DCNL carb question | FerrariChat
DCNL carb question
Discussion in 'Maserati' started by JulianMerak, Nov 29, 2013.
  1. JulianMerak
    JulianMerak Formula 3
    Just been playing with my carbs again. At one point the engine stalled and with the ignition on and the fuel pump producing 3 psi of pressure I noticed one carb was pouring with fuel. My question is, should all the float needle valves be capable of preventing any fuel getting through in the real world? Or is it time for new ones
    Julian
  2. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    a grove. there should b no fuel bypass. lot of cars lost for that reason.
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,047
    You either have a piece of dirt in a needle valve, or failed needle valves. Replace them all if they are very old. They should not leak in normal usage.
  4. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    but on the Merak thread someone made a very improved version
  5. thecarnut
    thecarnut F1 Rookie
    3,234
    Atlanta
    The Car Nut
    Meraks and Boras use DCNF carbs, not DCNL .... they are very different.
    Ivan
  6. JulianMerak
    Thanks, will order 4 new ones Monday
    PS Fuel was running down the inside not the outside of the carb so the fire risk was smaller at least and that also might explain why the colortune was totally hopeless yesterday. I did try it on the two cylinders controlled by the leaking needle valve by complete chance
    Julian
  7. staatsof
    96,011
    Fuggetaboutitland
    Bob
    Grose jet.
    I don't know if they fit DCNLs?
    Cars in good nick that are run regularly don't have these issues anyway.
    I thought he'd rebuilt the carbs? That would include this?
  8. JulianMerak
    No, I did a quick clean and synch which was,a big improvement. Perhaps I should just do it once and for all
  9. staatsof
    96,011
    Fuggetaboutitland
    Bob
    Probably so unless there's evidence of a somewhat recent rebuild. The float needle & seat valve are typical replacement item in a rebuild kit. As already noted it can lead to fires on some cars. You can buy the pieces separately and assemble a rebuild kit yourself. I did that for the six DCOEs on my Espada and it was cheaper than buying "kits" but check around. There are plenty of folks making parts for Webers so be careful. I also had the steel parts replated and replaced any damaged items.
  10. Quattroporte3
    Quattroporte3 Formula 3
    Nov 13, 2010
    1,060
    I bought this rebuild kit, as far as I could find it was cheaper than many others and seems to be of decent quality: Maserati Enthusiasts' Page (next to last post from the bottom)
    I also ordered Grose replacement jets instead of the needle type. They're supposed to be an improvement compared to original.
  11. red27
    red27 Formula Junior
    Sep 7, 2010
    943
    London UK
    Mark Oliver
    Do they supply for DCNL 5? The kits I could see were all for DCNF. Different beast.
    I am contemplating refurb. of my DCNLs too, with complete strip and ultrasonic clean.
    Pierce manifold have the requisite kits here:
    38-40 DCNL
    I have not taken the plunge yet but seem to recall from previous posts that they have a
    Solid reputation. Anyone with first hand experience?
    Cheers all.
    Mark.
  12. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,047
    Mike Pierce has been a friend and business associate for almost 30 years. He is a straight-up guy. Honest and very knowledgable. They now have the largest Weber inventory in the world.
  13. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,047
    A quick comment about Grose Jets. I am suprised you could find them, as the man who made them has died and the business is closed. He just operated out of the basement of his house. Unfortunately, I have switched back to Weber needle & seats, as I found the ethanol fuels caused the Grose Jets to glue themselves closed if the car was not run for a few months over the winter. The fuel pump pressure was not enough to pop the ball off it's seat, and I would have to take the top off the carb to free the ball. After a few years of this, it just got to be too much. However, we still use them in our race cars, as we run race gas and they do provide better fuel level control.
  14. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    I hate that ethanol in gas! I have been using ethanol free gas in my Merak, so the Gross jets have behaved well. The Gross jets are available for the DCNF carbs. I'm not sure how well they cross reference to the other Weber carburetors.
    Also, a list of all ethanol free gas stations in the U.S. is available on the Merak Group website under the links tab. The Gross jet is also listed under the products/parts tab. You can just Google "Merak Group" and it will lead you to the site.
    Ciao,
    George
  15. Quattroporte3
    Nov 13, 2010
    1,060
    I bought mine here: Marketplace:John Titus - Citroen-SM-wiki
    As far as ethanol is concerned, it's usually marked on the pump, and I try and avoid it as far as I'm able. Additionally, I've found that the car *hates* to sit unused, so I try and go for a drive at least once a week. It seems to help keep things working, it's when the car sits unused that stuff breaks!
  16. velocetwo
    velocetwo F1 World Champ
    Dec 11, 2006
    12,545
    Left Coast
    #16 velocetwo, Dec 1, 2013
    DCNL's are very diffrent than DCNF's
    Mine were on a very early Ghibli and only a few cars used them. I think one Lancia model.
    The bodies were sand cast and they lacked a air bypass adjustment, this caused a lot of extra work. In order to get the air bypass balance between the four carbs you had to "tweek the butterflies by hand. To do this I took the carb off and hooked my wife's vacuum cleaner hose to the bottom side and a Weber Synchrometer on the air trumpet end. This allowed me to see the air flow and make adjustments to all carb's butterflies before they went back on the car for final tuning.
    I found the colortune worked really well tuning the Ghibli
    Pierce is the best place for parts and I did order rebuild kits from him 10-12 years ago.
    On another note these carbs hate dirt even if it is microscopic.
    Make sure you check ALL your filters there could be a gas tank filter, a fuel pump (or pumps) filter, a engine compartment filter and the filter in the carb. They all need to be spotless.
