Daytona engine rebuild - how many HPs would you expect? | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by Italian Tuneup, May 6, 2020.
  1. Italian Tuneup
    Italian Tuneup Karting
    Apr 16, 2019
    81
    Europe
    Stefan
    My Daytona engine is in the process of a complete rebuild. At the end it will be bench tested.
    Everything has been made to original specification. No high compression pistons or hotter cams.
    It´s a euro spec engine.
    How many HPs would you expect?
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    9.3:1 compression ratio?
    No more than 350 bhp.
    Matt
  3. Italian Tuneup
    Apr 16, 2019
    81
    Europe
    Stefan
    Yes standard compression but with forged pistons and new rods.
  4. Smiles
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    Neither gets you more horsepower.
    Matt
    Racer_X, chuckbrandt and turbo-joe like this.
  5. gcalex
    gcalex Formula Junior
    613
    Mostly New Hampshire USA
    Alex
    If we are talking about a bench dyno, I've seen a curve (claimed "stock", but possibly jetted in some way) that went into the 370 range, but dynos are notoriously variable, so I would not get too hung-up on the exact figure.
    Did they dyno the engine before they tore it apart? That comparison would be the real thing that would be telling..
    If not, perhaps they have some curves of other engines that they have done, so that you could see that things were at least typical for their shop.
    hagen111 and turbo-joe like this.
  6. Smiles
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    Although there was a reason for rebuilding the thing.
    Matt
  7. gcalex
    613
    Alex
    Well, yes, if it had failed in some big way, then yeah, "before" might not be so interesting... :)
    Daytonafan likes this.
  8. Italian Tuneup
    Apr 16, 2019
    81
    Europe
    Stefan
    Yes they have a bench dyno with a separate control room (don´t know the correct english term for this setup)
    They did and do a lot of vintage Ferrari engines and will not rebuild your engine without testing on a dyno. So they have a lot of curves from stock and race Ferrari engines.
  9. TTR
    TTR F1 Veteran
    6,097
    Riverside, CA
    Timo
    Stefan, IIRC, pre-rebuild dyno testing was not a reasonable option in your case...
    ... besides, the HP/Torque will be whatever it is and probably sufficient.
    P.S. Would you mind sending me an email or PM about the discovery of "the cause" ?
  10. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,108
    be sure to dyno with air filter box and air filter box off. there will be a difference.
    also suggest testing with premium fuel and again with 100 or 110 octane racing fuel.
    turbo-joe likes this.
  11. westextifosi
    westextifosi Formula Junior
    274
    Lubbock, TX
    Tex Timberlake
    How much difference would you expect to see using 110 race gas given 9.3:1 compression?
    Racer_X likes this.
  12. Edward 96GTS
    11,108
    its not the comp ratio that matters, its the ethanol vs non ethanol. here in cali we only have 91 octane w/ 10% ethanol and 100/110 octane race fuel(non ethanol) as options.
  13. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,593
    Grant
    Do you really want them to rev the nuts of your newly rebuilt engine? sure test it and run it in a little but I would give it 500 miles or more before revving it so much.
    PrecisionMike likes this.
  14. westextifosi
    274
    Lubbock, TX
    Tex Timberlake
  15. Edward 96GTS
    11,108
    every good engine shop dynos a fresh engine.
    if it breaks let it break while in their hands. also good way to check for leaks.
  16. gcalex
    613
    Alex
    As noted already, it is probably better to have the engine spin a bearing while still in the shop... :)
    But also, doing a few dyno-pulls is also the best way to check/tune the set-up of the engine, and it is a lot easier to do that sort of thing on a bench dyno, than on a rolling road dyno...
  17. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,064
    This entire discussion may be fun to talk about, but it is absolutely useless. Like the saying "statistics don't lie, but statisticians do", dyno's give real numbers, but dyno operators lie all the time. If you tell me how much power you want your engine to make on the dyno, I can guarantee I can get the dyno to give you that number. It is all about the "correction factor". Every dyno should be calibrated before a motor is tested. The operator inputs the ambient temperature, engine air inlet temperature (carb air temp), fuel specific gravity, barometric pressure and other variables. All this data becomes the "correction factor" which converts the raw torque and bhp readings to a "standard" number. This number provides consistency and allows for the normal variances in weather, etc.
