DCT Failure | Page 2 | FerrariChat
DCT Failure
Discussion in 'California(Portofino)/Roma(Amalfi)' started by MalibuGuy, Sep 21, 2012.
  1. hotbmwm3
    hotbmwm3 Formula Junior
    Jan 11, 2006
    554
    Melbourne and London
    Owner -09 California
    I would make a call to at least check your rights
    This link was recommended by someone in another part of ferrarichat when I googled Ferrari lemon law California lawyer
    http://www.lemonlawspecialists.com/
    Lemon law is a state based law so suggest you find a specialist in SFV or LA
    You live in the right place to find a lawyer :)
    It's 10 years since I lived in Malibu, but from memory, if the car is purchased from you it would appear as a lemoned law car on the carfax for the next owner
    And that's a lot better to ensure that future buyers know the car has huge problems without it effecting your resale
  2. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    6,048
    OK got back my Cali.
    She is humming along like a dream.
    Wiring harness??? Well they replaced it and did some tests with the old DCT--still malfunctioning. So the harness was perfectly fine.
    Got a new DCT--not a rebuild which is what I think they were doing in the past. Shifts properly. Hopefully Getrag fixed the problem. If they did this one should last 100K miles.
    But if it doesn't, Ferrari now has a 2 yr warranty on parts like the DCT.
    My dealer and service center handled this extremely well. I am very pleased.
    Also FNA stepped up and helped out with extending my warranty!
    Wow now I can drive and sleep in peace!
  3. hotbmwm3
    Jan 11, 2006
    554
    Thanks for the update
    Seems like a reasonable outcome
    Suggest you keep a file for the documents they have provided in relation to the parts warranty and vehicle warranty
    Dealerships change ownership, employees at FNA leave etc
    Have everything documented, don't leave any weasel room
    I hope they promised to replace the entire car in the event of a FIFTH failure
    If it happens a fifth time, ask for a California loan car while they are checking out the problem, and don't give the loan car out until they have replaced the car
  4. MalibuGuy
    Sep 18, 2007
    6,048
    The loan car I usually get is a Prius!
  5. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Dullsville. Another reason to solve the transmission mystery.
  6. Balsamina
    Balsamina Formula Junior
    May 19, 2010
    964
    San Francisco Area
    S
    Good for you. Good luck this time around. Knock on wood, still no problems with mine, other than the random sw glitch when trying to start.
  7. gk@kco.no
    Mar 3, 2010
    46
    Norway
    Geir Knutsen
    I have gearbox no 3, all changes on the warranty. I have just bought the extended warranty. I did not realize any fault with the first gearbox, but the dealer did. On the 2nd gearbox, the car kept jumping out of 3rd gear. Seems OK now, on the 3rd gearbox! The car is the firs one that was deliverred in Norway, June 2009
  8. MalibuGuy
    Sep 18, 2007
    6,048
    Obviously the problem you have with the DCT has NOTHING to do with your driving.
    The Getrag DCT has a design defect. Getrag needs to fix this. In the meantime, we are all in the dark. The replacement box may have the same defrect and therefore will FAIL.
    The replacement cost out of warranty is 28K plus labor
  9. Xeron
    Xeron Formula Junior
    Jan 25, 2010
    404
    Vegas
    California Lemon Law is no joke and very consumer friendly. I had a big issue with my SL63 transmission jerking and banging into gear and I lemoned it after 3 clutch packs and two transmissions, wiring harness etc. ( Apparently it was a software issue). None the less, having the car go into gear on its own in freeway traffic is enough to make you lose it in your pants. I can refer you to the guy I used. As long as you bought the car in California and paid California sales tax the law applies to you regardless of where you live. MB was yanking my chain for months over this and was actually the main reason I moved from AMG to the California.
    Any word if the 458s are affected by the DCT issue?
  10. MalibuGuy
    Sep 18, 2007
    6,048
    Lets hope the 458 box is better designed than the Cali.
    But Cali drivers tend to DRIVE while many 458 owners only use the car for special occasions and are afraid to put miles on the car. They may never see the failure due to the low use.
  11. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Or until it's WAY past the warranty expiration.
  12. mrizkallah23
    mrizkallah23 Formula 3
    Sep 10, 2012
    1,513
    Los Angeles
    Mark Rizkallah
    Ya sounds bad man, maybe you should just get rid of it....and in its current condition i dont think it will sell for much...but ill be glad to just take it off your hands as a friend and fellow Fchatter...:)
    OP its good to see someone with mileage on the car. I definitly would be super mad about going through 4 gear boxes. Hope this next one last you longer. Thank god for the warranty.
  13. MalibuGuy
    Sep 18, 2007
    6,048
    Since the California will be retired in about a year, do you really think that Getrag is going to correct the DCT problems for this car?
    Or do parts suppliers continue to produce replacement parts for several years and improve their design.
    I think that they would probably make sure that the new DCT designed to fit into the new replacement California doesnt have this flaw.
