Dash lights out after 15 min of driving ... | FerrariChat
Discussion in '348/355' started by Redlyne_mr2, May 19, 2018.
  1. Redlyne_mr2
    Redlyne_mr2 Formula Junior
    Aug 5, 2009
    472
    Calgary, Alberta
    Ryan D
    my 98 355 dash lights will go out after 15 minutes of driving. This tells me that it’s something electrical with an issue that’s heat related . I’ve read a bad potentiometer can cause this. Anyone have experience with this?
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,428
    Ian Riddell
    Is the problem limited to the dash lights? Is the centre console switch backlighting affected? Is the clock, fuel gauge, etc, backlighting affected? I'm just wondering if it's a light power problem in general or if it's limited to certain areas.
    Have you tried putting the potentiometer in a different position?
    I've had my rear turn indicator lights and brake lights play up after 15 minutes or so, but this was due to a bad earth near the radiator. Even earths can be affected by temperature.
  3. Qavion
    Feb 20, 2015
    14,428
    Ian Riddell
  4. Qavion
    Feb 20, 2015
    14,428
    Ian Riddell
  5. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    Can you elaborate further? When the dash lights go out do they come back on the day after or come back on at all? Surprisingly I don’t see a “potentiometer” in my car. Ive never driven at night. Never had to turn on the lights. 1999 355F1.
    A potentiometer is more or less an adjustable resistor. It’s purpose is to limit electrical power to a device(s) by limiting the voltage via a dial or sliding mechanism. When these devices fail, it usually happens at the contacts. The likely instigating factor is heat. But we don’t know it’s the problem until you answer question above and check all devices in line. The fuse for example. See drawing.
  6. Roth
    Roth Formula Junior
    Apr 1, 2016
    433
    Pepsi Generation
    Here
  7. INRange
    INRange F1 World Champ Silver Subscribed
    Jan 27, 2014
    12,638
    Virginia/Florida/Caymans
    JD
    Dash light's rheostat located on stem, bottom of tach face.
  8. Qavion
    Feb 20, 2015
    14,428
    Ian Riddell
    In your other thread, you've posted a (still) photo of the centre console with the clocks not illuminated, but the switch backlighting illuminated.. .and the topic labelled "dash lights flicker". Assuming the switch backlighting was ok (and not just in its "on" state during the flickering) this is something we can work with. It proves it's not a fuse or relay but something further down the line (as one fuse powers all these lights). It's more likely to be a rheostat problem or something further downstream, such as an earth.
    https://www.ferrarichat.com/forum/attachments/image-jpg.2400516/
    In theory, you can remove the tacho electrical plug and put a (temporary) shorting wire across the plug's white and yellow-red wire, bypassing the rheostat. This will give you full brightness on all the instrument lighting (except the tacho which will be dark). If you get no flicking on the instruments on subsequent drives, this will prove the rheostat is faulty. Rheostats are not available new. I have seen used rheostats for sale, but they have silly prices.
    If indeed the switch backlighting was in it's "on" state during the flickering in your photo, it could be a fuse or relay contact failure.
  9. m.stojanovic
    m.stojanovic F1 Rookie Silver Subscribed
    Dec 22, 2011
    3,288
    Serbia - Niš
    Miroljub Stojanovic
    The "rheostat" is actually electronic, using a potentiometer and probably having just one power transistor controlling the current to the bulbs. I believe it can be repaired by replacing the transistor and/or other failed components inside. Otherwise, it is the same as Alfa Milano unit but these are also very hard to find (one Alfa forum even suggested to look for a Ferrari 348 or 355 rheostat).
    Qavion likes this.
  10. Redlyne_mr2
    Aug 5, 2009
    472
    Calgary, Alberta
    Ryan D
    thanks for the help everyone. I was able to source a brand new rheostat (sat on a shelf for years), I've since installed it and lets see what happens.
    Qavion likes this.
  11. HS Lim
    HS Lim Rookie
    Nov 14, 2017
    1
    HS Lim
    hi there! I am wondering if you solved the problem with new rheostat.
    Thanks in advance
  12. Redlyne_mr2
    Aug 5, 2009
    472
    Calgary, Alberta
    Ryan D
    Yup looks like the issue was the rheostat, all is well now. Since this rheostat was super hard to find Im going to see if my old one can be repaired for future use or to help out another owner. I suspect this will soon become a common issue for others.
    Qavion likes this.
  13. Qavion
    Feb 20, 2015
    14,428
    Ian Riddell
    Thanks for the feedback, Ryan. I was hoping it was something cheaper, like a relay, but...
