Daytona Footwell Lights | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by PDB, Sep 23, 2023.
  1. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    Hi,
    Can anyone advise on where I can get the small round footwell lights used in the Daytona footwells. Neither of mine work and they don’t appear to be repairable.
    I can’t imagine they were unique to Daytonas, so what else were they used in?
    Thanks,
    Paul
  2. Edward 96GTS
    Edward 96GTS F1 World Champ
    BANNED Silver Subscribed
    Nov 1, 2003
    11,097
    found mine in europe. sorry cant remember shops name. old timer ferrari parts place.
  3. gcalex
    gcalex Formula Junior
    607
    Mostly New Hampshire USA
    Alex
    Are you sure they don’t work?
    Sometimes the “brushes” in the internal switch are just oxidized, and some repeated rotating of the clear plastic lens will bring them back...
  4. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I don’t think the lenses in mine rotate.
  5. gcalex
    607
    Alex
    That is what a lot of folks think; which is why I asked about it… :)
    Assuming you have the original lamps…
    …if you look at the sides of the clear lens, you will see that it has curling on it (rather than being smooth); this is so that you can grip it to rotate it. Inside the lamp there are actually brushes that rotate with the lens, and allow you to manually turn the lamps off, even if the door is open.
    You will also see that there is a metal clip on the back of the lamp that you can pull-out (comes out sideways, and looks like a little trident once it is out, if I recall correctly). Once the clip is out, you can access the bulb and replace it if it is burned out; though frankly, it is unlikely that the bulbs have gone on both sides, and it is far more likely that some previous owner turned both the lamps off (which is why I suggested giving the lamps a few turns as a first step).
    So if you still have original lamps, it is not likely that you need new ones.
    readplays likes this.
  6. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I hadn’t considered that they had integral switches, I’ll give it a try.
    Thank you.
  7. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I have checked and you are correct, they do rotate, although they still don’t work. I think the internals are probably corroded.
    I have also checked all the usual suppliers and none of them have any.
  8. gcalex
    607
    Alex
    Ok, so it sounds like you have the original lamps; when you rotate them, you can feel the little "detents" of the switch mechanism right?
    If so, when you open the doors (open both at the same time, just for good measure), do the red lights on the ends of the doors light up? If not, then the problem might be the push-button switches at the front door jam; pull each of them outward with a little force, and see if that brings the door lights back; once the door lights are lit, then try rotating the footwell switches.
    Alternately, just put a volt meter to the leads of the footwell lamps and make sure they are getting 12 volts.
    If you are getting voltage, but lamps are still not lit, just pull-out the little clip that I mentioned, remove the bulb, put the clip back, spray some Deoxit in there, and work it around by rotating the lens; and obviously replace the bulb if somehow it has burned out. This should clear-up any contact corrosion. The mechanism is really simple, so I really doubt that you actually need replacements...
  9. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    Thank you for you detailed and expansive reply, it is much appreciated.
    One of the lamps eventually rotated, but there is no discernible detent and it feels rough. The other won’t rotate at all. The bulbs appear to be soldered in at the back, so I’ll need to unsolder them before I can remove and check them.
    The red lamps on the rear edge of the doors work fine.
    Paul
  10. gcalex
    607
    Alex
    It sounds like someone has mucked with yours, or maybe they are not original afterall.
    Can you send pictures?
  11. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    They are definitely original, they’ve just seen better days.
  12. gcalex
    607
    Alex
    Cool. I don't see any soldering there, and it definitely looks original.
    So in the lower picture, the metal tab/terminal to the left actually pulls-out sideways; you might find that it is a little stuck, and putting a little oil on the contact-point between the bulb end and the tab/terminal metal might let it come-out easier.
    Once that little metal piece is out, the bulb just drops out.
    With all that stuff out, you can look inside and see how the "rotating lens" switch works, and where you need to hit with some Deoxit (to clean the contacts).
    If everything is rusty inside, it might be hard to rotate the lens, but just hit everything with a little Deoxit (or some type of "penetrating oil"), and the internal-switch mechanism should free up.
    Sergio Tavares likes this.
  13. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
  14. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    Ahhh….I can now see that the “collar” is part of the switch, but I still can’t get the bulb out.
    Is there a way to get the other contact out?
  15. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I’ve got the bulb out.
  16. gcalex
    607
    Alex
    Yikes, that solder should not be there. I get that the contact and the collar can be a little "touchy", but I still can't imagine how someone thought it was a good idea to apply solder. May be they wanted to be extra sure that the lights turned-on for some judging or something... :)
    The only way to get the rest of the mechanism out is it bend-up the back-side of the chrome bezel. Once you free the bezel, the whole thing comes apart. Unfortunately, the bezel will show some distortion after you put it all back together, however, so I would not recommend trying this, unless you have a spare to replace it.
    I think you can see how the mechanism works now. With a little tinkering, you should be able to get it working.
    Just let me know if you find something else puzzling, as I would be happy to pull mine and open them up to check stuff...
  17. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    One of the units now rotates pretty freely now, but the other is still siezed.
    Once I was able to get the bulbs out, I could see how they work. I'm going to buy an ultrasonic cleaner and see if that will free the other one up. If nothing else, they'll get a good clean. :)
    Thanks,
    Paul
  18. gcalex
    607
    Alex
    It is sort of a cool little design, right?
    I probably should do the sonic cleaner as well, while mine look ok, no one accuse them of looking brand new... :)
    I've often wondered how many of these were binned, because people did not realize that they had a switch and/or it was possible to change the bulb...
    PDB and readplays like this.
  19. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    The good news is that both now rotating freely. The not so good news is that the centre fell out of one of the lenses, so I'll need to glue that back in again.
  20. gcalex
    607
    Alex
    Wow, learn something new every day; I did not realize that those were two piece lenses...
  21. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    The mechanical parts cause problem with the eletrical route.
    Use a good penetrate oil and much soaking time
  22. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I'm not sure that they are. It looks like the centre just brokek out. The plastic is very thin at the base of the groove on the outside of the lens and I think it has just fatigued and cracked. I have glued it back in with UV resin, which is brilliant and the lamps are now working again.
