dash lights | FerrariChat
dash lights
Discussion in '456/550/575' started by hogbreth, Feb 8, 2024.
  1. hogbreth
    hogbreth Karting
    Oct 23, 2006
    119
    Florida
    John Bennett
    1999 550 went to drive it last night everything worked except no dash lights. today I checked the fuses under the Pax foot board all tested OK. I plan on checking the rheostat to see if there is power to it. anything else I should be aware of?
    thanks
    F456M likes this.
  2. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    Does the icon for parking lights come up (a green one). I have had the same thing on my 550 a few times the last years, and it is bad connection somewhere in the fuse box. I have wiggled and massaged it on the upper right side and then the parking liggt icon dissappear and the instrument light is back. I have no idea why it does that. Turn signals seem to disappear at the same time when this problem occurs. :)
    Qavion likes this.
  3. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
    Fuse 12 provides power to the dimmable (rheostat-controlled) lights on the dash (and on the centre dash cluster and HVAC panel), but also to some non-dimmable lights, such as the licence plate lights, "sidelights on" and "parking lights on" annunciators.
    The connector Erik refers to is probably connector F (white wire on pin 1):
    You should be able to figure out if your problem is a dimmer issue or a power issue by checking your licence plate lights.
    Fuse 5 provides power to most of the other dash non-dimmable annunciators: water temp and oil temp warning (in their respective gauges), airbag, parking brake, brake warning, window heat, suspension, seatbelt and low traction annunciators.
    F456M likes this.
  4. Qavion
    14,290
    Ian Riddell
    You can temporarily bypass the rheostat by shorting out the yellow and white wire on the connector
    That will give you full brightness.
    F456M likes this.
  5. Aerosurfer
    Aerosurfer Formula 3
    1,886
    Indianapolis
    Nick
    Qavion likes this.
  6. hogbreth
    hogbreth Karting
    Oct 23, 2006
    119
    Florida
    John Bennett
    Thank you everyone for your feed back I revisited 15 amp fuse in spot 12 it seemed to test ok but i replaced it any way and pressed hard to make sure it was seated
    I have dash lights again. I honestly don't know what I would have done without the help of this forum dealing with all the little problems that crop up
    Qavion likes this.
  7. Qavion
    14,290
    Ian Riddell
    Hopefully there are no dry solder joints in the relay panel. These cars seem to be showing their age. On the F348 it’s now recommended that you remove and reinsert relays and fuses periodically to refresh the contacts. Some DeOxit wouldn’t hurt, either.
    When you say you tested the fuses, do you mean with an ohmmeter or voltmeter?
    308 GTB likes this.
