Daytona poor running... | FerrariChat
Discussion in 'Technical Q&A' started by Tspringer, Apr 14, 2006.
  1. Tspringer
    Tspringer F1 Veteran
    Apr 11, 2002
    6,155
    I picked up my Daytona today from the mechanic. I took it to him for a general tune up. Check timing, adjust carbs, change oil, flush and change coolant, check/clean plugs.... He knows this car very well and rebuilt the engine in it about 15K miles ago.
    I took it to him to begin with due to the car running poorly. Upon hard throttle application, in 3d, 4th or 5th gear from a constant cruise, the car would stumble badly and act as if it was being flooded or such before eventually catching and then pulling strong to redline.
    The car also has a tendancy to foul its plugs. I have fought this running condition before along with the plug fouling. Once before my mechanic tackled this and the car ran great... but now were back to the same thing.
    I will try and describe better the exact nature of the symptoms. The car fires and idles fine. It pulls away from a stop fine, but sudden hard throttle application will induce a stutter. The car under hard throttle will bobble, stutter and act as if its being choked down. Then as it slowly builds revs for a moment it will eventually clear its throat and roar off. But it also fouls plugs. Not the same plugs consistently... but apparently most of them. When the plugs get fouled it will run on 10 or 11 cylinders.
    My mechanic says compression tests out good... around 175-180psi and within a 5% variance. I may also test the compression myself over the weekend.
    I called him on cell as I was driving home and discussed that the car was still behaving as before I brought it to him. He is going to come out monday and pick the car up, take it back to the shop and tackled it again.
    Any ideas on the problem?
    As I said, this engine has about 15K miles on it since rebuild. When it was rebuilt, it was balanced and blueprinted, the heads were ported and polished, larger stainless steel valves were installed, factory competition pistons and custom liners were used. It has hot cams, dual MSD ignition boxes. The timing checks out great.
    I have not dealved into the car myself due to time constraints. I am building a Porsche RSR vintage racecar and its currently scattered all over the garage, basement and parts of the house. So it has been my top priority relative to my free time.
    The issue seems carb related. I would guess something is up with accelerator pumps, main jets or something else that is causing it to dump far too much fuel upon initial throttle application.
    So.... what do you guys think???
    Terry
  2. Llenroc
    Llenroc F1 Veteran
    5,560
    Colorado
    Vern
    Terry, this is only an opinion but, I would agree on that it sounds like carburation too. excellerator pump concept but, in the reverse of what you are saying like they are starving the mixture a bit, too lean. You would think that those MSD boxes would keep those plugs clean in just about any combustion environment. I wonder if cam timing could be off? Just thoughts, Regards, Vern
  3. Rifledriver
    37,288
    Is it still using points to trigger the MSD's? Or did it get switched to an optical system?
  4. Tspringer
    Apr 11, 2002
    6,155
    If the car were running lean from accelerator pumps not working, the plugs would indicate a lean running condition. Instead, they are getting wet and fouled indicating the opposite. At least I think....
    Hmmmmmmmm Cam timing? Something worth checking I reckon.
    This really has me bummed out. I was very much looking forward to putting lots of miles on the beast this weekend. The weather will be perfect. Now, no honking V12 fun for me. :(
    Rifle: no points. Optical pickups inside the distributors.
    Terry
  5. Rifledriver
    37,288
    I vote carbs.
    The cam timing is an interesting point but you dont get any tougher Ferrari motor than the Daytona and timing just does not change without a human involved. It will retard slightly over time with chain strech but all in unison and not by a whole bunch in any event.
    I think the thing to do would be to get a really good look at the function of the accel pump operation. If it has gotten some dirt in the system the pump nozzles are small and several may be clogged, non return valves may not be working. Pump diaphrams shrink and start leaking with age etc. Look it all over.
    Float levels do change, ck those too.
  6. Llenroc
    Llenroc F1 Veteran
    5,560
    Colorado
    Vern
    Terry, sorry I was thinking from my old holley carb days on the acc. pump deal. How about float level in the carbs maybe they are too high or sticking.
    edit whoops Brian beat me to it.
