Daytona Koni Details | Page 2 | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by murphyrg1, Nov 16, 2021.
  1. gcalex
    gcalex Formula Junior
    547
    Mostly New Hampshire USA
    Alex
    Interesting.
    I've added your raw JPEG to my earlier composite pic:
    I don't see any Koni decals on the shock.
    Do you recall whether they were "wings"?
  2. readplays
    readplays Formula 3
    Aug 22, 2008
    2,350
    New York City
    Dave Powers
    Sounds like Rosso Chiaro to me. :p
    BMWairhead likes this.
  3. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    For what it's worth, I don't recall any decal... :confused:
    ... but will look into my photo archives when I get a chance.
    OTOH, I do have two paint samples and related references marked "Koni shocks", but won't (at this time) share details of either here. Sorry.
  4. gcalex
    547
    Alex
    Interesting connection to make.
    As it turns out, not so much Chiaro, as Dino:
    Cloudy here today, so could not get a shot in full sun, but as you can see, there is an argument that Rosso Dino is a candidate that has some merit. Particularly as it has more of an orange-cast under indoor lighting. If one had a source of a good Rosso Dino formulation, it would be worth trying if you wanted to stay toward the orange-direction of the possibilities.
    Since I can anticipate some "your Rosso Chiaro is way too dark" comments, I included two shots of my Chiaro car under different lighting conditions, so that folks could see that Chiaro can vary a lot in different photos.
    turbo-joe likes this.
  5. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,302
    the problem with orig koni pix 50 yrs simce manufacture is that the paint becomes more brownish with aging. hence the redder appearance.
  6. gcalex
    547
    Alex
    Well, generally things don't spontaneously change color unless subjected to some sort of energy, typically either heat, or light. The 50 year old Koni that I have does not show much evidence of being exposed much to either of these.
    Of course, the pigments might just be unusually unstable (from a chemical standpoint), but if that is the case, then there is no way to verify it, because all truly original shocks would now all be the wrong color... :)
    Personally, I think manufactures care much less about the colors of the paints they use than folks think, and they certainly update their colors all the time to "evolve with the times". So the fact that modern Konis are orange does not really say much about the state of things 50 years ago. And if Koni themselves have spent a long time rebuilding vintage shocks with modern colors, then things get really muddled.
    At the end of the day, photos are not reliable color indicators, and the memories of people "who where there" are pretty unreliable as well.
    So while actual paint samples are not necessarily perfect, I think they are the best that we've got.
    At the very least they give an indicator of what true "time capsule" car would look like.
  7. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    Have you ever had an opportunity to observe and really pay attention to, let's say, 5-10 Daytona's, all red and according to their respective owners, all or majority being "Rosso Chiaro" lined up next to each other at a concours or a show of some sort, only to realize most or none actually color match each other ? ;):rolleyes:
  8. Edward 96GTS
    9,302
    im sure someone on a porsche forum would have the exact paint code considering how anal they are. forget about pix on a website.
    readplays likes this.
  9. gcalex
    547
    Alex
    Oh, absolutely... :)
    The only reason that I say that my car is Chiaro, is because it is pretty close the the paint sample that I've got.
    Now I admit that paint samples may not be definitive, but like I said in my previous message, I think they are more reliable that pictures or memory... ;)
  10. Edward 96GTS
    9,302
    best if somebody can send you an orig shock to color match.
  11. gcalex
    547
    Alex
    #36 gcalex, Dec 18, 2021
    Well, paint-codes from 50 years ago are pretty meaningless; the pigments from those formulations just are not available any longer.
    Of the Porsche folks trying to match samples, the most credible conclusion (based on my surfing) is that RAL 3013 (if you want the evidence-supported color) or RAL 2002 (if you want something that won't totally offend folks who think the color should be "orange").
    But again, it is possible that the Koni shocks were not painted the same color as the Ferrari ones.
  12. Edward 96GTS
    9,302
    this thread is reading more like a thought
    exercise than a practical solution to a problem.
  13. gcalex
    547
    Alex
    Well, like I said, I managed to get a hold of a GTC/4 shock that looks original; it's pretty close to RAL 3013.
