dashboard light does not function , 360 Modena | FerrariChat
Discussion in 'Technical Q&A' started by roose369, Nov 15, 2009.
  1. roose369
    roose369 Rookie
    Nov 14, 2009
    15
    Chile
    Joachim Roosen
    H all ferrari fans. Lastweek I took delivery of my black ferrari (2002)360 modena, which I purcased in Miami and shipped it to my country; Chile.
    The dashboard lights did work , mut suddenly turned off, and now only the arrows light up, I tried every thing with the 2 small buttons , on the left in order to raise the intensity, however in the panel next to the intensity there appears a cross ( could this indicate that it is turned off, or has a malfunction ? All the fuses are ok. Please help as in the dark I cant see the speed and te other controls.
    Joachim
  2. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    There are threads on this issue, try search function and you should find help. It seems it is a relatively common problem and not that easy or cheap to repair.
  3. Tifoso Ferrari
    Tifoso Ferrari Formula Junior
    Nov 7, 2005
    578
    Upper Volta
    Gianni Cagate
    A very similar problem happened with both my 456M and 575M. Turned out to be a simple connector that was loose that was connected to the dimmer switch, underneath the dash.
  4. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
  5. roose369
    roose369 Rookie
    Nov 14, 2009
    15
    Chile
    Joachim Roosen
  6. tazandjan
    39,174
    Joachim- If you are not up to doing it yourself, here is the group who can fix it for you. ~$500 for a repair and it will be checked to ensure it works. They repaired a 575 SA instrument panel for me.
    Make sure you try that connector first.
    Franchorchamps of America, Inc.
    935 Sunset Dr Suite A
    Costa Mesa, CA 92627
    (949) 631-6373
    Rod Drew
    [email protected]
    Will White
    http://www.ferrarioc.com/
    Taz
    Terry Phillips
  7. roose369
    roose369 Rookie
    Nov 14, 2009
    15
    Chile
    Joachim Roosen
    Thanks a lot , I bought a new lightpanel for USD 225 , changed it and now it works, Great tip, thanks
  8. roose369
    roose369 Rookie
    Nov 14, 2009
    15
    Chile
    Joachim Roosen
    THanks Rod , I bought a new light panel for USD 225, excanged it and now it all works !!!!
  9. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I'm curious what is involved installing the new circuit board? Can you lay under the dash, spot the bad critter and make the replacemtent or must many things be removed first just to get to it?
  10. tazandjan
    39,174
    #10 tazandjan, Nov 29, 2009
    Paul- you need to pull the instrument panel. The strip lighting panel looks like this, so you can see it is not something you are going to slide into the assembly.
    Search in the 360 forum for "yellow tachometer" and there are photos and instructions on how to remove the panel.
    Taz
    Terry Phillips