    Im not so sure about the current Cali getting a fix.
    What do you think?
  14. hotbmwm3
    Jan 11, 2006
    554
    Once the cars are out of warranty faulty design actually helps their profitability
    I just bought a VW golf that's out of warranty and the air conditioning compressor is a known failure item on the first couple of years production
    So I'm about to pay $1000 to fix it on a car that cost $15k
    If companies can make parts that fail after the warranty expires it could double their sales without any additional costs to find leads or convert them
    I wonder if there are any management consultants around that suggest making parts fail deliberately by under engineering them?
  15. eclipsisNA
    eclipsisNA Southern California
    91
    LA & OC, CA
    After 4 gearbox changes, they still don't know what is causing this? It's not like Gertrag only produces gearboxes for Ferrari. The DCT in my M3 is a dream to use and has held up 40k+ miles. I would Lemon Law the car and not sell it to some unsuspecting soul.
  16. MalibuGuy
    Sep 18, 2007
    6,048
    #41 MalibuGuy, Oct 18, 2012
    Thanks for your comments. I am looking into this option too.
    But analyzing this problem leads me to believe that the DCT failure is not the result of being unlucky and getting a bad box. Instead it is a design defect which exists in all Cali's which rears its ugly head after use-- 19k to 20 something thousand miles.
    So the unsuspecting soul is anyone who owns a Cali and puts miles on the car!
    I think Ferrari should put pressure on Getrag to fix the problem and not just handle the failures on a case by case manner.
    Involving the Lemon Law is one way for the individual to get rid of his car. But it is less satisfying than getting the problem fixed right for all the owners.
  17. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I don't know about "deliberate," but Ferrari owners tend to contribute to the "pay, because the warranty is expired" syndrome, as many owners seem to want to put less than 10k miles on their new cars, then sell them, often just before the warranty is about to expire (or after). I have no doubt this low mileage practice has saved Ferrari countless millions in warranty repairs and where the repairs are eventually done by Ferrari, countless millions in profits. 10-20k miles are not enough miles to discover all the defects, and if it's true the the Getrags are defective and will fail at 20-30k miles on all Calis, then nearly every owner (or subsequent buyer) is in for a rude shock if they follow the pattern of "saving" their cars' mileage by keeping them under 10k miles. I hope this isn't true for the DCT Getrags but am at a loss whether to try to sell soon to avoid this possible scenario or drive the car more "like normal" and put enough miles that it continues to be Ferrari's problem (with the 2 year warranty on new parts, if they fail at 20k miles, you just need to drive the car 20-30k miles within each two years, get a new transmission each time, and continue this until the rest of the car falls apart!).
  18. hotbmwm3
    Jan 11, 2006
    554
    I'm going to sell mine in the next few months while there is 6 months warranty left
    I don't want a bill for $25,000 six months after the warranty ends
    I have really enjoyed having it for 18 months
  19. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I re-read the thread. Hopefully the problem is confined to early cars. MalibuGuy, at what mileage intervals did your DCT fail? Others who have experienced failure, at what intervals and what model year is your car? Rick Lederman and others have put > 40k miles on their cars without any problems so maybe this isn't a widespread issue.
    I do notice that the car is reluctant to start in first unless you come to a full stop. I use the paddle to ensure a first gear start but wonder about that from wear and tear perspective. It seems worse to make DCT slip to start from 0 mph in second. Sometimes when in quick stop and go driving, the DCT gets confused after stopping and quickly going straight away (like you would from stop signs). Where I live the city decided they wanted to slow traffic so there's a stop sign almost every block so multiple start-stop-start agains are unavoidable. Everything running fine though.
  20. MalibuGuy
    Sep 18, 2007
    6,048
    I get about 17k miles per DCT
    Rick sold his first car and now is on his second. I don't think he put 40k miles on either car
  21. hotbmwm3
    Jan 11, 2006
    554
    I wonder how widespread this problem is
    I only have 5000 miles on my car
    Can everyone here that has experienced a DCT failure requiring a gearbox repair or peace net please post in this thread listing
    Build month and year (early, mid late 20xx is fine)
    Repair or replaced?
    Miles/Km traveled at time of failure
    Please list details if multiple failures
  22. Naplesgolfer
    Naplesgolfer Rookie
    Feb 19, 2011
    34
    Florida
    Erik
    My 2010 Cali, built in Nov 2009 , had one DCT Failure at 2500 Miles. They replaced the DCT. I just traded the Car on a 2013 Cali 30 in June. I am getting the car in mid Dec. most likely. Hope this helps.
  23. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    How many miles on the car at trade-in?
  24. Naplesgolfer
    Naplesgolfer Rookie
    Feb 19, 2011
    34
    Florida
    Erik
  25. professor88
    professor88 Rookie
    Jan 10, 2010
    49
    DCT failure immediately after delivery July 2010---no problems since then with 11K miles now
