Daytona oil | Page 2 | FerrariChat
Daytona oil
Discussion in 'Vintage (thru 365 GTC4)' started by bighitter2, Oct 17, 2021.
  1. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,831
    Timo: My pleasure.
    TTR likes this.
  2. bighitter2
    bighitter2 Formula Junior
    May 7, 2005
    486
    virginia usa
    chuck coli
    Timo, thanks for the tip about quantity of oil to buy, however my car does not have a drain plug in the pan…have you ever seen that before? Chuck
  3. TTR
    TTR F1 Veteran
    5,191
    Riverside, CA
    Timo
    I haven't seen that, but there appear to be couple of different design/part numbers for the pan, so perhaps earlier ones don't have a drain plug ?
    OTOH, to drain the engine sump, maybe you could just unbolt the entire pan, clean sump screens, etc while it's off and re-install the pan with new gasket. Easy peasy.
  4. TTR
    TTR F1 Veteran
    5,191
    Riverside, CA
    Timo
    According to parts manual references, looks like some "early" production (Daytona) sump pans might've been made without drain plug.
  5. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,831
    If your sump has no drain plug. as long as you drain the tank as quickly as you can after you shut off the engine, you will be fine. Most of the dry sump Ferrari comp cars have no sump drain plugs. We get the oil hot, shut off engine, loosen the tank plug (removing the safety wire, etc.), refire engine to evacuate the engine sump, shut off, and immediately drain the tank.
    TTR likes this.
  6. bighitter2
    May 7, 2005
    486
    virginia usa
    chuck coli
    Thank you DWR46 a good idea, i’ll try it..Chuck
  7. TTR
    TTR F1 Veteran
    5,191
    Riverside, CA
    Timo
    You don’t initially drain the (hot) oil already in the tank before refiring to prevent any it getting sucked back to sump during (the brief ?) “evacuation” process ?
    Just curious.
  8. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,831
    Timo: I did not say that. I said "loosen" (not remove) the tank plug. I cannot count all the times I have fought a too tight drain plug and all the while the oil in the engine is setting there getting cooler waiting to drain out. We always make sure the drain plug is quickly removable before we refire the engine to get as much oil into the tank as possible before draining it.
  9. TTR
    TTR F1 Veteran
    5,191
    Riverside, CA
    Timo
    My apologies Dyke, I didn’t mean to suggest you having said or stated something.
    I was merely asking a question, but failed to make it clear and it wasn’t that important anyway.