    So why don't I just use that color on my car?
    I'm just not sure that I am willing to endure the "slings and arrows" of folks saying that if I had a time machine so that I could see the paint before it aged 50 years, I would have painted them orange... :)
    Kidding aside, I'm not saying that folks that go with some form of an orange are "doing it wrong"; frankly, I think folks should use whatever color they think looks good to them. I certainly totally get why one would use a color that would reduce the chances of some show judge giving one a hard time.
    I just think it is sort of interesting that there seems to be plenty of evidence that is contrary to the general assumption that Konis should be orange.
  14. gcalex
    547
    Alex
    In my mind, the solution was provided when that GTC/4 shock came out of the box.
    I agree that all the rest is a tangential discussion about the pitfalls of trying to figure-out colors when one does not have a sample that seems reliable.
    A potentially useful tangent, since I think that not that many folks have samples to go by...
  15. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,046
    San Francisco Area
    John Vardanian
    #40 John Vardanian, Dec 18, 2021
    Most people use this.
    john
    V12addict and Edward 96GTS like this.
  16. gcalex
    547
    Alex
    Hi John,
    Many thanks for the concrete reference to a specific "rattle can"; I don't have convenient access to a "paint guy" to do custom matching, so ultimately, I need something that is more-or-less off the shelf.
    A visit to a couple of local car-parts places yielded two cans labeled "Chevy Orange-Red"; the Duplicolor DE1607 that you cite, and VHT SP119.
    I shot samples of both, and got the following (also adding a pic that I got from Performance Shocks for comparison):
    To my eyes, the Duplicolor is not as vibrant a color as the Dino shock, or the Performance Shocks (PS) shock, or even the 2002. It is also a touch more orange than the 2002. It is an interesting choice of color, because it is not bright like the more modern Koni color, but still most folks would say it is definitely a kind of orange.
    Interestingly, the VHT is a tangibly different color; much more kindred to 3016 (though a bit lighter). And unlike the Duplicolor (or 2002) it never seems to "go orange" under any lighting conditions that I tried. The VHT is a better match to that 71 GTC/4 shock.
    The PS shocks look like they are likely painted something similar to the Dino shock; i.e., something a bit more orange than the 2002.
  17. John Vardanian
    Jul 1, 2004
    3,046
    San Francisco Area
    John Vardanian
    You are welcome, Alex. Times like this I tend to pick the "prettier" one of the two. But, there needs to be a hint of orange.
    john
  18. DZ-96
    DZ-96 Formula 3
    1,782
    South Germany
    Daniel
    Hi Guys
    Only for information
    Daniel
    Suspension ̵ Centre is a company based near Amsterdam , as an official Koni service center we can refubish every original shock of this mark build since 1958.
    As many Ferari and Maserati cars built after 1963 were provided with the Koni Oem shock, we are having all the data to get every Koni build shock as they were new, or even better.
    All the shocks and springs leaving our company are powder coated, no paint. In most of the cases we make some technical improvements also, whitch are only inside the shock.
    Kurval NL
    Mark Holthuis
    Director
    +31 (0)252 676 080 / +31 (0)6 53 74 94 45
    [email protected]
    Pondweg 15, 2153 PK Nieuw Vennep (NL)
  19. Edward 96GTS
    9,302
    once you decide on the color then you need to determine the scheen. it never ends
  20. murphyrg1
    murphyrg1 Karting
    96
    San Luis Obispo, CA
    Rory Murphy
    Alex,
    To continue beating this dead horse...
    I was just visiting a friend who was completing his restoration of a Koni equipped '67 Shelby. When the talk turned to Koni paint, he said that several of the Shelby guys have been using a VHT SP503 rattle can paint which is sold by NPD as Early Koni paint - VHT just calls it Bright Orange. I was not convinced, but he sprayed a test panel over medium grey primer and it actually is pretty close to the '73 911 strut that I have. The photo is in direct sun and the VHT actually appears a bit more red in person than it does in this photo, but it is close to the original Porsche Koni color.