  7. Rifledriver
    37,288
    Just for laughs also get a good look at all the progression ports and probe them to be sure they are not blocked.
    Does not fit all the symptoms but some similar ones.
  8. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    What heat range are the spk plugs and brand?
    Have the carbs ever been completely rebuilt dissassembled?
    If the butterflys are not perfect with the progression ports you'll get a stumble on take off.
    Sounds like a carb sync issue such as mixtures, linkages or possibly float levels.It takes some real skills to tune 12 Webers maybe get a mechanic more familiar with them.
  9. ParadiseRoad
    ParadiseRoad Formula Junior
    Mar 26, 2006
    538
    Colorado
    I agree, check the plugs for proper heat range. Too cold a plug is going to get wet and miss when the accelerator pumps richen the mixture.
  10. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Concerning the accel pumps you can check them by getting a small vial or plastic container wrapped in wire, give 2 shots of throttle and measure the appx amount of fuel for consistency in each, should be around 8ml fuel if I recall.
    Its interesting the car was in tune then out, carbs shouldn't just go out of tune unless bad fuel deposits from sitting or air leaks from somewhere , lead plugs, throttle shafts.
  11. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    The inconsistency is the clue here I think.
    Are you sure your fuel supply is trustworthy..... ie, water either in your tank or even from the outlet you buy it?
  12. Tspringer
    Apr 11, 2002
    6,155
    The car did not just go out of tune suddenly. It had slowly had the running get worse, and over the winter I didnt drive it as often as I should. Once, in response to the running issues I pulled and cleaned the plugs and it ran great.. until it fouled the plugs again.
    The plugs are a BP6 heat range... should be fine. The mechanic has 30+ years experience with Ferrari's and is ex-FAF. He rebuilt this engine previously. In his shop when I picked the car up were a 330GTC, Testarossa, 250GTL, 300SL Merc, several E-Types, Rolls Royces and other cars.
    When he got the car, he only drove it up the street briefly. He then took it back to the shop... changed oil, flushed coolant, changed thermostat, checked and set timing, cleaned plugs, ran the car to temp, set mixture and balanced carbs. He says it ran great then.
    I went and picked it up, spent 20 minutes crawling in traffic to get to the highway, sat in a parking lot at idle, and by the time I got on the entrance ramp the plugs were fouled again and/or unable to keep up with all fuel it was dumping.
    I really think it has to have something to do with accelerator pumps, butterflies, progression ports.... something, or more likely several things, in the carbs.
    The carbs have not been fully rebuilt in probably 20 years. So they may be due for a full going through.
    The mechanic is coming to my home to pickup the car monday morning. (His shop is an hour away). He is going to take it back and tear into it... so I am going to leave it be this weekend.
    I am going to share all opinions with him however and I do appreciate all the ideas!!!!
    Terry
  13. mlflotus
    mlflotus Rookie
    Jan 24, 2004
    32
    60015
    I had a six carb alloy 275 that did the same thing for 20 years. Never did get it to run 100% unless I featherd the throttle slightly. Always thouht the car was over carburated even though it was stock. It did run better without the air filter & just velocity stacks( the same velocity stacks I sold you a while back).
  14. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    I know they are not the same Webers, but do the carbs on your car have the air bleed jets in them like the carbs on boxers do? (I might need a little help on the correct terminology here, as I’m still new to Webers.)
    When my car was exhibiting the same symptoms as yours, I found a tiny bit of something in two of these jets. After blowing them out, and cleaning the fouled spark plugs, the car ran like a top again.
  15. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    For my 77 308, going from a 6 heat range plug to a hotter 5 plug appeared to get rid of a slight miss-fire, an oily fuel smell and a sooty exhaust.
    I think Ferrari recommended colder plugs expecting their cars to be tracked or at least to use a lot of high power. With modern road conditions, speed cameras and so on, this is sadly not possible much of the time.
