Dash Top Vent Removal | FerrariChat
Discussion in '348/355' started by Derekevan13, Apr 17, 2018.
  1. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
    Does anyone know if the two dash vents with three hex bolts each can be removed without disassembling the dash? I’m thinking there may be nuts on the underside that are not secured to the dash. (Stock photo from the internet). Thanks!
  2. salbrech
    salbrech Karting
    Dec 20, 2013
    103
    Derekevan13 likes this.
  3. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    Bonjour, comme le dit un tournevis et une clé Allen raccourcie pour que l'étape soit gênée par le pare-brise. Pour les clips, mettre un chiffon (chiffon) dessus pour ne pas avoir à le chercher partout dans la voiture.
    Derekevan13 and Yassa like this.
  4. allandwf
    allandwf Formula Junior
    Aug 27, 2011
    267
    Scotland UK
    Excellent timed post. That is on my to do list as they look very tatty on mine. Thanks
  5. A348W
    A348W Formula 3
    Jun 28, 2017
    1,748
    North Wiltshire, UK
    and me! was on my list to do as the paint on mine is bubbling slightly.
    I'm not sure if its plastic or metal; but either way they are coming off and being stripped and re-painted.
  6. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
    Sounds like no dash removal is needed, which is great. Ideally (if they are steel) I’d like to have them powder coated, but will likely strip with paint thinner, lightly sand, and hit them with flat black Rustoleum as I have a Concourse event on Sunday.
  7. Derekevan13
    Derekevan13 Karting
    Jun 9, 2017
    62
    348 Jeff, thank you for the thorough documentation! What was that third black piece you had on the table? Do you think powder coating is an overkill?
  8. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,502
    Jeff
    The 3rd piece is the trim under the window sill round teh engine compartment (which is actually 3 pieces).
    All my black plastic parts have just been stripped and then painted with a black satin spray paint which has proved fine.
    If your getting other parts powder coated you might as well but I havent and they have been fine so yiur decision really
  9. salbrech
    salbrech Karting
    Dec 20, 2013
    103
    hello guys,
    I did this trim and cover plate painting 1 year ago, but in the process of removing the cover plates I damaged quite some little stuff.
    Can someone explain to the community how exactly you removed the cover plates without damaging them?
    I pried them off with a flat screwdriver, but could not do it without damaging the cover plate: on one, I even slipped of and damaged the dash leather a bit :-(
    Before installing them back on, I removed the snap lock notches and just installed them with a very weak glue to avoid the same trouble next time....
    Best regards from Switzerland
  10. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,502
    Jeff
    I used a knife rather than a screwdriver as its thinner. Only thing I can recommend is to be very, very careful.
    I agree on replacement - they are just too tight a fit so I sanded them down a bit until they would clip on without a lot of force but a light touch of glue is a good idea too
  11. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    Personnellement, je n'ai rencontré aucun problème de démontage et de remontage ...
    sauf quand le clip saute, ou un chiffon dessus pendant l'effort du tournevis.
  12. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    675
    Vermont
    john truskowski
    What kind of cupcake was that?:rolleyes:
  13. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,845
    Southern Md
    Robbie
    We have done several hundred sets of these, if anyone doesn't want to mess with doing their own, give us a call or email. We can refinish them for you. Robbie
  14. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Guys - when stripping these to bare aluminum (which I
    Recommend) use an epoxy primer even if a ratttle can. You can buy some 2 part epoxies from Eastwood that come in a rattle can with an activator. Not as good as a spray gun but not horrible. Epoxy is the best for bare metal. Self etch is OK but not as tough.