    Your VHT SP119 Chevy Orange test panel appears to look the same as my Bright Orange panel but is also seems more red than what I would consider Chevy orange. Does your test panel photo do a good job of representing the actual color? My rebuilt shocks have just arrived back from Performance Shock in primer and I have to get serious about selecting a color.
    Thanks,
    Rory
  21. gcalex
    547
    Alex
    Hi Rory,
    No one likes a dead horse more that I do...
    Are those pictures supposed to be SP503 and SP119, respectively? At least on my computer, I don't note any difference between them.
    Presumably the red cylinder is a tube from your 911 strut, right?
    I really can't vouch for how my pictures look on your computer screen.
    Here is what I get when I put your photo and my "full sun" pics in a single image:
    On my computer, your top pic looks very similar to my SP119.
    But your earlier pic of the 911 strut looks orange on my computer, and SP119 is not orange at all (at least to my eyes).
    I'm on a trip at the moment, but head home early next week.
    Once I get back to my garage, I'd be happy to shoot a panel of SP503, and add it to my comparison stack-up.
    Cheers,
    Alex
  22. murphyrg1
    murphyrg1 Karting
    96
    San Luis Obispo, CA
    Rory Murphy
    Alex,
    First, I don't know why two pictures were uploaded on my last post, but they are identical. Secondly, I'm beginning to see why this exercise is so fraught with various opinions of which color is closest to be correct. You're right on a couple of points: your VHT SB119 looks very like my SP503 on my computer, too. It appears to be a brick red with very little orange in it in both cases. It's so similar (on my computer, at least) that one wonders if they could be essentially the same formula - which I realize makes little sense.
    Your also right about my 911 strut - it does look more orange than this photo depicts. Attached is a photo taken in indirect sunlight that more closely represents it. I took yesterday's comparison photo in direct sun to try and be more consistent with what you had already done so well. When holding the SB119 test panel next to the 911 strut, they appear close to each other with the test panel being a bit more red than the 911 strut. Which seems to be at least in the right direction to approximate many of the photos that have been shown in this thread. But I'm also seeing differences in color with the same image viewed on my phone vs. my laptop vs. my desktop, so I'm starting to question my ability to select a color that is not in front of me. You've had many of these colors in front of you, what direction are you leaning?
    Regards,
    Rory
  23. gcalex
    547
    Alex
    Hi Rory,
    Well, of all the "these are original shocks" that I have in my possession (4 different ones), the one that to my eyes has the strongest evidence of actually being original is that 365 GTC/4 shock, and that shock does not give the impression of being "orange" under any lighting condition that I've tried.
    If I were to try and match that shock, I would go with the RAL 3016 (though I have to admit that there are some other RALs that are close, and I do want to try and check them out under different lighting conditions).
    If I had to grab a rattle-can today, then that VHT SP119 also like RAL 3016 is "not orange", and it has the advantage that it is a bit brighter, and looks more "dressy".
    But...
    ...many folks seem to think that these shocks should give the impression of being at least a little "orange-ish", so near as I can tell, my opinions about the color are a distinct minority, and my guess is that if one goes with my leaning, you are setting yourself up for an argument with some show-judge in the future.
    This last point probably does not matter for my car, because it is unlikely to ever get to a Platinum standard, but it sounds like it might be a consideration for your car...
    BTW: I got stuck on the West Coast for a couple of extra days, so wont be able to try and do a test shot of your VHT color until later this week.
    Cheers,
    Alex
  24. murphyrg1
    murphyrg1 Karting
    96
    San Luis Obispo, CA
    Rory Murphy
    Thanks one more time for the thoughtful response, Alex. I can understand your logic based on the info you have. I don't know if or how much we will show this car in the future, but I think the three of us that own this car are in general agreement that we would rather be correct than try to play to whatever opinion a judge may have in the future. Of course, it's easier to take that stand if you have some good documentation in hand from an original car or period photo - something we don't really have in this case. We may have to make a decision with info that is certainly incomplete and possibly flawed. At least with 3 of us, there won't be a tie.
    Rory
  25. Edward 96GTS
    9,302
    paint darkens with age. those old shocks should color sanded and buffed for a truer color.
    next up: gloosy or semigloss paint.
