Damn!! (308 Overheating Post #5,674) | FerrariChat
Discussion in 'Technical Q&A' started by PenP, Aug 14, 2006.
  1. PenP
    PenP Formula Junior
    669
    Los Angeles
    Pen Pendleton
    Well, my 308 is overheating like crazy (runs normal temp when car has airflow, overheats in stop-and-go traffic). I first had a shop flush the system and check the timing. Cost too much as usual. Still overheated.
    The system's been bled more times than a drunken homeless plasma donor.
    So today I got out the wrenches myself and replaced the radiator with a re-core (everybody keeps a few spare rads around, right?). After all that work, car still overheats in the same fashion!! Damn. Damn. Damn. All that work for nothing (well, it did eliminate one possible cause, so I guess it wasn't all a waste – AND I got rid of the unused A/C condenser, so it's nice to have that hump out of there). Seems like the car should run cooler just for taking out the condenser – that's a pretty restrictive thing to have in front of a radiator!
    My 365 had an overheating problem (but not as bad as the 308) and a re-core solved it all, but not this time.
    So I guess this means it's the waterpump or thermostat. WP seems tight and there are no leaks at all, but who knows what's going on inside.
    BTW, I did the "foam" mod on the side of the rad by using rubber garage door weatherstriping that is scored in the middle to make it have a 90° angle shape. The shape works perfectly for stuffing into that tiny space on the sides of the rad. No glue, just stuffed it in there.
    I don't even have my usual 10 questions; I'm just "sharing".... DAMN!!!
  2. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    You have never checked the thermostat?......:(
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yeah I'll second that, change the thermostate. Also, when you bleed it make sure you do it with the heater setting turned all the way to hot. That way you do run the chance of air getting in from the heater core. One more thing have you checked the condition of your radiator cap? You may need to get a new one.
  4. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    If it's OK when moving but overheats in traffic it could be that the fans aren't kicking in when they should be (or at all)
  5. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Hey good point!
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    PenP,
    I 2nd checking the fans, Both should be blowing if It's trying to overheat.
    The thermoswitch connection at the bottom of the radiator is known for getting corroded. Altho, I'd think that changing the rad would have delt with corrosion. Next is the thermor switch itself being bad.
    I understand your frustration tho...
  7. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    Isn't there a relay that controls the thermoswitch?? Worth checking that as well.
  8. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    After you get through checking the fans to make sure they are running, feel how hot the air is coming out the louvers in the snout of your car. If your water pump is putting out sufficient flow at idle, you should notice only a small temperature difference between the driver's side and passenger's side in the blast of air. In my 328, the hot coolant enters at the top on driver's side and flows across and down. If the flow from the water pump is low, little makes it all the way across the cavity at the top of the radiator. Thus the air rushing by the small trickle of coolant falling down the passenger side can easily remove the heat meaning that the passenger's side air blast is a lot less hot than the driver's side if your water pump is not putting out sufficient flow at idle.
    While this has not happened on my 328, I have another car that would like to get too hot when running at low rpm and slow speed under load. It's problem was that the clearances between the impeller and cavity it resides in had gotten too large due to corrosion and would not pump sufficient coolant at low rpm. A new water pump immediately fixed the problem.
  9. jhsalah
    jhsalah Formula 3
    2,409
    Philadelphia, PA
    Jawad
    Having the same problems with my 308... I'm sure you've done the searches already, given the humorous title you gave to your posting, but here's a recent thread... http://www.ferrarichat.com/forum/showthread.php?t=113933
    If you scroll down you'll see everything I did already (oh and though it says the foam was replaced, it hasn't been yet, that was my mistake). At the end of the day, water pump was checked (seems ok), cam timing was adjusted, new fans went in, the radiator got flushed, new radiator cap, and thermostat replaced, but still overheating badly in traffic...
    Not sure what else is left other than the foam but very much doubt that's going to fix it. Really annoying...
  10. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Check the thermal switch on top of the LH radiator mine went bad with the same symtoms.
  11. tnowak
    tnowak Rookie
    Apr 13, 2004
    23
    New Hampshire
    Tom Nowak
    What I've done with my car is bypassed the thermoswitch for the fans. I made a jumper that connects both of the spade lugs, and heat shrunk the entire connection.So the fans are on all the time. My car is a summer car, and I know that both fans are running all the time to maximize my capacity. In my situation, warmup times are no greater with this approach. Instead of waiting for the fans to kick on at 160 or 180 or whatever switch you have installed, the fans are going once the switch is turned on. What this also does for me, is when I turn the switch on, I hear both fans running, thus I know they will be running when they are needed. My 2 cents.
