daytime flasher 456M | Page 2 | FerrariChat
Discussion in '456/550/575' started by chrismic, Aug 11, 2014.
  1. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    #26 2000 456M, Aug 14, 2014
    I just did a check: there is no difference in the light pattern between flasher and fog light. There is absolutely no effect in using the flashers while the fog lights are on. An oncoming driver would have no clue you were flashing him.
    Incidentally, the 456M operation manual at page L-9, has a diagram identifying item F as "Foglight and Daytime Flasher." I guess there is no circumstance where you would need to flash someone to lower their lights when you were in a fog.
    As far as the rear lights are concerned, switching on the fog lights is like having the parking lights on or driving with your headlights raised. The outside rear lights are illuminated as they'd be if you were driving at night.
    nini likes this.
  2. redcaruser
    redcaruser Formula 3
    2,426
    switzerland
    daniel
    Yes, there were little concerns. The main problem is not only the light intensity rather the lens, the light shines too high for all traffic participants. Therefore if I would like to use the daytime flasher as a daylight I have to install another headlamp including diffuser. With such a change I loose the legally prescribed daytime flasher functionality. For me not a proper solution.
    Yes, we will install the AEG light into the grill.
  3. chrismic
    chrismic Formula Junior
    Jan 7, 2012
    272
    Thanks guys!
    Daniel: I see - interesting that US cars have flasher and fog light capacity. I assume they have different beam/diffuser...probably also explains different partnumbers for US and Euro lights, too. At this stage I am inclined getting US lights and hook them up to fog switch and indicator lever...
  4. Flore
    Flore Karting
    Jan 22, 2013
    98
    Dubai
    I'll let you be the guinea pig and report back :D
  5. Lionworks Auto
    Lionworks Auto Formula 3
    Oct 16, 2013
    1,023
    Worthington OH
    Ed
    Confirmed on mine. Pulling stalk with fog lights on does absolutely....nothing
  6. MogulBoy
    MogulBoy Formula Junior
    Sep 23, 2004
    972
    Devon
    Would these 90mm round DRLs from Hella be of any use?
    Original New Hella LED Daytime Running Lights Universal Set 90 mm Round Eazy | eBay
    If you could replace the OEM flashers with these units and leave the original wiring in place so that you could flash them on if you wanted to, you might be able to wire up a parallel feed so that they could be switched on to run as DRLs when you wanted to...
    If you then wanted to flash someone, you could flash them off(!) with your new switch or, if you were clever enough, wire them so that the stalk flashed them off. The last thing would be to remember to switch them off (or dim them?) when the headlights come on as I believe that the regs state that DRLs are for daytime use only (or come up with some crafty wiring solution that would automate this). :)
    P.S. I saw a beautiful blue 456M near Geneva recently and noticed that it was driven without any lights on and thought that the driver was running a small risk of being sanctioned but at least he did have diplomatic plates, so perhaps that was his defense!
    F456M likes this.
  7. redcaruser
    2,426
    switzerland
    daniel
    Great input MogulBoy, thx, I will check your approach with my Ferrari garage.
    E few days ago I did also a short trip with my 456M, unfortunately I forgot to switch on the light. This can happen also without diplomatic plates... ;)
  8. redcaruser
    2,426
    switzerland
    daniel
    #33 redcaruser, Oct 24, 2014
    Today my Ferrari specialist has installed the daytime headlights (AEG LED Daytime Running Lights LS*18). IMO not the worst solution; fully legally compliant, the components were just fixed with tape and cable retainers, the look is ok - yes, I'm happy!
    F456M and nini like this.
  9. nini
    nini Rookie
    Jun 13, 2012
    20
    BXV NY
    Nino C.
    The fog lights are not fog lights at the 456m they are Daytime Flashers just turn the light switch 1 Turn keep the button in the mittel Consol down and voila' u got daylight LOL i been doing it for years and if u want them to look Cooler let them convert to HID
  10. Mirek
    Mirek Formula 3
    1,483
    Los Angeles, CA
    Mirek
    Can you exit the car with the stalk still turned 1 turn and the fog lamp button down ?
    No battery draw ?
  11. MaurizioAM
    MaurizioAM Karting
    Sep 5, 2018
    104
    Plano Texas
    Maurizio
    Not the stalk just the toggle switch in the center console. I always leave my switch on so the moment I start her up "daylights" are on. I haven't had any issues with battery draw, I don't even use the tender just starts up everytime.
    Sent from my Nokia 6.1 using FerrariChat.com mobile app
    F456M likes this.
  12. Mirek
    Mirek Formula 3
    1,483
    Los Angeles, CA
    Mirek
    The toggle switch does not turn on the lamps without turning the stalk one turn...right ?
  13. Qavion
    Qavion F1 World Champ
    14,194
    Ian Riddell
    Correct. For some reason, cars fitted with rear fogs require two clicks (Low beams).
  14. Qavion
    14,194
    Ian Riddell
    Further clarification... The fog light switch has no power going to it until the "outside light" relay has been energised (with one click of the stalk switch)
  15. nini
    nini Rookie
    Jun 13, 2012
    20
    BXV NY
    Nino C.
    Yes only when u change the car stereo somehow mysteriously it drains the batterie
  16. nini
    nini Rookie
    Jun 13, 2012
    20
    BXV NY
    Nino C.
