mode. I mostly use qualifying mode/sport or race, from time to time full ev mode.
    -Haptic control is fine, I have zero problem with it, only once accidentally pressed the voice control.
    -Bluetooth doesn't drop off on me, on my previous F8, I often have to reconnect bluetooth every few days.
    -Sport mode is very safe, somehow the traction control is seemless, race mode with previous cup 2 tires, it span tires if I floor it from 60~70mph.
    -In Race mode, the exhaust valves seem to stay open longer on deceleration
    Jo Sta7, JSwan724, Lukeylikey and 4 others like this.
  2. Dsald
    Dsald Karting
    Mar 12, 2022
    247
    Chris Johnson
    I just closed on an SF90, should have it in a couple weeks. Coming from an f8 spider, and even though I will miss the spider, I am excited for the sf90.
    on hybrid start, how far can you go before engine starts?
    LVP488, Gh21631 and lamborarijason like this.
  3. lamborarijason
    Sep 18, 2017
    158
    Jason
    Congrats!!
    The car will start in hybrid mode without engine running by default, you press start once to turn on accessory, second press car starts silently in hybrid. When I first got the car I was confused as it start silently and I would press it for 3rd time and end up turning off the car.
    You will be able to leave the neighborhood quietly. I have not tried to see how far it can go before engine starts. I usually just leave neighborhood quietly as cold start is quite loud and neighbor has new born baby. As soon as I am a few hundred feet away, I put the car in qualifying mode and engine starts. You can also manually start in Qualifying, performance, and hybrid mode, just not ev mode.
    For a while I thought something wrong with the car as I could not put it in full ev mode from the start. It turned out need to wait 5 to 10 minutes then it become available, perfectly normal. Full EV mode is kinda fun and totally functional, despite only 15 mile range, the car seem to regen from deceleration and braking quite well without engine running and I have hard time getting electric range to go down unless I am doing prolonged freeway driving in ev mode.
    Being able to change tach in different colors is kinda cool as well (Yellow, red, white, silver), sound system is also surprisingly good. Head up display is also pleasant surprise that helps me be aware of speed I am going while keeping my eyes on the road.
    -Another noticeable difference is F8 has super low rear diffuser clearance. SF90 has more generous clearance in the back.
    -Keyless is true keyless, you do not need to take out the key to unlock the car, just press door handle and it unlocks, auto locks if you walk away with key.
  4. Deezul_812SF
    Deezul_812SF Karting
    Aug 20, 2024
    71
    Do you find the power usable on the streets? Does the power spool up so fast you have to short shift? I know 1000hp is not something you can wring out 100% on public streets but I was just wondering is it just too fast to really enjoy upshifting and downshifting.
  5. lamborarijason
    Sep 18, 2017
    158
    Jason
    It is usable on the street for me, I enjoy it even when driving slow. However, if you are talking about enjoying the rev climb and let it rip like say a 458 or 992 GT3, no, it does not offer that kind of sensation.
    I do have to short shift a lot, can't really stand on throttle for too long, it would hit 80mph or 100mph in instant if given anything over 50 to 100% throttle, I noticed that I am usually on brake almost immediately after I go WOT. It is amazing how it is possible to lay 1k hp down especially with PS4S tires.
    When I had F8 and 992 Turbo S they too required short shift a lot as well, F8's weak point was traction (I actually use the power of F8 even less than SF90 for this reason), 992 Turbo S was the delay/pause off the line (everytime from standing still, from idle to 2500rpm takes a brief moment), so for me on the street (excluding storage and able to carry 2 kids) SF90 was more usable than F8 or 992 Turbo S due to how instant it is and traction, also ride is really comfortable, I have not felt the need to use bumpy mode yet in SF90, where in F8 I use bumpy mode a lot.
    Because the car is also not loud at all, it is easy to do occassional brief hard acceleration without drawing too much attention. When I had louder cars such as Aventador SV, I find myself always drive quite slow to not make too much noise and attract unwanted attention.
    LVP488 and Deezul_812SF like this.
  6. Deezul_812SF
    Aug 20, 2024
    71
    I'm glad you mentioned the 458 - that is my only experience with Ferrari. Corvettes are the other including the most recent version. All of them I was able to wring them out pretty good without too much short shifting. Thank you for answering my questions. I wondered about how all of the power would translate to the road. I have driven a Tesla and when hitting the pedal its more of an instant electric feel which over time is not as exciting. Does the SF90 feel more naturally driven by the ICE or does the electric motors dominate?
