Daytona electrical issues | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by PDB, Oct 8, 2023.
  1. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    Hi,
    I’m assuming this must be a bad earth issue somewhere, but I can instantly fill my fuel tank for free simply by adjusting the panel lights dimmer.
    Should there be a dedicated earth connection from the instrument panel to the chassis somewhere?
    How big a job is it to remove the dashboard? I’m not entirely happy with the wiring, so I’d like to be able to get at everything and thoroughly check it out.
    As an example, it has inexplicably stopped charging when running, when it was charging fine.
    When should the “Starter” lamp in the tacho light up (mine doesn’t light at all) and should the “Brake” warning light light up when the ignition is on but engine not running? That feels more like ignition lamp behaviour, so I was wondering if they have been connected incorrectly.
    Thank you,
    Paul
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,546
    romano schwabel
    what you understand under "starter lamp"?
    the problem you artie seems to me a ground problem
  3. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    sorry, too fast typing.
    I mean: the problem you have seems to me a ground problem
    PDB likes this.
  4. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    That’s what I assumed, bad earth/ground, which is why I asked if the instrument panel has a dedicated earth/ground connection because I can’t see anything on my car, which may explain the problem.
    Paul
  5. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    just try to connect a ground wire to the instruments-housing and see what will happen
    NYC Fred and PDB like this.
  6. gcalex
    gcalex Formula Junior
    607
    Mostly New Hampshire USA
    Alex
    As I understand its function, the “Brake” light covers three things: 1) brake-lamp failure, 2) failure of one of the brake hydraulic circuits, and 3) engagement of the hand-brake. Of these three, only the hand-brake is something you would normally see; obviously, only if ignition is energized.
    “Starter” (according to the manual) indicates that the manual choke is engaged.
    Can’t verify, because neither has ever worked on my car; so many niggles, so little time… :)
    PDB likes this.
  7. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    Thank you. That explains why I’ve never seen the Starter warning lamp lit because the choke isn’t connected on my car.
    My handbrake lamp doesn’t work either, so you’re not alone.
    Paul
  8. gcalex
    607
    Alex
    Here is the switch at the top of the choke lever; you pull the lever toward the driver, the switch closes, and the light should turn on.
    Seems that mine is not getting 12V at the input, so probably they removed to bulb when they disconnected all the choke stuff on my car.
    Switch for handbrake is similar, you can touch it if you put your hand in from the access panel behind the LH seat, but to service it, you probably have to pull the console. Mine works if I fiddle with it, but the contact is intermittent.
  9. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    Thank you again, I wasn't aware there was an access panel, so that's something else for me to check. :)
    Paul
  10. gcalex
    607
    Alex
    It's small; maybe 10cm tall, and 15cm wide; right on the central tunnel adjacent to the floor; mostly to get to the shifter adjuster...
    swift53, PDB and Edward 96GTS like this.
  11. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    the dash face plate with instruments unscrews with four thumb screw but the wiring behind must be released.
    Here is teh kicker when you see it!!!
    The electrics have MANY connectors and each can corrode. There is even the Sub-wiring loom for instruments BEFORE it goes to main loom. This means you can have many connectors between points and all are decades of corrosion.
    i suggest a possibility solution for you to look then possibly remove all instruments AND theor sub-loom to clean up all connections.
    These extra connectors make original production easily for Ferrari but really add headache to user now
    PDB likes this.
