Daytona Heater Core | FerrariChat
Daytona Heater Core
Discussion in 'Technical Q&A' started by ehs308, Feb 9, 2012.
  1. ehs308
    ehs308 Rookie
    Mar 29, 2011
    49
    I am in the process of refurbishing the cooling system (hoses, water pump rebuild, radiator pressure test etc.) on my 1973 Daytona and would also like to have the heater cores tested as well. It appears that on the left side heater core housing there is a small bracket which the washer pump affixes to. The bracket looks to be tack welded to both the core housing and the metal shroud on the firewall to which the brake booster's cast frame is attached. I have located both the upper and lower bolts that secure the heater core housing in place but I'm not sure how the housing is removed given the above noted bracket. Wondering if anyone has removed their heater core and can offer any advice? The right side core housing removal seems fairly straight forward. Any suggestions would be much appreciated.
  2. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    I believe you have to take out the front wheel wells that are riveted in and drop from the bottom. Drew
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    The one I restored had two brackets on each core housing, one top and one bottom. I do believe the fender well liner will need to come out to remove the box. I'll try and see if I have any pictures.
