Database Programs? | FerrariChat
Database Programs?
Discussion in 'Other Off Topic Forum' started by SefacHotRodder, Feb 9, 2004.
  1. SefacHotRodder
    SefacHotRodder F1 World Champ
    Dec 20, 2003
    11,141
    NJ
    Chris
    Ok, i tried using act for this but couldn't figgure it out (if someone wants to, PLEASE fill me in on how to).
    Basically i need a program where i can define the fields. I want to open it and a box to pop up with the fields i have defined, i want to enter the info and click ok and the info entered into a registry that i can add to whenever i want.
    I hope thats clear
    cheers
    Chris
  2. lesterm
    lesterm Formula Junior
    Nov 3, 2003
    611
    Durham, NC
    Microsoft Access is a pretty simple dbase program that might work for your purposes.
  3. KKSBA
    KKSBA F1 World Champ
    14,740
    SBarbara-La Jolla CA
    KKSBA
  4. SefacHotRodder
    Dec 20, 2003
    11,141
    NJ
    Chris
    thanks guys, i'll check those out
  5. SefacHotRodder
    Dec 20, 2003
    11,141
    NJ
    Chris
    ok, i'm using access. do i set it up as a table, form, query or report?
  6. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    You want to create a new TABLE, defining the fields in DESIGN mode ("Design" table).
    Then, when you want to enter data into the table, you want to open the table up in DATASHEET mode ("Open" table), where you can add records ("rows") as needed. (In this view, your "fields" are the columns).
    Note that, in this use, you've basically set up a custom spreadsheet with some nice database features behind it (data integrity, search ("queries"), etc.). This is like a "flat" table or flat database. If this is all you're doing, you may investigate using Microsoft Excel... A bit easier to use for simple rows/columns.
    Private Message me if you need more help.
    I recommend getting Que Press's "Special Edition Using" Microsoft Access 2000 or 2002--those books are gold.
    --Mike
  7. Jay
    Jay Karting
    Nov 13, 2003
    152
    Charlotte
    Jay
    With Access, the first thing to do is create a table. Add all the fields you want stored with each record. Each field has a type and length. Then create a form. The wizard will walk you through it. As long as all you want is a simple form to display and enter records. It's all automatic.
  8. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    K5, PM me your # and a good time to call... i've been working with ACT! for damn near three years...
  9. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    ACT! has only a bit of a learning curve, and is good for basic databases. I hear it is not very open though, so moving your data later might prove to be problematic. Access is quite powerful, with a steeper learning curve. You won't go wrong with FileMaker Pro.
    In a database, you have to track one-to-many relationships (eg. one owner, many cars). To show these relationships in a spreadsheet table, you will end up repeating data in one column (eg. owner's name if there are multiple cars), or you will need to leave blank cells in that column. You will hit limitations pretty quickly unless you master the pivot tables function. So don't use Excel unless you know you will not progress beyond a simple grid.
    You can import Excel tables into spreadsheets at a later point, though, so it can work as a temporary solution until you move up to a database program. But avoid the hassle and go with the full-fledged program you are ultimately going to end up using.
    Of those, FileMaker Pro is the best choice for starting out with.
