Damaged threads in oil pan -- solution? | FerrariChat
Discussion in '348/355' started by Zanzibar, Sep 22, 2007.
  1. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    One of the steps in the procedure for replacing the exhaust manifold is to drain the oil. I noticed quite a bit of resistance when I removed the drain plug. It turns out that the person who was there before managed to mess up everything by not properly seating the oil drain plug. As a result, the plug threads are damaged and... also the threads inside the hole in the oil pan are damaged. :-( As I see it, the oil pan is aluminum with a threaded steel insert where the drain plug goes. There is no way I can install the damaged drain plug. It just will not catch on. What is the best solution for this rather annoying problem, short of pulling the oil pan. Is it possible to install a new threaded steel insert in the hole? Would a helicoil installation save me? Anyone out there who has experienced the same problem?
    Thanks,
    Rik Gruwez
    Bruges, Belgium
  2. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Helicoils can work in aluminum but work best in cast iron.
    Considering this needs to be an oil tight seal and the drain bolt will be removed regularly one should remove the oil resevoir and take it to a welder who can tig weld a new boss there .....for a permanent repair. Such a repair (if you take the oil resevoir out yourself) would cost here around $50.00.
  3. Quadcammer
    Quadcammer Formula Junior
    Jun 29, 2005
    500
    Clifton, NJ
    Oliver
    you may want to try running a tap through there to see if you can clean up the threads before going to the helicoil/timesert route.
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Are we talking about the oil drain plug on the bottom of the dry sump oil tank, or the oil drain plug on the bottom of the engine itself?
  5. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    What is the effort involved in removing a 355's oil pan? Anydone done this before?
    Regards,
    Rik
  6. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    It is the drain plug on the bottom of the engine itself.
    Regards,
    Rik
  7. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Tricky but doable. The rear of the sump is sealed by a thin o-ring that one has to be quite careful with. Attempt the repairs in place first.
    Dave
  8. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    +1....that o-ring is very easy to mess up. If done in place be sure to clean/flush the repaired area out very carefully...the sump pickup screens do a good job of filtering, but I wouldn't take any chances.
  9. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    That did not work. I did manage to get the old helicoil out though. I ordered a 22mmx1.5 helicoil installation tool, which should be here tomorrow. Then I will try to insert a new helicoil. Wish me luck...
  10. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #10 Miltonian, Sep 24, 2007
    Good luck!
    I'm not sure if the "oil pan" setup is the same on a 355 as it is on a 348, but is it possible that the plug you removed was NOT the actual oil drain plug ("scarico olio") on the vertical face at the FRONT of the engine (#15), but was instead the cover plug for the oil pump on the BOTTOM of the pan? They're not the same, and many people have made that mistake before!
  11. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    I seem to have removed the correct plug. ;-) Number 15 has damaged threads. The damaged helicoil which I intend to replace is number 19 in the drawing.
    Regards,
    Rik
  12. BeachBum
    BeachBum Formula 3
    Make sure you run the Helicoil tap through the threads to clean them out, Use Lubrication, Then wash out the Lube, If there was already a Helicoil in the hole the tap should go in and out very easy. Try putting a dab of Locktight on the coil before inserting it. There pretty easy to put in. You shouldnt have a problem.
  13. markarelius3
    markarelius3 Karting
    Jun 17, 2007
    69
    Alpine, UT
    Mark
    Helicoil should work fine... we've had to use a helicoil to replace the threads on a plug hole on a race engine with an aluminum head running 21 PSI of boost. Compression was fine. MANY recommend Time-serts (or keenserts) as a much better product over the Helicoils.