    It maybe that the hotter plugs just perform better with not perfectly adjusted carbs.
    In any case there seems to be no disadvantages in going to a hotter plug. Pre-ignition or pinking is apparently not a problem with these low compression engines (Daytona also?).
    Richard
  16. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Those are the idle jets John, the air bleeds have a nut on them.
    I agree on going to a hotter plug bp5es, the traffic is probably what fouled your plugs a hotter plug will prevent this.
  17. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    Thanks J.P. like I said, still learning.
    So in my previous, substitute ‘air bleed’ with ‘idle jets’.
    Whatever they are, getting the tiny pieces of whatever out of them made a tremendous difference, and I assume it might well pertain to Daytona carbs as well?
  18. Tspringer
    Apr 11, 2002
    6,155
    I also see little reason to not try a hotter plug and I will be having the Bp5 plugs installed.
    I am also wondering if a bad coil or something not spot on with an MSD box could be an issue?
    Terry
  19. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Nah, from what I've read BP5ES is the best plug for older V12 Ferraris, BP6s can foul, according to the experts quote "a colder plug is the sign a wanker worked on the motor", this was from Tony P in Forza also agreed byPatrick Otis.
    I am thinking of going to a BP5ES in my BB as well from a BP6ES, I avoid driving in town so haven't had a fouling issue especially since I replaced my wires with Beru Porsche 911 style screw on extenders but I think they are better as the plug runs a bit hotter so it keeps things clean.
  20. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Depending on what cross reference manual you read, the original champions cross over to an NGK 7 or 6.
    I used 7's for years until I came to Oz and leaded fuel dropped out the market, and since then use 6 as std fitment, 7 in high compression engines (used to use 8's) and 5's in city cars.
    5's on track or in competition will melt the tips.
    Examine the plugs closely, or even post close up photo of the tips here... oil contamination, bad fuel, overheating of tip (wrong plug for use/timing) etc can be quite easily identified.
    Check NGK website too, for photo's.
  21. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Get away from ES, try EY.
    Same price, grooved tip.
  22. F SPIDER
    F SPIDER F1 Rookie
    Jan 30, 2002
    2,873
    NYC, A'dam, W'stock
    rijk rietveld
    Terry,
    I had the same after a major service of my (ex)Daytona. WWoC checked everything and could not solve the problem. Later it turned out to be a tank of bad gas. Maybe you want to check this.
  23. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,537
    Tuscaloosa, AL
    Drew Altemara
    I would clean the idle jets just in case. Easy to pull and clean.
    I would also get a buddy and check the timing on each bank and see if the mechanical distributor advance is advancing.
    Easy stuff to do yourself if you are a little handy.
    Good luck.
    Drew Altemara
  24. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    I had a similar problem on my '78 308, I looked down the carbs while holding the throtle at 3500 and saw fuel dribble from the accelerator jets. The cure was to clean the check valve in the accelerator pump circuit.
  25. Tspringer
    Apr 11, 2002
    6,155
    David Feinberg on another board posted this:
    Terry,
    I wrote a post on this subject quite some time ago entitled "What's wrong with my BB"...or something like that. The symptom you descibe is typically caused by a sticking/jammed accel pump discharge valve (in the body of the carb)....and/or a loose accel pump nozzle check valve (at the point of fuel discharge).
    Based on your description, I'd place my money on the pump discharge valve....as if it were to stick open, you'd siphon fuel via the pump circuit under all throttle positions....
    Carb rebuilds....or just pulling and cleaning this specific jets on the car will solve the problem.
    Regards,
    David
    I tend to agree with him and others who posted similar ideas here. The mechanic is coming to get the car today and will be going into the carbs in depth to check for these or any other issues. I will probably also try the hotter plugs. Also am going to check on possible coil issues though this does seem more likely as a carb issue.
    Will post back when he is done! I would tackle this myself but just do not have the time plus the RSR project is at a phase where I cannot take time off it. We must get bare metal sections prepped and primed or they will start surface rusting....
    Terry
