Dash bulb replacement | FerrariChat
Discussion in '348/355' started by dantm, Jul 4, 2013.
  1. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    How does one go about replacing the dash bulbs? I think some of my lights are out because they don't go on when the key is in pos 2 (just before firing the car up).
    Also -- just to confirm, which ones should go on for testing just before starting the car? I thought all Slow Down, CEL, ABS, Brake, and Battery - is that all?
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    355?
    To access the bulbs, you need to remove the instrument cluster which has only 2 screws on the bottom, on each side of the steering wheel, in the part line between the upper and lower section of the dash.
    You might be able to change them without taking the cluster out, but disconnection the cluster and removing it from the car will make it much easier
  3. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    Did you ever find out how to remove the dash bulbs? I have my dash down getting recovered so, I thought "While im in there" I would take the opportunity to replace my bulbs with blue ones like another fchatter did. (REALLY COOL LOOKING BTW)...thanks...
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #4 Dave rocks, Nov 27, 2013
    Just rotate them and pull out but be carefull to not hurt the plastic circuit board...
  5. stevew3765
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    thanks a bunch
  6. mdsassaman
    mdsassaman Karting
    Nov 4, 2006
    246
    Reading, PA
    Mike Sassaman
    It would be great to have a list of the bulbs and sizes to replace these with LEDs and a source for the LEDs. Maybe even a kit from some LED supplier for the whole dashboard lights replacements.
  7. stevew3765
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
  8. stevew3765
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    thanks to JEVS..
    (8) 74-xHP3: Wedge Base LED bulb 74-AHP3: Amber $27.92 Super Bright LEDs
    (9) 74-xHP3: Wedge Base LED bulb 74-RHP3: Red $31.41 Super Bright LEDs
    (4) 74-xHP3: Wedge Base LED bulb 74-GHP3: Green $13.96 Super Bright LEDs
    (13) 74-xHP3: Wedge Base LED bulb 74-BHP3: Blue $45.37 Super Bright LEDs
    Also Ricambi will tell you if you give them a call...
  9. stevew3765
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    Hi as you can see we have a another question. What size and where did you get your dash bulbs.I posted a list from JEVS. I have a question also. I tested all my bulbs and one was out in the main cluster (speedometer) if one bulb is faulty will it cause failure to the rest of the bulbs on the circuit? Thanks
