Daytona oil hoses! Rebuilding sump hoses-correct metric hose?? | FerrariChat
Discussion in 'Technical Q&A' started by Bandonbound, Oct 28, 2016.
  1. Bandonbound
    Bandonbound Rookie
    Aug 13, 2006
    27
    Been going round and round trying to get the 2 365 GTB/4 Daytona style sump hoses rebuilt. Have the original taper/screw in fittings, would like to keep those if at all possible. Tried couple different hoses, nothing correct so far. Earls 14AN, guess is possible to make it work but not going to use. Found some metric hose, Cohline style, OD around 26.5 and ID 18MM, The Earls was 18mm ID and will not go onto taper without major issues. SO, does anyone have the hot tip on hose using the original fittings?? I at least want to get the short hose done, routed under the motor mount and starter so I can get the engine back in. The other long one is accessible so not that much worry. Drew A. and Bill B. have been very helpful with photos of routing etc. so that's ready! Also, has anyone used a totally new hose on the short one, with the kink fitting at the sump pan?? Is that kink totally necessary if someone uses new fittings?? Any help would be appreciated. Bandonbound in Ca.
  2. tazandjan
    39,176
    Try these guys. They do work for NASCAR and have done 575M F1 hoses for friends. They can do just about anything with hoses. Their F1 hoses were better than OEM and cost $140 for five hoses vs $550-900 each for Ferrari hoses.
    Goodridge
    (704) 662-9095
    174 Gasoline Alley
    Mooresville‎ NC‎ 28117
    United States
  3. Bandonbound
    Bandonbound Rookie
    Aug 13, 2006
    27
    I'll try Monday, you wouldn't think this would be a big issue but it sure is turning into that. many thank Bandonbound in Ca.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Tri Valley Hoses, in Livermore.
  5. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    I had mine rebuilt by a company in Indiana. Whoever does it its important for them to keep the correct orientation of the two end fittings. The steel braided hoses are quite stiff. If the other leads do not pan out PM me and I can look up the company name.
    Good luck.
    Drew
  6. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    GT Car Parts.
  7. Santino1
    Santino1 Karting
    Jun 4, 2014
    101
    Sacramento, CA
    Daniel
    http://r.search.yahoo.com/RV=1/RE=1477890687/RB=/RO=8/RU=http%3a%2f%2fwww.batinc.net%2fcoolers.htm/RS=^ADAy4yKCmfjlMoA45eQbT6sG3JcHJ8-
  8. TTR
    TTR F1 Veteran
    5,897
    Riverside, CA
    Timo
    #9 TTR, Oct 31, 2016
    I've rebuilt all oil sump hoses on several 365 GTB/4s re-using OEM fittings.
    Have patterns, variety detail options and also technical consultation, if needed, available.
    PM with contact info, if interested.
  9. Bandonbound
    Bandonbound Rookie
    Aug 13, 2006
    27
  10. Bandonbound
    Bandonbound Rookie
    Aug 13, 2006
    27
    Timo, David here, revisiting this Daytona sump hose issue. Has anything changed since we last spoke? Original style hose available or still Earls style with Earls fittings? I have the twist compression style ends but not that hung up on using the absolute original etc. thanks if you can help. I just need one, rear sump pan to bottom of radiator. Thanks David
  11. TTR
    TTR F1 Veteran
    5,897
    Riverside, CA
    Timo
    David, please forgive my lack of recollection at the moment, but you're welcome to call/email/PM me for further advise/assistance.
