Daytona Parts | FerrariChat
Daytona Parts
Discussion in 'Vintage (thru 365 GTC4)' started by Maranello, Jan 3, 2013.
  1. Maranello
    Maranello Karting
    Mar 16, 2005
    106
    Afternoon all,
    Does any one know of a Supplier who has stock of the Under dash panel Lamps.
    1 either side,Approx 25mm Hole
    White with Chrome bezel
    Appreciate any help
    Also Fuse Box panel Cover, - Fibreglass panel
    S
  2. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,528
    Tuscaloosa, AL
    Drew Altemara
    Very hard to find the correct ones. Turn up on ebay occasionally. That's where I found mine several years ago. None of the suppliers had them.
    Good luck.
    Drew
  3. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    The Daytonsa ones are NLA. You could modify & use the 328 lights if you had to. They are smaller diameter though and have a black bezel.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,353
    Frederick, Maryland
    Brian Brown
    We tried for two years to find those lights. They are also used in the glovebox as well. Had no luck from any supplier. On the fusebox cover, it would be best to borrow one, and pull a mould from it to have a new one made. I have never seen those for sale anywhere either.
    Brian Brown
  5. Maranello
    Maranello Karting
    Mar 16, 2005
    106
    Thank you for all,
    Managed to Locate one of the Under lamps coming from Italy - + 2 328 Lamps coming from the netherlands,
    As for the Fuse panel cover, - getting it remade using one from another car i have here,
    Many Thanks