    By manipulating these numbers, a dyno operator can cause the results to vary widely and produce whatever power he desires. For example, we purchased a 275 Comp Car that had a "special" motor. The dyno sheets that accompanied the engine showed 404 bhp at 8,400 rpm. That would be a "very stout" 275. Upon careful examination of the dyno sheets, i noticed a "strange" correction factor was used. In specific, the barometric pressure was very low. Actually it was similar to that found in the eye of a hurricane. I checked with the airport in the town where the dyno was located and asked them for the pressure on the day of the dyno test and, you guessed it, the actual pressure was MUCH higher ( Milwaukee, WI doesn't have many hurricanes). When we pulled the engine and ran it on our dyno, it made 348 bhp, still a VERY STRONG 275, but no where close to the "reported" results.
    All the above illustrates is that dynos are only good for ONE THING, comparing and evaluating changes back-to-back. You can make a carburetion or cam timing change and then make another "pull" and the dyno will tell you instantly if the motor liked it or not. Obviously, testing fresh engines on the dyno is much easier then installing them in a car and then finding all the water and oil leaks.
    With the above said, absolute power and torque numbers can have some relevance IF the dyno operator always sets up the runs conservatively and accurately with his Correction Factor inputs. Still different dynos will give widely ranging results. Trying to compare engine outputs from different dynos is truly apples and oranges. It just cannot be done with any reliability.
    With all that said, my GUESS is the gentleman's Daytona motor should be considered a success if an conservative and correctly set up dyno shows anywhere from 320-350 bhp.
    As to breaking-in motors before dyno testing. We get the motor running, make initial timing and carburetion adjustments, and run the engine at varying rpm (up to about 3,500) for 30 minutes and then commence the power tests. We run as many tests (pulls) as required to test all the various ignition and fuel combinations as well as sometimes cam timing changes. These can be a few a 6-8 pulls with engines we are familiar with, to over 20 pulls ( you think you are going to wear out the motor on the dyno) with engines that we have a lot of variables to investigate. In EVERY case over the last 30 years, we have ended the day with at least 10-15% more power than we started, thanks to being able to evaluate each change quickly on the dyno.
    PDB, -K1-, john a barnes and 20 others like this.
  18. Ak Jim
    Ak Jim F1 Veteran
    9,794
    North Pole AK
    I could just imagine a pre-rebuild dyno test where the engine drops a sodium filled exhaust valve during the test.
    christc and turbo-joe like this.
  19. TTR
    TTR F1 Veteran
    6,097
    Riverside, CA
    Timo
    No different than dropping one while driving.
    Well, come to think of it, actually dropping one while driving could result to more severe consequences.
  20. Terra
    Terra F1 Rookie
    3,940
    Isn't the stock compression ratio 8.8:1 ? (both for Euro version and US)
  21. TTR
    TTR F1 Veteran
    6,097
    Riverside, CA
    Timo
    I thought U.S. spec. is 8.8 and Euro 9.3, but having never actually measured either myself, can't say for sure. I did (and measured) one with 10.0.
  22. christc
    christc Formula Junior
    470
    Germany
    Pre not post...!
    Fully agree. I would not want to test an engine of unknown state before a rebuild on full load on a test bench. To many unknowns. Post rebuild any time. It is the best way to check if you succeeded in having a healthy engine.
    Ak Jim likes this.
  23. TTR
    TTR F1 Veteran
    6,097
    Riverside, CA
    Timo
    Oops, perhaps I shouldn’t have revealed that, as it may give someone an idea that I actually don’t know anything about vintage cars, let alone 365 GTB/4s. :oops:
  24. Terra
    Terra F1 Rookie
    3,940
    I'm fairly certain US and Euro Daytona all have identical pistons (and compression ratios). Aside from the differences in emissions equipment and exhaust systems, I believe the only thing major mechanical difference are some slight changes to the carburation.
    TTR likes this.
  25. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,064
    Terra Is correct. Same pistons per Parts Catalog, and 8.8 to 1 compression per Factory Build Sheets.
    TTR likes this.
