Dash Bulb Replacement | FerrariChat
Discussion in '308/328' started by tomburns, Jul 3, 2008.
  1. tomburns
    tomburns Karting
    Apr 13, 2005
    60
    Toronto, Canada
    Tom Burns
    Hi,
    I couldn't find anything here about how to access the instrument lights. Do you need to remove the steering wheel, the whole dash, panel, etc.? Info or a pointer to the proper thread/post would be greatly appreciated.
  2. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
  3. canadiantifosi
    canadiantifosi Formula Junior
    Jul 2, 2008
    919
    uh...guess...
    Canadian Tifosi Sr.
    I just recently completed upgrading the bulbs in my dash cluster. Very simple job. I put in 3.5 watt bulbs in the speedo and it made a noticeable difference in brightness.
    Simply remove the four indicator lights in the corners and you will be able to see the mounting bolts that hold the dash cluster to the bulkhead. If the 4 lights don't come out easily, try working some dental floss or fishing line around the circumference of the light's bases and give them a little wiggle.
    It might be a good idea to cover the steering column with a shop towel to keep the dash from scratching the leather on the flat surface and the steering column.
    A good idea is to always take digital pics each step along the way as this will provide a reference if you run into a problem with re-assembly.
    Cheers-Colin Firth-Ontario Canada
  4. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    and if you brake the clips on the warning light housing,no big deal,sigmacars has them for sale,which I bought plenty when I changed out my temp gauge,they always brake
  5. ClydeM
    ClydeM F1 World Champ
    11,763
    Wayne, NJ
    Clyde E. McMurdy
    I replaced the bulbs a while go and had no significant difference in lighting.
    However I did achieve a major increase by cleaning the contacts at the Molex(?) connector behind the panel.
  6. mwr4440
    57,885
    Bavaria, The 'Other' Germany
    Mark W.R.
    If you don't take the dimmer switch out of the equation, you may see little to no increase in brightness. Also, sometimes people actually change out the wrong bulbs. They are not necessarily intuitive.
  7. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    #7 spiderseeker, Jul 4, 2008
    Here is a shot of mine after replacing the bulbs. (sorry , no before shot)
    It was bright enough, that I didn't bother bypassing the dimmer.
  8. ClydeM
    11,763
    Wayne, NJ
    Clyde E. McMurdy
    Sorry, forgot to mention...I did clean the dimmer pot/reostat...that helped a smidge, but not significant. Bypassing it didn't help either. For me, it was the oxidized connectors.
