Daytona Hood replacement struts- | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by stephenpdean, May 29, 2007.
  1. stephenpdean
    stephenpdean Rookie
    Jul 10, 2004
    6
    Has anyone found a modern gas shock/strut replacement for the Daytona hood support? If so, must any part of the Daytona be modified? (I had rather not modify anything on the car.)
    Better yet, can the originals be rebuilt? Is there a source to rebuild the originals? Note: Kimmerly Brothers, which has been mentioned as a rebuild source, has gone out of business.......completely! I've tried the hydraulic rebuild shop at Quinn Catapillar, and they were interested in doing it, but after several days said they could not do it. They could not remove the snap ring on top , which IS very small.
  2. Telerding
    Telerding Formula Junior
    Sep 30, 2004
    362
    Santa Maria/CA
    Tom Elerding
    You can try reoriginals, at www.reoriginals.com. Like many things on their web-site they are listed as not in stock. But one would hope that they will be in stock in a reasonable time.
    Post on www.daytonaregistry.com. Someone there may have more up to date info on alternate sources.
    Good luck
    Tom
  3. shill288
    shill288 Formula Junior
    Feb 24, 2005
    900
    West Coast
    Steve Hill
    Rod Drew "rebuilds" the hood struts. What that really means is he puts a smaller diamater strut inside the gutted Daytona "fat" struts. They perform great. Re-originals sometimes has reproduction struts that are very close, but not exact, to the originals. The pressure in the reproduction shocks are a bit stiff compared to the original units.
    Boge also makes a strut, although much smaller in diameter to the original strut, that works great functionaly as well.
    The above thoughts are from personal experience with all three.
    Steve
  4. choll
    choll Rookie
    Oct 2, 2006
    6
    San Diego, CA
    I have a Maserati Bora and the struts for the rear lid look very similar to the Daytona. I expect a company that can rebuild the Daytona ones (or C4?) could rebuild the Bora ones too. I'll try Re-originals, but has anyone found other sources?
  5. TTR
    TTR F1 Veteran
    5,893
    Riverside, CA
    Timo
    I’ve rebuilt several sets of OEM Daytona struts and fabricatereproduce Concours correct replacements for them also.
    I have no experience with ones for Bora, but if they’re exactly same as Daytona, I might be able to help.
  6. choll
    choll Rookie
    Oct 2, 2006
    6
    San Diego, CA
    Thanks. I can send you some detailed photos when the car comes back from the shop. I just took it in for some minor repairs/touch up work yesterday, after one of the original 1973 tires blew up when I foolishly tried to drive the car. :( It now has five new XWXs.
  7. 1monza
    1monza Formula Junior
    321
    Manhattan Beach, CA
    Norbert Hofer
    If you still have the original hood strut you can have them rebuilt. Their are a couple of places in Canada that can rebuild them. Just Google gas spring, gas strut or lift support.
    V12addict and 375+ like this.
  8. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    lots of aftermarket replacements but no rebuilders
  9. Dogdish
    Dogdish Formula Junior
    Dec 27, 2005
    367
    Denver
    Frank at Strutwise did mine quite a few years ago. I just googled him, still in business up in British Columbia.
  10. jnk
    jnk Formula Junior
    Nov 12, 2010
    345
    PM sent
  11. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    Thank you dogdish
    a long way from me but a possibility.
  12. choll
    choll Rookie
    Oct 2, 2006
    6
    San Diego, CA
    #12 choll, Sep 30, 2023
    I've attached a photo of one of the Corte & Cosso struts. It's about 775 mm long (between eye centers), and 40mm in diameter with a 11.5mm shaft. It has this stamped in the body:
    Corte & Cosso
    ESP 99 05565
    9 HN K 7​
  13. Edward 96GTS
    Edward 96GTS F1 World Champ
    11,087
    ^ the attachment piece at the end of the shaft is incorrect.
  14. choll
    choll Rookie
    Oct 2, 2006
    6
    San Diego, CA
  15. Edward 96GTS
    11,087
    ^ what are you asking?
  16. Regular Guy 01
    Regular Guy 01 Formula Junior
    564
    Tacoma, WA
    Eugene Greer
    Frank at Strutwise is my go-to guy for all my strut work.
    He has rebuilt struts for my Mercedes SL55, my Ferrari 458 spider and my Acura NSX.
    When the wife and I visit Vancouver for vacations, I enjoy stopping by his shop and chatting him up. I will also drop off struts and pick them up on the way back home. He is truly a great guy and a good friend. On my last stop through, he even showed me a Daytona strut that he rebuilt. I had bever seen one before and all I could think about was how big it was....... I did appreciate the car it was from and the life it has lived.
    He, like all of us is getting older every year and his health isn't the best. If you need his services, get it done sooner than later. Tomorrow might be too late.
    I will miss him when that day comes.
    HTH,
    GG
  17. swift53
    swift53 F1 Veteran
    8,294
    E.S.
    Alberto
    I had mine restored. Barely 1 month.
    Frank is a terrific guy!
    Regards, Alberto
    Regular Guy 01 likes this.
  18. Edward 96GTS
    11,087
    when?
  19. swift53
    swift53 F1 Veteran
    8,294
    E.S.
    Alberto
    In November, during a moment of health improvement for Frank.
    Please note that it was utter alignment of the stars, and it does not mean you will get the same results.
    When someone is ill, you have to take that into consideration, right? :)
    Regards, Alberto
    turbo-joe likes this.
  20. Edward 96GTS
    11,087
    unfortunately his health is failing.
  21. TTR
    TTR F1 Veteran
    5,893
    Riverside, CA
    Timo
    Unfortunately the Canadian outfits took (read stole) my 2+ years of R & D after I commissioned one of them to produce components for my replacement struts, even after promising not to steal my ideas.
    Goes to show how much or little someone’s word is worth.
  22. TTR
    TTR F1 Veteran
    5,893
    Riverside, CA
    Timo