  7. lamborarijason
    Sep 18, 2017
    158
    Jason
    I also have Model X Plaid currently and previously Taycan Turbo S, I like EVs as point A to B family car. However, they just plain dull and numb. Mainly due to lack of ability to shift through the gears and sound.
    SF90 feels like ICE NA car with no lag or delays in qualifying and performance mode, while has same instant punch of Tesla from dead stop (without even using launch control) or while car is moving. If want it to feel like EV, it can as well in full EV mode. If reliability is not an unknown question mark, I would highly recommend nearly all hybrid sports/super cars from Artura, Temerario, Reveulto, SF90, 296, 992.2 GTS, etc.
    Deezul_812SF, LVP488 and Caeruleus11 like this.
  8. Deezul_812SF
    Aug 20, 2024
    71
    This confirms a lot - thank you for the details. I'm more excited to make my decision now.
  9. Divexxtreme
    Divexxtreme Formula Junior
    Aug 14, 2020
    840
    Scott
    You're welcome. Glad you're enjoying the PS4S!
    Deezul_812SF likes this.
  10. lamborarijason
    Sep 18, 2017
    158
    Jason
    It was you that recommended, thank you, it really made the car a lot more enjoyable on the daily basis.
    Divexxtreme and Deezul_812SF like this.
  11. Onemorelap
    Onemorelap Rookie
    Apr 6, 2025
    1
    I just hit 5K miles (including 100 track miles) on my SF90 Spider and my experience so far:
    In short, I love it.
    By far, the best sports car I’ve ever driven on every level. For context, I’ve spent many miles driving the likes of the 458 Speciale, Pista, F8, 812, 991/GT3, 992/GT3, 996TT.
    The speed can only be experienced. There is nothing like it. Everything else feels slow by comparison.
    The handling is exceptional.
    As noted by another community member, the engine feels like it is naturally aspirated but better. The V8, turbos, and the electric motors combined with (magical) software that perfectly blends the power creates a new type of driving experience. You have to try it.
    On sound, I had aftermarket exhaust on nearly all other cars I’ve had, from RUF/Sharkwerks on the 911s to Novitec on the F8. Although I’m sure exhaust would improve the SF90 sound, the car sounds incredible without it. I’ve also noticed the engine/exhaust sound got even better at around 3500 miles.
    The SF90 is so well built. I’ve had zero issues. I drive the car very hard and it gives me the same confidence as the GT3s, which are work horses.
    The V8 Ferraris I’ve had the good fortune to drive never really felt solid from a build quality standpoint, especially when compared to the V12s. The SF90 is a step change.
    I love technology and have learned to enjoy the new infotainment systems. Surround view is great and worth every penny if you brave congested city streets and tight garages.
    There is no luggage space in the trunk so I often use the passenger seat. That typically means the wife can’t join for a weekend trip, and whether that is a plus or negative I leave to others.
    I will provide another update when I break 10K miles.
    Hope this helps.
  12. Thecadster
    Thecadster F1 Veteran
    7,527
    Welcome to FerrariChat.
  13. LMP
    LMP Formula Junior
    Aug 11, 2022
    352
    Florida
    #13 LMP, Apr 7, 2025
    The other day I mentioned to my wife ,you know this exhaust sounds better today, said to myself it has more miles and starting to come alive :) and agree what you wrote I owned a lot of the of the cars you mentioned , and Ruf CTR3 clubsport….this car is by far my favorite the only thing is my wife has made it her car ……Congratulations on a great experience of ownership!
  14. lamborarijason
    Sep 18, 2017
    158
    Jason
    That is interesting, can anyone else confirm this? I am at 2300 miles, so I won't know for a bit longer
  15. Dsald
    Dsald Karting
    Mar 12, 2022
    247
    Chris Johnson
    I am also about to make the switch to ps4s tires, mostly because the cup2's are rock magnets. In the neighborhood the sound of the rocks hitting the car makes me cringe, wasn't like this on my f8 with ps4s tires.