    Carefully check your whole fuel system, this can save you a lot of time in the long run.
  17. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    Excellent points! Gas tank must be relined and an extra glass see through fuel filter wouldn't hurt either. The air filter should also spotless. In the late Merak SS model, it is possible to run 2 small K & N filters in the air intake snorkels [while still using the stock configuration] in conjunction with the stock air filter to keep things ultra-clean.
    Ciao,
    George
  18. JulianMerak
    Great idea with the vacuum, I will be trying that out soon. Thanks!
    If anyone is based here in Australia you can also get parts for these Carbs from Thornbury Carburetors here in Melbourne
  19. staatsof
    96,011
    Fuggetaboutitland
    Bob
    Life gets tough when your balls get stuck ...
    So you experienced some benefit using these?
    I had them in my Bora a t a time when I was chasing a much bigger gremlin and just took them back out to eliminate that as a possible suspect so I can't say I had a positive or negative experience with them.
  20. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    Hi Bob,
    I have had the Grose jets in use for about 6 years with no issues of any sticking even when I was using the 10% ethanol based fuel. Regular driving is certainly a very big plus. With the Grose jets there is never a worry of fuel starvation no matter what the demand, no matter what the bank.
    Just Sayin!
    Ciao,
    George
  21. Quattroporte3
    Nov 13, 2010
    1,060
    Any thoughts on using a vane style tool vs. a mercury column one for setting airflow and tuning/syncing carbs?
    Either way is fine for me, just wondering what the pros/cons of each type are.
    This is for the 42DCNF on a 4.9l V8, btw.
    Thanks!
  22. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    You are confusing matters.
    The colourtune is used to set the idle mixture.
    The mercury columns or any other vacuum/flow measuring device is used to synchronize the airflow between the throats.
    Best,
    Jack.
  23. BartvanderWeiden
    BartvanderWeiden Formula Junior
    Nov 29, 2008
    383
    Netherlands
    Bart van der Weiden
    Maseratisti,
    My advise before even touching the carbs:
    1. Set the valve clearance correct than the valve timing.
    2. Make sure the ignition is set correctly.
    3. Check the leads and put new plugs in.
    Only then start playing with the carbs.
    4. Make sure the carbs are absolutely clean inside!
    5. Start with the synchronisation first per carburettor, left and right intake shall be equal!
    6. Then fix the accelerator cable at a ~1.500rpm level and check / adjust the air flow to be exactly the same between the 4 carbs. This excercise is time consuming because every time you do and undo the nuts on the linkage the stuff resets itself a little different.
    7. Now go to idling RPM and check the airflow again, use the adjuster screws for the butterflies per carb. After all this you can start playing with your colortune to set the idling mixture.
    Be aware that if you foul a plug you need to run the engine under load for at least 30minutes to clean it up and be able to progress playing with your settings!
    Quite an excercise but it pays off to have your engine running smoothly.
    Ciao,
    Bart
  24. thecarnut
    thecarnut F1 Rookie
    3,234
    Atlanta
    The Car Nut
    +1 very good suggestions.
    Here are a few other tips:
    Before you start adjusting the carbs do a compression test. Setting the carbs to all draw equal amount of air is fine if the compression is consistent across all cylinders but not so good if you have most cylinders at 150 psi and one at 120 psi. You will want the lower compression cylinder(s) to draw a little more air to compensate.
    A Colortune is a great tool to verify that the carbs are working properly. You should be able to screw in the idle mixture screw in all the way and see the spark but the cylinder not firing. As you unscrew the mixture adjustment screw the flame will initially be white, then turn blue and finally turn yellow. I set them just as they go from blue to yellow.
    If you cannot get the cylinders to burn with a blue flame using the Colortune (ie: the cylinder goes from not firing to a bright yellow flame), it is time to rebuild the carbs.
    For those not familiar with Colortune it is essentially a see-though spark plug. You temporarily replace the standard spark plug with the Colortune and then you can see what is happening inside the cylinder while the engine is running. You do this one cylinder at a time. Simple and effective.
    Once you finish with the Colortune idle jet adjustments, disconnect the spark plug lead one cylinder at a time and note the RPM drop. Use a heavy rubber glove when disconnection the wires! I use the digital RPM indicator on the ignition timing light for this test. You want each cylinder to have approximately the same RPM drop when disconnected. Adjust the idle mixture and/or air flow to achieve this.
    As Bart mentioned, this is very time consuming but will make a huge difference in the way the engine runs.
    Ivan
  25. Quattroporte3
    Nov 13, 2010
    1,060
    Ok, ok,
    my typo.
    I didn't mean colortune (even though I wrote it, and yes I will buy one of those too), I meant "carbtune", as produced by f.x. Morgan and many others. Mercury (or not) filled columns to measure vacuum and sync carbs together. I've seen these kinds, as well as the vane type that looks like a wine cork with a meter on it, sits on top of the velocity stack.
    As far as the other things go, the car has been gone through, has excellent compression across all cylinders, no loss on leak down test and the valve clearance/timing has been set. The people at the dyno place found that 2 spark plug wires were not providing spark under load, all wires have been replaced and tested as ok. They also found that no. 2 carb (from the firewall) is leaking, and wanted the carbs rebuilt before doing a dyno run.
    The carbs were rebuilt by the PPO, but that's beginning to be quite a few years by now, over 5. Plus the fact that they're leaking tell me that it's time to go through and make sure they're ok.
    Thus my question now, which carb sync unit do I want, and why. Yes, I'll get a colortune too for the idle mixture :).
    (and thanks for the tips Bart and Ivan, they'll come in handy when I get that far!)