  12. PenP
    PenP Formula Junior
    669
    Los Angeles
    Pen Pendleton
    The fan-running-all-the-time thing may not be a bad idea here in So Cal.
    And also for reference: (1) cap replaced (2) fans come on (3) thermo switch works (4) car has heater removed and plugged off.
    As much of a hassle it is to get the airbox off the car, I didn't swtich the therm. Since I had an extra re-cored rad (and that's what made my other F-car run hot), I just threw that in. I guess the therm is next to do. And I'll do that waterpump test by feeling the temp on the rad, thnx for that! But I guess you just have to pick these off one-by-one, and hope that it is not the dreaded, knock-on-wood bad head gasket.
  13. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    There are test kits for combustion products in coolant. Try commercial auto parts houses. Unlikely that consumer places like PepBoys, & AutoZone will have them. Altho, AZ does occasionally surprise me.
    At least that will eliminate :), or confirm :{, that possibility.
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    short of incorrect system pressure or a bad t-stat. what about your A/F ratio, is it lean causing a hot runing engine? some times the overheating is becouse the engine is not in tune and running hotter than it should, no fault of the cooling system.
    my 2 cents
  15. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    I replaced the cap on mine and it seems to be running cooler. It wasn't over heating as much as it was running 10-deg or so hotter than normal.
    The old cap looked brand new too boot.
    One thing to know is the OEM cap is 1.1bar which is 15-16lbs, not 7lbs like a lot of them are replaced with (and which is what my old one was).
    My car runs ~195 in 95+ heat and high humidity with the AC on to boot. Even if you just replaced it, try a different one. It’s a cheap fix ($6.50 at O’Reilly). I’ll post the PN when I get home for those who care.
  16. Mark 308 gt4
    Mark 308 gt4 Formula Junior
    Apr 24, 2006
    285
    West London
    Mark Taviner
    Sorry to hear of your troubles, I only wish I lived around the corner I would have a look for you.
    I would still go for the thermostat, in fact I would have gone for that after the first flush. Radiators and water pump internals take many years to block up, its a very slow process but thermostats just give up. They stick closed open or half way. The half way looks like what could be your problem, going along at speed the water pump is pushing it through the small hole. But when ticking over in traffic it is not circulating fast enough, thus getting hot!
    Hope you fix it, keep us posted.
    Mark...
  17. jfrazar
    jfrazar Karting
    BANNED Rossa Subscribed
    Jun 26, 2004
    223
    Savannah, GA
    Joe Frazar
    Is the car boiling over? My 308 gauge has always read a little high. It used to bother me unitl I pulled out my laser temp gun. The gauge is just wrong. 195 on my car reads 205 on the gauge.
    Joe
  18. PenP
    PenP Formula Junior
    669
    Los Angeles
    Pen Pendleton
    Thanks everybody. I'm doing the therm today; we'll see.
  19. silvergts
    silvergts Rookie
    Dec 12, 2005
    13
  20. thecarreaper
    thecarreaper F1 World Champ
    18,130
    Savannah
    no disrespect, BUT THIS IS A BAD BAD BAD IDEA!!
    the cooling fans are DESINGED to kick on and off, and they draw a bunch of amps. by leaving them on all the time, the electrical system is not allowed to "rest" and go through a load / charge cycle. my old lambo had the fans "straight wired" and it did nothing but cuase burned up alternators and overgeated connections. the switch is there for a reason and there is NO REASON to wire it to run all the time.
  21. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Here's a thought . . . the intake manifold water passages on my old motor were all corroded/blocked with calcium near the end holes of the head . . . most of the water was being forced through the middle "elbow connection" hole only . . . . that engine seemed to run hotter than my new motor, but new motor also has new thermostat so???
    Sean
    P.S. Getting the intake manifold off was a PAIN because of the corrosion!!!
  22. 4Webers
    4Webers Formula Junior
    Nov 12, 2003
    276
    Texas
    Darrell
    #22 4Webers, Aug 15, 2006
    Here's a pic of what that looks like - very not pretty. I would pull the manifolds and at least check for this if you are having overheating problems that can't be solved by the 'easier' fixes.
  23. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Yep, that's what mine looked like.
    Sean
  24. mfennell70
    mfennell70 Formula Junior
    Nov 3, 2003
    620
    Middletown, NJ
    My latest Esprit project has that too. I was amazed at how hot the fuses get.
    Fortunately, the fuse box is by my knee in that car. For the time being, I'm manually controlling the fans by inserting fuses (3, one for each fan) as necessary. It's suprising how little the fans actually have to run.
  25. thecarreaper
    18,130
    Savannah
    i really need more sleep so i can spell properly....
    i agree, it seems the fans cool better in a cycle and by operating in a cycle, it gives the charging system a way to keep up!