    I also experienced the same issue as you did, race mode, 3rd gear about 40mph and pushed it to see what the car can do, lost control almost immediately. That's probably just me needing to get used to the car though, can't blame that all on the tires.
  16. lamborarijason
    Sep 18, 2017
    158
    Jason
    Another thing I noticed, if I start car up in qualifying + race mode (must start it up in race, start in any other mode then switch to race won't work). The exhaust sounds way better once car is warmed up, most noticeable at lower cruising speed and deceleration, car is louder, I was kinda surprised, doesn't feel like lack exhaut sound or need valve controller any more. Maybe it is easter egg.
    I drove 99% in sport mode for first 2 months as traction control is quite seamless and keeps the car well planted, I tried race mode a few times prior to PS4S tires, it was quite scary. PS4S allowed me to explore race mode with confidence.
    Took me a while to get used to it, I always had very high HP cars, with F8 I was comfortable using all its power on first day even on Pirelli PZ4. SF90 took me 2 months and wasn't until I switched to PS4S.
  17. Jo Sta7
    Jo Sta7 F1 Veteran
    5,680
    Scottsdale/Pittsburgh
    Jon
    Thanks for the write up! Car sounds amazing. FWIW, if you wear these tires out, try the Continental Extreme Contact 2. I found in my 765 the PS4S was spinning a lot. These new Conti's offered insane levels of grip and confidence.
    lamborarijason likes this.
  18. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,634
    France
    Regarding the PS4S vs Cup2 debate, I think the Cup2 provide more grip (that's what they're designed for after all) BUT only when they're in their narrow temperature range - so on the road, they're typically too cold to offer proper performance.
    Caeruleus11 likes this.
  19. Caeruleus11
    Caeruleus11 F1 World Champ
    11,403
    I almost agree- except that the Ferrari spec Cup tires do warm up pretty quickly- for a cup tire. I think the Ferrari spec Cup2 is more like a super 4s- except for wet conditions. I would add if you are in a very warm climate and are going to drive for more than 30-40 minutes at a clip, depending on your driving style, you might find you are overheating the 4S tires. The 4S is an excellent tire, but when I was driving in an area with temps that ranged in the 90-100F area and I was on an extended drive that involved a lot of switchbacks- not in the USA- I was overheating the 4S on my Pista. I know that seems almost impossible, but thats what happened. Even back home in the USA, I am back to Cup2 tires on my Pista, Just to show it all depends on our driving style, the roads and conditions in our area, I have cup2 on my SF90 and Ive never experienced any problems; but I do recognize someone else could have a different experience. My average drive time is about 60 minutes and Id say it takes 15-20 minutes for the tires to really warm up most of the time. I would note the Pista spec Cup2 tires is a different K number than that on my SF90- the SF90 tire has a considerable more tread depth. And is even more like a super 4S. Whats on my Pista has much less tread depth and behaves a little bit more track (just a little, neither is a real track tire)
    LMP likes this.
  20. lamborarijason
    Sep 18, 2017
    158
    Jason
    I really really wish so, it would had saved me a set of 4 tires plus hassle. My SF90 came with factory Ferrari spec K-series cup 2 tires, not cup 2 R, only had 2k miles on them before I tossed them.
    My driving is mostly street, zero track, I can't wait 15 to 20 minutes for them to warm up, by then I am almost at where I need to be, I have zero doubt that Cup2 will be fine during Summer or with extended warm up time. They just didn't work for me what so ever, rolling 3rd gear, floor it, tires would just spin, forget about even using 1st and 2nd gear. PS4S, very much once engine is warm 5 to 10 minutes in, it grips even in 1st gear.
    • Warm-up Issues:
      The Pilot Sport Cup 2 requires a significant amount of heat to activate its grip, which can be difficult to achieve on the street. On a track, gentle warming and high pressures are recommended to prevent premature wear and delamination.
  21. Jo Sta7
    Jo Sta7 F1 Veteran
    5,680
    Jon
    The lateral grip is the big difference in Cup 2 vs PS4S. As far as straight line, no difference when warm, really and at street temps PS4S will be superior.
  22. lamborarijason
    Sep 18, 2017
    158
    Jason
    Thanks for recommendation, if they work for 765LT, they must be insanely grippy. I would love to pick up a set once they have size available for SF90.
