Dash switches | FerrariChat
Dash switches
Discussion in '308/328' started by johnhunt, Sep 4, 2013.
  1. johnhunt
    johnhunt Formula Junior
    Aug 9, 2013
    343
    Washington
    John Hunt
    As I look to fix certain items it is plain that prices are all over the board for parts. One vendor might charge $30 for an oil pressure switch and another $250 for the same part. And one vendor might be cheaper on one thing and very expensive on another. No real rhyme or reason to it as far as I can tell. But it really pays to shop around.
    Anyhow I found these switches that appear to be correct (except for the black tab) for our cars. They are about $15... and I post it because I have seen them on ebay for ten times that.
    Classic Lucas Retro Switches Vehicle Switches : On, off single pole switch 036411
    Regards,
    BTW: that oil pressure switch was purchased here Ferarri Parts | Ferrari Spare Parts | Ferrari Spares
    Want a stock shift knob? They are $25 here Ferrari 208/308 GT4: Gear box: Gear box - Highlights VS. $278 here Ferrari Parts : 103301 : 103301 SHIFT KNOB WHITE NUMBERS - T. Rutlands
    They also have the choke/heater knob assemblies (the whole thing) for $150 or so.
  2. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
  3. ClydeM
    ClydeM F1 World Champ
    12,054
    Wayne, NJ
    Clyde E. McMurdy
    Make sure you post these in the part xref thread.
  4. Nielsk
    Nielsk Karting
    Dec 8, 2012
    179
    Central Florida
    Which position is off? I bought an aftermarket replacement dash switch, it works and looks fine but it is off in the down position, opposite of the correct switch. Annoying...
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    You are allowed to rotate the switch. The underlying plate can stay where it is.
  6. Nielsk
    Nielsk Karting
    Dec 8, 2012
    179
    Central Florida
    Rotating does not work. At least on my car, the switches have 2 positions, straight out and down. If you rotate 180 degrees, it would be straight out and up, opposite from all the other switches and the graphics...
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Post a pic please?
  8. Nielsk
    Nielsk Karting
    Dec 8, 2012
    179
    Central Florida
    #8 Nielsk, Sep 6, 2013
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Ah I see. Sorry cant help I didn't realize this was a 308GT4. Perhaps I can try to locate the correct switch.
  10. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #10 Crowndog, Sep 6, 2013
    Try:
    Www.holden.co.uk
    Go to electrical,switches,toggle. Then about halfway down they start
    They have several including center off up or down on. May have to change paddle. Single position also available but you need to check with them if center is off it looks like they have both.
