Daytona oil pan removal | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by bighitter2, Mar 14, 2025.
  1. bighitter2
    bighitter2 Formula Junior
    May 7, 2005
    495
    virginia usa
    chuck coli
    I am going to remove my oil pan just to clean out any residue that maybe left behind after oil changes and replace the gasket , is this a straight forward job or is there anything i should be aware of..thanks Chuck
  2. TTR
    TTR F1 Veteran
    5,800
    Riverside, CA
    Timo
    It could be “a straightforward job”, but given that it’s to be performed on a 50+ year old car/engine with who knows what kind of care or by whom it has received during those 5+ decades, anything is possible.
  3. swift53
    swift53 F1 Veteran
    BANNED Rossa Subscribed
    Nov 17, 2007
    8,110
    E.S.
    Alberto
    You might want to check the integrity of the drain plug threads, really closely, and not have to repeat the job.
    50 year old car....
    Ever been inside the engine before, or rebuilt recently? Might check a bearing or 2.
  4. TTR
    TTR F1 Veteran
    5,800
    Riverside, CA
    Timo
    ... etc, etc ....
    swift53 likes this.
  5. bighitter2
    May 7, 2005
    495
    virginia usa
    chuck coli
    Thanks for the advise, i will take all of it in consideration when dropping the pan..
  6. swift53
    swift53 F1 Veteran
    Nov 17, 2007
    8,110
    E.S.
    Alberto
    Please show your findings as will be most illustrative to all concerned.
    Thank you.
